Building an extractor for C2J(R5 ts) engine in R8
Results 1 to 19 of 19
Like Tree11Likes
  • 5 Post By Frans
  • 2 Post By potentz
  • 1 Post By Thierry
  • 3 Post By Frans
Thread: Building an extractor for C2J(R5 ts) engine in R8
    Nov 2011
    Norway
    60
    Default Building an extractor for C2J(R5 ts) engine in R8
    I thought I should build an extractor to go with my planned ITB inlet.
    I have a pair of extractors from Opel(Vauxhall) with 2,0L XE engine that I though would be good for parts.
    The question is wether to just make up a new flange and modify one of them as mutch as needed to fit the engine and the car. Or just look at them as pipes, bends and collectors and try to build it as close to ideal as possible.
    The primaries are 36x1,5(33mm ID) about 33-36cm long. Secondaries are 41x1,5mm(38mm ID) that is about 40cm long. Far from ideal but still far better than what is bolted to the engine originally. The inner ports is of course too far from each other. The outer a bit too close.
    Building an extractor for C2J(R5 ts) engine in R8-dsc_0236.jpgBuilding an extractor for C2J(R5 ts) engine in R8-dsc_0237.jpgBuilding an extractor for C2J(R5 ts) engine in R8-dsc_0223.jpg
    I havent done any calculations myself but I see the what is usually suggested for a 4-2-1 for similar engines is about 60cm primaries and 30cm secondaries.
    Any thoughts?
    1000+ Posts Frans's Avatar
    Auckland
    1,491
    Hi Reidar,
    I have a love for extractors and some experience of the effectiveness of a correctly calculated one. There are a few horsepower locked away in it. The advantage of having a good calculated extractor is that you can have a very hot cam in the car with matched carburators and it will be almost as driveable as a car without a hot cam. I can prove this and take a look at my last post in "2 new racecars in NZ" then you will see how driveable my race car is with a wild cam and good extractors. An AFer on here has followed my Spreadsheet and I hope he sees this and could maybe confirm his experience as well.
    I have an Excel Spreadsheet that I made to do this calculation because it is about 2 or 3 pages of calculations if you do it by hand. What I am trying to say as well is that if you are going through with the trouble of making one, then you might as well do it the right way. The calculation takes into consideration the exhaust lobe position on the cam the rpms where you would want it to work to it's optimum, the speed of sound etc..
    This formula dates back to the 90's when I worked the formula into the spreadsheet. It is one from a race engine builder in USA with hundreds of hours on the Dyno to prove the results.There might be other ideas by now and it is for a 4 into 1 only.
    I will help with the spreadsheet if you want. Here are a few pictures of the race car extractors that I built at home by buying bends and welding them together to get the correct lengths.
    This is for a crossflow G head but it will look the same for your head and I see you have the good type head.
    Regards, Frans
    JoBo, ReidarUF, PeterT and 2 others like this.
    Old enough to know better
    Young enough to do it anyway.
    Nov 2011
    Norway
    60
    Hi Frans.
    I've studied your extractor and also the calculations for it from the spreadsheet. I thought it might build something similar for another engine based on R5 Alpine witch I have a pretty hot camshaft for.
    The C2J are probably not going to be that hot but it would still be fun to dial in the numbers in your spreadsheet to see how it turns out.
    I'm not too keen on putting four metres of primaries in the back so I would prefer a 4-2-1. Is your spreadsheet usable for that? I remember Ross building a really nice one for his Dauphine.
    Fellow Frogger! potentz's Avatar
    Jul 2011
    adelaide australia
    308
    Default tuned length extractors
    yes,i used Frans calcs for my 4 into 1 setup.really works well throughout the rev range.good idle and drivability is great.
    highly recommend this .
    Attached Thumbnails Attached Thumbnails Building an extractor for C2J(R5 ts) engine in R8-20150218_193521.jpg   Building an extractor for C2J(R5 ts) engine in R8-20150217_143126.jpg
    ReidarUF and bowie like this.
    Member Thierry's Avatar
    Feb 2015
    Central coast
    32
    Thanks for sharing, Im going to be dreaming about extractors tonight, would love to be able to make a set .
    bowie likes this.
    Dec 2010
    Blackburn Victoria
    474
    All good to make your own, but you know you can buy a set off the shelf from Mecaparts??
    (R5 in R8 or A110)
    Nov 2011
    Norway
    60
    Mecaparts dont have extractors for my engine. Actually I havent been able to find extractors for C2J engine in R8, only for R9/11.
    When speaking of Mecaparts and Autobleu who produce their extractors they have many designs from short 4-2-1 similar to my two opel/vauxhall ones to quite long 4-1. Their 4-1 still seem quite a lot shorter than those built after Frans calculations. A compromise I guess.
    Arne Berg is a well known(in Scandinavia and Finland) Renault tuner in SWeeden. Some time ago I got a drawing of his extractor design.
    A 4-1 with primaries similar to those on my Opel 4-2-1...
    Nov 2011
    Norway
    60
    I just got Frans spreadsheet. I put in the data and came up with this:
    Building an extractor for C2J(R5 ts) engine in R8-screenshot_20180307-104217.jpg
    I think I Will have flanges cut at the local mechanic scool to save some work. Will probably have two or more cut in case I'll try different designs.
    7,448
    I'd be interested to hear how it compares with this online calculator, which is based on the formulas in Graham Bell's book.
    Exhaust Calculator - Time in the Garage
    Nov 2011
    Norway
    60
    I gave it a go:
    Building an extractor for C2J(R5 ts) engine in R8-screenshot_20180307-133559.jpg
    Building an extractor for C2J(R5 ts) engine in R8-screenshot_20180307-133607.jpg
    Seems strange to me. For a 4-2-1 it calculates 37" primaries but on 4-1 it simply states they should always be 15". Did I get this all wrong?
    Feb 2012
    Vista SA
    986
    Default Exhaust calculations ?
    So Guys, where does this leave me??
    A 16TS 1655cc engine sporting 2 x 45mm Side drafts, a cam and light head job.
    I'm wondering if the extractors that came with it are no good???
    Attachment 104301
    Any comments would be appreciated.
    Phil
    1,701
    A of of us will be interested, love to make a good set too for a hotted up cam.
    307 HDi wagon
    407 HDi wagon
    7,448
    Quote Originally Posted by ReidarUF View Post
    I gave it a go:
    Sorry, I haven't had a chance to get back to this. Attached is the diagram from the book. In the case of a 4-2-1, P1 should always equal 15". ie P = P1 + P2
    Thus both got 1.24" and 37" or 37.12" primaries, for a 4-1. I doubt you'd pick the difference. Looks identical to me.
    Attached Thumbnails Attached Thumbnails Building an extractor for C2J(R5 ts) engine in R8-expipe.jpg
    Nov 2011
    Norway
    60
    Yes that seems more reasonable.
    So for the 4-1 the the dimmensions are pretty mutch the same as with Frans spreadsheet.
    According to Fiat guru Guy Croft the old rule about short primaries and long secondaries on a 4-2-1 is out dated. That the results are better the other way around.
    Ipswich, Queensland.
    1,895
    Attachment 104301
    Phil
    Given the modification the previous owner has done to your R8, I doubt the pipes are too far wrong. Looking at the pics they look to be about 1.5" and 36" or so long. All will be fine. With a reasonable cam and compression it should make 115 Hp at the wheels at a bit over 7K.
    '56 Renault 750 (16TS Power)
    '62 Renault Dauphine Gordini
    '08 Renault Megane sedan
    Nov 2011
    Norway
    60
    @Potenz: I just realised you had the same engine(or head) as me. Whats other mods have you done?
    I made up a drawing today to bring to the local mechanic school to have them make up two or three flanges. Where inlet and exhaust share the bolts i will leave the material till after welding.
    Off cource they would prefer a cad file...
    Feb 2012
    Vista SA
    986
    Thanks Alan.
    Wow!! that will be interesting, 7K !! Hmm, might be a while before I try those revs on a recon engine. Hope to run it it for a few months before trying the power. Poor little late model R10 gearbox !! best take it easy I guess.
    Phil
    Auckland
    1,491
    Phil,
    Run it in on the track!! Get it fit quickly. Coaches don't take it easy on players.
    Frans.
    FIVEDOOR, bowie and potentz like this.
    Feb 2012
    Vista SA
    986
    No way Frans. I need to have some fun in this baby before I cane it and probably blow it up Ha ha ha Phil
    Phil,
    Frans.
