Widening R8/R10 14" Rims
Results 1 to 19 of 19
  • 1 Post By R8 Dream
Thread: Widening R8/R10 14" Rims
    634
    Default Widening R8/R10 14" Rims
    I heard that AJAX in Moorabbin shut its doors not long ago.
    I hear there was another place in Heidelberg, Vic that used to cut the centres out of 15" steel wheels and weld them up on 5" steel rims.
    Can anyone recall their name and if they are still in operation?
    Angelo
    4,366
    Can't help in VIC, but I had R16 centres welded into new holden rims to make 14x6" wheels for my R10/R8.
    They were done by a company here in NSW called Morton and May in Warwick Farm. Was $750-800 for the set (I supplied the R16 wheels, they did the rest).
    KB
    Fellow Frogger! Jensen's Avatar
    373
    Iíve got a pair of R8/10 15 inch rims that have been widened (to 6 inches I think). Currently have 195/60 tyres which donít look either stretched or baggy. Happy to sell them if of any use. PM if interested Located in Melbourne too.
    Jeremy
    634
    Thanks Jeremy for the offer.
    i have 3 X 14" X 5" and need just one made up to match these.
    Feb 2005
    rosevale/tasmania
    2,745
    I have gone down both paths: cut down 15s & R16 centres. The advantage of cutting down, 15s is that they can be cut to mate up with the wheel wells of the rims being used With the 14 centres from the R16, one has to check that they will reach (or over-reach - in which case slight cutting down will be in order).
    However, if the R16 centres will mate with your intended rims then that is by far the better path to follow. This is because the R16 centre is stronger & has much better stud hole & nut design.
    If you are stuck with cutting down a 15" R10 rim, then I'd very much recommend the reinforcement which I added to mine (a "spacer" ring cut out of 3 mm plate & welded at two points, 40į & 80į, in each 120į arc between the studs). This has two benefits: The first is very much reducing the "flapping" of the wheel centre in those arcs & the consequent stress & strain (to the point of cracking) in the stud hole area. The second is giving one three new holes which aren't flogging oval &, as they are in 3mm plate, will better resist future ovality.
    enjoy! Peter
    Mar 2013
    olinda victoria australia
    696
    NEway Wheels
    11 Beatrice ave
    West Heidelberg 3081
    03 9457 3141
    Have done a few wheels for me over 40 years ad never let me down
    Do a lot of oddball stuff and charge a fair ( not stupidly low, not stupidly high ) price
    They give good advice and are honest and helpful
    Only sticking point might be that they told me when I went in with 4CV rims to tweak that they could only get 6" new rims, nothing smaller, but that they were quite happy to weld on anything that I could provide, provided it was safe and would fit
    You may need to source your own 5" rims
    Best Wishes
    Andrew
    Quote Originally Posted by R8 Dream View Post
    Angelo
    634
    Quote Originally Posted by Andrew Watkins View Post
    NEway Wheels
    11 Beatrice ave
    03 9457 3141
    Best Wishes
    Andrew
    Thanks Andrew, yes was Newbay!
    Just couldnít recall the name
    Will call and see what they can do for me
    My Supermodel 63-1092's Avatar
    somewhere! Pilbara, Bowen Basin, Melbourne?
    10,754
    I got mine done in Lilydale, just google it, if you can't find them id have to look through my stuff to get the number.
    I even have a spare rim to cut up if you need it.
    John
    Александър Кристоф Шанел
    Fellow Frogger! R10S FAN's Avatar
    Mt Barker S.A.
    390
    Hey mate i have 1 x 14 x 5 widened rim with an R16 centre i think. If you want it you can have it for the cost of postage. Will put up a pic tonight.
    Anthony
    Sent from my SM-G935F using aussiefrogs mobile app
    Current Frogs:
    1964 Renault 8 (1289 / Sonics)
    1968 Renault 10 (Modified 1.4L Alpine White)
    Mt Barker S.A.
    390
    If anyone else needs any wide 13 inch widies to suit R8/R10 send me a pm im happy to pass them on. I reckon i have 3 and i have a pair of 13 inch widies to suit R12 too.
    Anthony
    Current Frogs:
    Feb 2005
    rosevale/tasmania
    2,745
    concerning 5"x14, old Valiant rims are that as I recall; so, a contact to the Valiant owners' clubs?
    634
    Quote Originally Posted by 63-1092 View Post
    Thanks John, Iíll give them a call on Monday.
    I have around 20 x R10 rims so all good for spares
    Angelo
    634
    Quote Originally Posted by R10S FAN View Post
    Anthony
    Thanks for the offer, although I acknowledge the R16 inners are stronger (thus a little heavier) I am hoping to match the other 3 Wheels i have with R10 inners.
    I have a 14Ē x 5Ē rim that i can salvage if needed as well as heaps of R10 centres
    Angelo
    10,763
    Angelo
    20 should be adequate.
    Are they all ROH ones, welded and locally made? Any 10S lurking in the stash with the redbacks?
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
    Feb 2005
    rosevale/tasmania
    2,745
    I have a 14” x 5” rim that i can salvage if needed as well as heaps of R10 centres
    Angelo
    I earnestly advise reinforcing the centres then.
    634
    Peter, I do recall seeing a post some time back with pics and instructions on how this was done.
    can you easily post that link again?
    thanks
    Angelo
    634
    Not sure John about the 10S type, but they are all stored off site and no doubt being well guarded by the redbacks ������
    jaahn likes this.
    Feb 2005
    rosevale/tasmania
    2,745
    thanks
    Angelo
    Try the below annotated photo. As I said earlier, the plate was 3mm. I took a wheel to an engineering works to facilitate them getting inner & outer ring diameters & (150mm PCD) stud pattern & hole diameter right. Supplied them then to the wheelwright doing the conversion.
    Widening R8/R10 14" Rims-explained-reinforcement-ring.jpg
    Sep 2011
    Victoria
    47
    Following for future reference
