Parts numbers catalogue
Results 1 to 15 of 15
  • 1 Post By Simon
Thread: Parts numbers catalogue
    Jun 2017
    Victoria
    34
    Default Parts numbers catalogue
    Hey all,
    Through my own cunning I've acquired several boxes of R12 bits and pieces kept as warranty and service stock at a rural Victorian dealership and forgotten about. All have carefully logged part numbers, but buggered if I know where some of them fit in the scheme of things. Does anyone have a parts catalogue that I can throw some numbers at?
    Cheers, one.four
    Sent from my SM-G950F using aussiefrogs mobile app
    Brisbane/Australia
    2,051
    Hello One.four,
    I have an R12 parts catalogue as do quite a few members.
    I've got some of it scanned but unfortunately most of the catalogue is hardcopy.
    Actually, the easiest way to search the parts is with Google, even for an oldie like an R12.
    Just enter the part number and Renault and you'll get a description and/or photograph.
    You'd be surprised how many old part numbers are listed.
    For example, the part in your photograph come up as a gasket for a Solex 32EISA/32SEIA/35EITA.
    A lot of Renault parts are interchangeable between models so this part and others will not only fit the 12.
    Jun 2017
    Victoria
    34
    Will look into it. Can I post the part numbers of the bits I canít find?
    Jun 2017
    Victoria
    34
    Hereís one: 7702062453. Itís a Lucas headlight in a box.
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,028
    Quote Originally Posted by One.four View Post
    Here’s one: 7702062453. It’s a Lucas headlight in a box.
    That could be an Australian made head light for an R12 & R16
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    Simon's Avatar
    6,162
    Correct. A Renault 16 (1970-74) rectangular headlamp.
    Kenfuego likes this.
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
    Jun 2017
    Victoria
    34
    PART NUMBER QTY MY GUESS OF WHAT IT IS
    7700 572 774 Head gasket to what?
    No part number Manifold gasket
    No part number Renault 12 ignition leads
    7700 610 ??? Window winder
    7700 502 161 Round bracket
    No part number Borg Warner 35 Auto transmission filter and gasket
    7700 511 772 Alternator bracket?
    7701 009 940 Unknown label
    No part number Klaxxon indicator repeater in box
    7700 508 016 Paper gaskets
    7702 050 215 Wiper clips
    7703 087 072 Seal
    0607 772 500 Rings
    7700 520 121 Fan switch
    7700 509 366 3 Wiper switch
    7700 562 310 Unknown label
    7703 077 032 Unknown label
    7703 074 070 Empty bag
    R-0554732800 Wheel studs
    7703 037 004? Circular plastic trim clips
    7703 033 003 3 Copper bolts
    7702 050 202 Wiper arm?
    7700 516 675 Rubber stops
    7703 067 137 3 Spring clips
    7701 348 178 4 Rubber rings
    7702 050 755 2 Round plastic clips
    7701 493 018 Lots Clips
    7702 050 920 5 Chrome trim ends
    No part number Plastic valve
    7701 348 179 Door light switch?
    7701 001 535 Fuel gauge
    No part number Foglight switch
    7703 077 033 Trim clip black
    No part number 6 Piston rings?
    08 54 313 200 Diaphragm
    7701 001 335 Rubber caps, clips, washers
    870852300 Rubber caps, copper bowl
    7701 348 028 Sun visor bracket
    7701 348 654 Jaegar indicator/light switch
    7700 555 322 2 Bracket
    No part number Clock
    0854 910 800 Dizzy cap
    7701 009 940 4 Drum brake replacement pads
    7700 565 962 Circle clip window winder trim?
    08 55 779 500 Rubber ring 1.5cm
    7700 616 590 Small rubber boot
    0855 564 4000 Split pins, rubber rings 1.5cm
    7866 037 000 Connectors?
    870557600 Carby butterfly
    7700 531 733 Spider joint
    No part number Drive shaft boot in cylinder container
    13 60 001 Ball joint
    7703 076 099 Spring clips
    7701 458 190 Washer and bush
    7700 506 301 Oil cap
    7700 589 253 Bearing
    7701 201 680 2 Rubber caps
    7700 725 145 Bush
    7701 460 815 4 Pin
    7701 493 043 Bolts, 5mm?
    7700 505 189 2 Bracket
    7700 555 325 Bracket
    7701 017 281 Wiper blades
    7700 508 592 Fuel sender unit
    7700 509 886 Boot latch
    7701 001 335 2 Brake boots
    7701 000 413 Brake bits
    7701 000 414 Brake bits
    7701 200 258 2 Brake bits
    7701 200 687 Brake bits
    7701 200 258 Brake bits
    7701 348 034 5 Gaskets
    7700 522 094 2 Manifold water fitting
    7701 000 417 Brake bits
    7703 077 032 2 White plastic mould clips
    7701 001 606 Metal caps
    7700 504 156 Rubber strap
    7701 200 026 Spring
    08 55 771 200 Seal
    7701 493 069 White plastic clips
    7703 087 074 Rubber grommet
    1386 2 Springs to fit Ducellier 71133
    7700 530 690 Door latch
    7701 365 377 Rear brake cylinder
    7701 458 180 4 Valves, intake?
    More to come...
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,028
    I'm not up with part numbers and its a lot of hard work to look them up in the books.
    Maybe put up some pics of the parts (which I know is a lot of work)
    What do you want to do with these parts? are they for personal use or do you wish to on sell them?
    Regards Col
    1973 Alpine A110
    Jun 2017
    Victoria
    34
    I have way more parts than I need, but equally I don't know yet what l need and what I don't. Catch 22...
    Jun 2017
    Victoria
    34
    Any clues on this?
    Brisbane/Australia
    2,051
    Might be an R16 but can't read the number.
    Boonah Qld
    2,525
    Measure the piston hole size that will tell you which cc capacity 807/44 etc engine it is off. My guess just by greater numbers is R16 but could be R15/17TL or 17G.
    Feb 2001
    Romsey, Victoria, Australia
    4,822
    Hey all,
    Cheers, one.four
    Where in Vic are you? I have parts books for most 70's Renault you can borrow in you need them. I'm in Airport West or Romsey.
    David Cavanagh
    03 9338 8191 or 03 93354008
    34 KING St
    AIRPORT WEST
    VIC 3042
    [email protected]
    Jun 2017
    Victoria
    34
    West Gippsland ... I do occasionally have to go out to Tullamarine, so could theoretically swing by.
    10,768
    That's the best way. Take a list and sit down in David's office for a while.
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
