R10 Side Draft Linkage
Results 1 to 11 of 11
Like Tree6Likes
  • 2 Post By R10S FAN
  • 1 Post By renault8&10
Thread: R10 Side Draft Linkage
    Fellow Frogger! R10S FAN's Avatar
    Mt Barker S.A.
    390
    Default R10 Side Draft Linkage
    Hi Brains Trust,
    In the final stages of fitting a 40DCOE on my 1397cc equipped R10. Does anyone have any suggestions or pics of their linkage setup? Not overly keen on one of the over carby setups but will consider as a last option!R10 Side Draft Linkage-1520217759542.jpgR10 Side Draft Linkage-1520217770913.jpgR10 Side Draft Linkage-1520217784856.jpg
    Sent from my SM-G935F using aussiefrogs mobile app
    J-man and LeMansTragic like this.
    Current Frogs:
    1964 Renault 8 (1289 / Sonics)
    1968 Renault 10 (Modified 1.4L Alpine White)
    1000+ Posts Frans's Avatar
    Auckland
    1,492
    This has nothing to do with the linkage, there might be many ideas. My question/warning is that I hope you have some PCV valve in the breather line. If not it will smoke like hell and suck the oil splashes in the rocker cover directly into the combustion.
    Frans
    Old enough to know better
    Young enough to do it anyway.
    4,367
    If you took all those extenders off, wouldn’t the original Y piece bolt onto the original spring mount that appears to be there on the extractors. Mine had a similar setup and just used the std spring.
    Attached Thumbnails Attached Thumbnails R10 Side Draft Linkage-detail.jpg   R10 Side Draft Linkage-kbr10engine.jpg   R10 Side Draft Linkage-dscn1544.jpg   R10 Side Draft Linkage-dscn1304.jpg
    Sunroof likes this.
    KB
    Fellow Frogger! potentz's Avatar
    Jul 2011
    adelaide australia
    308
    and use a better quality linkage.get rid of the plastic.
    4,367
    Both of those are genuine Renault parts. I’ve broken one in 30 yrs, which was my fault as I bent it the wrong way taking it off onetime.
    Ironically, I ended up with a full metal aftermarket one on the “concourse car”; and the original plastic one on the white R10 (and the new R8 when ready).
    JohnW likes this.
    KB
    Fellow Frogger! nauli's Avatar
    Oct 2017
    Perth, WA
    321
    Not sure if this helps, but this is the 40 DCOE setup on my A110
    Attached Thumbnails Attached Thumbnails R10 Side Draft Linkage-20180305_162558_resized.jpg   R10 Side Draft Linkage-20180305_162624_resized.jpg   R10 Side Draft Linkage-20180305_162610_resized.jpg
    1969 Alpine A110
    10,769
    You must have worked hard to break it!!! I thought they were made of indestructibium. I've always wondered how they made them so strong.
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    Citroën CX Pallas 1980
    Feb 2005
    rosevale/tasmania
    2,747
    As you'll see, mine is indeed one of the dreaded "over-carby" set-ups. The cable from the front does a right angle turn to rise vertically on the front side of the Weber & work the pivot. To accommodate that right angle turn, we used a largish diameter wheel sourced from a marine supplier.
    Works fine.
    cheers! Peter
    634
    Quote Originally Posted by R10S FAN View Post
    Hi Brains Trust,
    In the final stages of fitting a 40DCOE on my 1397cc equipped R10. Does anyone have any suggestions or pics of their linkage setup? Not overly keen on one of the over carby setups but will consider as a last option!Click image for larger version.
ID:	104219Click image for larger version.
ID:	104220Click image for larger version.
    I can't quite see it (possibly the angle of the photos) but if you intend to track the car at any CAMS endorsed event, you will need a 2nd spring set up (in case one brakes - so the throttle remains shut) as the scrutineers will pull you up on this.
    Angelo
    Dec 2004
    749
    webers already have a spring in the side of the linkage thus not requiring another.
    LIFES TOO SHORT TO DRIVE BORING CARS!
    Mt Barker S.A.
    390
    Thanks for all your suggestions guys, i'm in the final stages of making my own linkage so i'll post some more pics once it's finished!
    bowie and J-man like this.
    Current Frogs:
