renault 16TS rev counter not working
Results 1 to 24 of 24
Like Tree2Likes
  • 1 Post By robmac
  • 1 Post By dogboy
Thread: renault 16TS rev counter not working
    1000+ Posts dogboy's Avatar
    melbourne,victoria,australia
    1,332
    Default renault 16TS rev counter not working
    thought id better start a new thread
    my rev counter is not working..tried a gogle search and nothing
    sany ide what I should check
    mind you...I cant even find the fuse box...hope it's not inside the locked glovebox...not sure how to get into that
    Rev. Dogboy
    1969 DS21 Pallas BVH with leather
    1970 Renault 16TS
    1967 Honda S800 cabrio
    Citroen 1970 DS21 Cabrio replica
    Citroen 1966 ID Safari (with 23 running gear)
    Citroen 1975 DS23 Safari
    1975 VW Kombi poptop
    1987 2CV
    Porsche Boxster S manual
    1988 Vespa PX200E
    19,103
    If it's the same as the contemporary Peugeots. The tacho needs three connections:
    1. Ground
    2. Ign switched +12v
    3 A connection to the points/ coil -ve.
    dogboy likes this.
    19,103
    Positive and ground are on the nuts at the back. The coil connection is on quick connect spade on the back, at least on the pug ones.
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,072
    Quote Originally Posted by dogboy View Post
    Its been a long time since I have anything really to do with an R16, Looking in the Haynes book I have here it looks like the fuse box is on the inner left guard behind the air cleaner
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,072
    As far a getting the tacho working, have a look on the coil there should be one wire on the positive side which comes from the ignition switch. There should also be two wires on the negative side of the coil which one will go to the distributor and the other goes to the tacho. Make sure these wires are connected.
    Next I would remove the tacho and make sure that everything is connected.
    If all is ok in both places you may have a faulty tacho.
    Is there any other electrical apparatus in the car that is not working?
    Regards Col
    1973 Alpine A110
    Simon's Avatar
    6,174
    Give the connectors to the printed circuit on the instrument cluster a wriggle as well, perhaps there may be a grubby connection.
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
    Brisbane/Australia
    2,067
    It is unusual for the tacho itself to be faulty, more likely dodgy connections as mentioned by others.
    The entire instrument cluster is on the one circuit so if the rest of the instrument cluster gauges are working then it won't be a fuse.
    Dirty contacts on the coil or a broken wire on the coil would be my first pick.
    1,332
    yes...the dash lights are not working
    is there a fan for the heater cause I cant see one??
    how does the tacho come out...no Haynes and don't want to damage anything...I slipped my hand behind and felt the earth and the positive...got a little tingle...haven't felt the spade connector yet
    all connections are on coil
    Rev. Dogboy
    1970 Renault 16TS
    1987 2CV
    1988 Vespa PX200E
    bob
    bob is offline
    May 2001
    Skipton
    2,393
    G'day,
    .........how does the tacho come out...no Haynes and don't want to damage anything........
    if you check the stickys.....
    Download links for manuals, tech data etc
    at post #38 you'll find a link for R16 tech stuff.....
    cheers,
    Bob
    Simon's Avatar
    6,174
    Are you sure it isn't an Aston Martin Lagonda? We're talking about 12 volts here....
    Have you checked the fuses in the location as mentioned by Col earlier?
    1963 Renault R4 Van
    1964 Renault R4
    10,816
    And there is a fan. Isn't it the third lever in the temperature up versus down quadrant? Not wildly effective but does help with those stylish demisting vents.
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
    Boonah Qld
    2,538
    If my hands are sweaty I have had a small tingle from 12 volts.
    Simon's Avatar
    6,174
    Correct. The one with the (ISO?) baby blowing symbol.
    1963 Renault R4 Van
    1964 Renault R4
    Brisbane/Australia
    2,067
    If none of the instruments are working and you're getting a 'tingle' when you're groping about on the dash then it's probably an earthing issue. The instrument lights are are on a different circuit from the dash power and if they're not working then this again points to an earthing issue.
    Try running a patch lead from an earth on the car to an earth point on the instruments.
    If you've got Jaeger instruments it will have the flexible plastic circuit board and you'll have to find a earth point on there.
    VDO will have point to point wiring so will be easier.
    It's been a while since I had my 16's (I've had a TL & a TS) but if memory serves, getting at the instruments on the R16 is pretty easy, just lift the top of the dash off.
    1,332
    I looked and still could not see it...maybe the aircleaner needs to be removed first..
    when previous owner bought car it arrived at his place,unlocked with ignition key and a receipt of sale and that was it
    I love a cars history so want to try and track down the previous owners family...someone in the Renault car club surely knows the car
    Is it listed on the register??
    Rev. Dogboy
    1970 Renault 16TS
    1987 2CV
    1988 Vespa PX200E
    Mar 2003
    356
    On my 76 model the 2 fuses are on inner right front guard and should have a cover -just follow the wires. As I recall my 1970 model was the same.
    Citroen DS21 Pallas 1970 Renault 16TS 1976 Renault 5TS 1981
    Nov 2005
    Geraldton
    1,574
    Ahh... those "ceramic" fuses. Sometimes a visual inspection isn't complete until you've removed the the fuse and had a butcher's at the conical metal sections on either end of the fuse. They sometime wear in situ and give continuity issues.
    In the Shed(s):
    In the Past:
    Boonah Qld
    2,538
    Yes ceramic fuses do give quite a bit of trouble. The ends become corroded. On my R15 I always left the cover off the fuse box so as I could wobble the fuses going along when the wipers stopped during a storm. Luckily they are with in easy hand reach near the right knee.
    bob
    bob is offline
    May 2001
    Skipton
    2,393
    G'day,
    My answer to those nasty little devices is here....
    Renault 20ts & Fuego & maybe others pointy fuse fix
    cheers,
    Bob
    Brisbane/Australia
    2,067
    The ceramic ones were bad but even worse were the cheapie fuses with the plastic core made to look like they're ceramic.
    These had a proclivity to melt or deform and made the dodgy contacts even worse.
    1,332
    Quote Originally Posted by tresbon2 View Post
    ah ha...here I was looking for a big fusebox and it's tiny...2 fuses...wow
    guess I better stop looking for the heater blower fan as doesn't seem to be one...how is demisting in these cars?
    I now have the feeling my heater knob mover but the heater didn't...def need a heater
    anyone here taken their 16 to the renno workshop in frankston?
    I'm around Red Hill (mornington peninsula) so looking for a local who knows these cars
    Rev. Dogboy
    1970 Renault 16TS
    1987 2CV
    1988 Vespa PX200E
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,072
    From memory the actual heater fan is under the scuttle panel below the windscreen.
    The heater itself is also a long twin tube affair, that could be blocked. You will also find this under the scuttle panel.
    Its easy to remove and dismantle so that it can be flushed out with a garden hose.
    Regards Col
    1973 Alpine A110
    Brisbane/Australia
    2,067
    Yes the heater core and the fan are both under the scuttle.
    The fan motor is at the drivers side end near the vent flap.
    When removing the scuttle you have to disconnect the cable to the vent flap .
    The motor could be dodgy as they get wet and slowly seize up.
    Even when the were new the demisting performance was pretty ordinary.
    Being designed as a LHD most of the demisting air was blown onto the center or the passenger side of our RHD versions.
    1,332
    Quote Originally Posted by REN TIN TIN View Post
    well I had a fellow frogger visit and show me the finer ponts of the 16
    I now know how the fan works and it actually works...I just hadn't moved the lever across enough
    also I got the dash lights working by fiddling with the rheostat control
    so just the tacho left to fix electrical wise
    thanks for everyones assistance
    JohnW likes this.
    Rev. Dogboy
    1970 Renault 16TS
    1987 2CV
    1988 Vespa PX200E
