R16 - What's the widest tyre someone has put
Results 1 to 15 of 15
    Nov 2005
    Geraldton
    1,565
    Default R16 - What's the widest tyre someone has put
    What's the widest tyre anyone has put on a R16 rim without drama?
    I'm not talking legal here. I'm trying to source some mud/sand/rally tyres for my R12 that's running 14" rims.
    Getting anything in a 175 X 14 is very expensive (often ex-England) and hard to find. 185 and 195 are a little easier.
    The tyres are for some off road driving and wont be used to cover much distance, probably <1000kms.
    There was someone doing retreads on the east coast a while back, for what I want they'd be fine. Does anyone have a lead on who that might be. Only need two.
    Peter
    In the Shed(s):
    In the Past:
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,007
    I have put 205's on a R16 14" rim, I run them on a R16 though not an R12 so not sure how you will go for clearances.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    1000+ Posts bowie's Avatar
    Aug 2002
    Sydney, Concord City, Sir.
    3,373
    I currently have 205mm tyres on my 12. I haven't measured the offset of my rims (they are 13" R18's that were widened), but they scrubbed on the rear until I folded up the rear arches. Now they only scrub when the suspension takes a hard hit.
    I reckon with 195's you will be peachy fine.
    1000+ Posts geckoeng's Avatar
    Perth, WA
    1,640
    Mr. P,
    My Yellow 16TS used to run 185x14 Ute tyres,
    You will need to check clearances . And they can come in rather agresive tread patterns. But for sand (?) a road tread may be better, with 15-20 psi.
    Ray
    Ray geckoeng
    Think Old, But Run Modern !!
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,007
    Mr. P,
Name:	Yellow TS 1.jpg
    Ray
    You will be struggling to get those under the guards of an R12, they are just to tall and will rub.
    Regards Col
    1973 Alpine A110
    Simon's Avatar
    6,161
    I'm thinking wider than 175/65 x 14s may have a good chance of snagging on turns where the floorpan/doorpillar/sill is stitched together just inside the wheel arch of the 12, as there isn't a lot of clearance there with the 175/65 x 14. Probably nothing a sledgy couldn't fix, but it would look a bit untidy, then there is the spring baseplate too, especially if it has the stock 12 front brakes instead of 15/17 vented discs. Caster bar clearance too?
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
    Feb 2005
    rosevale/tasmania
    2,744
    What is the rim width? If standard R16, then it's 4.5". That means that the maximum width fitments are:
    80 series: 185
    75: 185
    70: 185
    65: 165
    A useful site on this is:
    Wheel/Rim Size Calculator - Shows acceptable rim width range for the tyre size
    As a rough rule of thumb, the higher the profile, the less chance of unseating the bead at low pressures on a given rim width.
    In 185/80 one can get a van tyre & this will have reinforced sidewalls. But clearance is an issue. Compared to standard 155/80-13, 185/80-14 is 3" larger in diameter & 1" larger in total width. A good site for these comparisons is:
    https://tiresize.com/comparison/
    I know 185/70-13 fits & maybe 185/70-14 is the best compromise. No van tyres in this size that I know of but BF Goodrich has the Advantage T/A Drive which Jax lists at $109 each (sadly the recent "4 for the price of 3" deal is defunct). It's fairly coarsley treaded with an emphasis on lateral main grooves & is supposedly fairly strongly constructed.
    cheers! Peter
    Nov 2005
    Geraldton
    1,565
    Thanks for your replies
    Good news!
    Just had a root around in the shed and pulled out a set of R 16 wheels. They're 6 X 14 rims with the centre hole, co they can be balanced on a standard machine, probably off a TX. That'll make things a whole lot easier.
    The R12 has raised suspension and I've had 185s on it before with real scraping issues.
    Still looking for an agressively treaded tyre.
    Peter
    In the Shed(s):
    In the Past:
    Feb 2005
    rosevale/tasmania
    2,744
    TX had 4.5" X 14 so . . . .
    Still, it should make the hunt easier having the 6" rims.
    Feb 2005
    rosevale/tasmania
    2,744
    Hmm! I had a brief trawl & my thoughts are still that the T/A Drive might be as good as you'll get. Van tyres tend to be solidly treaded with a low percentage of void. Off-road tyres are not available. With 6" you could fit 195/70.
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,007
    Rally tyres but they are not cheap
    Regards Col
    1973 Alpine A110
    Nov 2005
    Geraldton
    1,565
    Yeah, that's been my observation too.
    And yes rally tyres aren't cheap!
    Anyone know the crowd that retreaded mud/sand/rally tyres?
    In the Shed(s):
    In the Past:
    Jun 2004
    396
    I run Dunlop 14" alloys on my 12 with (from memory) 185/60-14, or it could be a 185/65-14.
    They fit fine on the rear now the guards are rolled, and the fronts are no problem. I have run 195/60-14 before but they rub a bit too much on the rear under compression.
    I have long term dreams of a slightly flared guard to run 225/50-15's on it, but that's a long way off.
    Regarding the rally retreads, I do remember a tyre shop in Morisset just off the freeway in the industrial estate that carried a bunch of rally retreads for all the Awaba Car Club guys for khanacross.
    Give these guys a call
    Mega Tread Tyre Barn
    Tyres - Morisset, NSW 2264
    Unit 3 15 Advantage Ave, Morisset NSW 2264
    (02) 4970 4090
    Feb 2005
    rosevale/tasmania
    2,744
    Quote Originally Posted by 3006882 View Post
    (02) 4970 4090
    hmm! sounds like 195/70 will foul.
    185/70 might even foul as well. much depends on just where you get fouling - is it a width issue or a diameter issue? compared to 195/60 the 185/70 is narrower but taller.
    185/65 is both narrower & shorter than 195/60 & might be ok. Given the off-road application, it'd be a better choice than 185/60.
    Fortunately for the T/A Drive option, 185/65 (& 185/60) are available in 14".
    1000+ Posts driven's Avatar
    Apr 2005
    1,424
    Many moons ago, sounds better than years, I used 195/45/13 on standard 13 inch rims.
    Upset the gearing but this was for Motorkhana.
    Acceleration was much improved. Clearance was fine but check again
    Got them as used imported tyres from a place in Newlands Rd Coburg
