Koleos rear lower tailgate not opening
Results 1 to 8 of 8
    Feb 2018
    5
    Icon8 Koleos rear lower tailgate not opening
    Hi
    Can anyone help me.. my lower tailgate will not open, it looks like the cable or locking system has broken but I cant get the internal trim off while the door is closed. I also cannot get it open and was wondering if someone knew how to either open the lower door, or how to remove the internal trim while still closed.
    I tried removing the receivers on the side by taking out the 3 bolts, but the bracket cannot get past the side trims.. hope this makes sense.
    Many thanks
    8,398
    A common problem. There is a write up in the common faults thread.
    #338
    Koleos Hints, Tips, Problems
    Feb 2018
    5
    Hi,
    I read those, but I wasnt clear on how to remove the internal panel while the bottom tailgate is closed.
    It seems to be clipped in & I can get some of the lugs out, but not at the bottom, so the panel is hard to move without fear of breaking. I too tried the side plates with the 3 bolts.. but couldnt get them out.
    Oct 2005
    vic
    848
    Default How to release Koleos lower tailgate after latch failure.
    Its been a while now.
    If my memory serves me correctly, I prised off the upper part of the lower tailgate inner-skin and then manually released each side of the lower gate manually.
    My recommendation is to leave everything intact until you have a new replacement SET (both left & right side) to fit.
    Not hard.
    In the future:
    Remember to not slam the lower panel shut - just latch it into place and then press closed.
    Feb 2018
    5
    Thanks, I've booked it in to the garage tomorrow & they can take it off & leave it off untill I go to the wreckers (Cant afford new ones), a 'friend' closed the bloody thing hard.. would love to send him the bill
    8,398
    Quote Originally Posted by nixy69 View Post
    I hope labour is not expensive, because this seems to be a common problem with a 'when, not if ' schedule of failure.
    In other words, if yours has gone, the one from the wrecker is probably not far behind. Just saying.
    Same goes for any of those common fault items….. like sun visors.
    Jo
    Feb 2018
    5
    decided to bite the bullet & let the garage do it... both catches had broken & cost me $850 ouch!!!
    Oct 2005
    vic
    848
    Yes ouch.....
