A110 Steering Wheel Hub Size Question
Results 1 to 9 of 9
    Fellow Frogger! nauli's Avatar
    Oct 2017
    Perth, WA
    321
    Default A110 Steering Wheel Hub Size Question
    I'm going for a slightly larger steering wheel on my A110, but I believe that there are two different shaft diameters for the steering column shaft...18mm or 20mm?
    Mine appears to be the smaller diameter. I measured it at the top of the shaft and it appears to be about 17-18mm, but certainly not 20. But I assume they are tapered, so my question is does the correct size refer to the top measurement when sourcing a hub?
    1969 Alpine A110
    4,366
    I think you also need to consider the splines - number of; coarse or fine.
    There is a difference between R8 and R10 columns and hence they need a different hub.
    I suspect you have an R8 column, but you would need to check - assuming you are looking to buy or change hubs.
    Edit - I re-read your post in greater detail. I would think the diameter would refer to the thickest part of the shaft. Could you not just use your existing hub and transfer the new wheel onto it? Those sports wheels mostly use a pretty universal 6 screw bolt pattern.
    KB
    Oct 2017
    Perth, WA
    321
    Re your edit....yes indeed, the plan was to use the existing hub, which theoretically is universal....BUT...it appears not to be strictly so. I made all the appropriate measurements....the new wheel has the universal 60mm centre but it looks like my hub is probably about 61! Furthermore only 4 of the 6 mounting holes line up correctly...the other two are slightly off centre. I noted that the 6 holes on the current wheel appear to have been made slightly eccentric to fit the (dodgy?) hub. So therein lies the issue!
    The new wheel probably can be massage-engineered to fit, but I would prefer a perfect fit...
    1969 Alpine A110
    COL
    COL is online now
    A110 COL's Avatar
    Van Diemen's Land
    4,031
    Hi Nauli
    This link may help you with the sport steering wheel PCD's
    Steering Wheel Hub Patterns | GTSparkplugs
    As far as Renault steering column spines sizes go R10, R12, R15, R17, Feugo are all the same size. The R8 steering column is larger.
    I'm not exactly sure of what the exact measurements are.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    Oct 2017
    Perth, WA
    321
    Hi Nauli
    Thanks Col....I think the way forward will be to drill a fresh set of mounting holes in the existing boss....
    Both my old and new wheels are 74mm PCD, but (for reasons unknown) the current boss is very slightly different.
    1969 Alpine A110
    10,769
    I'd go and see Geckoeng....
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
    Oct 2017
    Perth, WA
    321
    I've already quizzed Ray! But I have a plan to try....
    1969 Alpine A110
    COL
    COL is online now
    A110 COL's Avatar
    Van Diemen's Land
    4,031
    Quote Originally Posted by nauli View Post
    That sounds like a plan, just drill and tap them in between the existing holes.
    There are many bosses that have both the 70mm and 74mm PCD.
    I made my own adapter https://alpine-a110.weebly.com/steer...k-release.html
    Regards Col
    1973 Alpine A110
    Oct 2017
    Perth, WA
    321
    Cheers Col....will see how it goes!
    1969 Alpine A110
