R17 Gordini Clutch & Flywheel
Results 1 to 11 of 11
Like Tree3Likes
  • 1 Post By 3006882
  • 1 Post By COL
  • 1 Post By superfred
Thread: R17 Gordini Clutch & Flywheel
    Jun 2004
    396
    Default R17 Gordini Clutch & Flywheel
    I don't have the box out of the car at the moment so can't do any measurements, but can anyone confirm the clutch diameter on the 807 engine/365 box combo, is it a 215mm or 185mm?
    Mecaparts has their horrendously expensive kits listed as 215mm, but I have also come across 185mm kits.
    Also, has anyone had any experience with the TTV lightened flywheels? They have a 185mm one listed for the Alpine A110 1600, so presumably the same as the 807 engines from the 17's.
    R17 Gordini Clutch & Flywheel-ttv-lightened-flywheel.jpgClick image for larger version.
Name:	TTV lightened flywheel.jpg
    Simon's Avatar
    6,162
    For a stock 844 motor out of an R1317 17TS/G, it is a 215mm clutch, so just check what clutch your 807 motor is.
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,031
    I'm not sure if this is going to confuse you or help you.
    I have just measured the clutch diameters of 807 engines that I have here and they measure up at 200mm.
    I have a clutch plate here that is marked R12 sedan/wagon and it measures up at 185mm.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    Oct 2012
    600
    I thought the R12 had a 180mm clutch. I'm currently attempting to to see if TTV has a flywheel suitable for my K4M install.
    Sent from my Nexus 6P using aussiefrogs mobile app
    4,367
    1.4’s were 180; 1289’s were 170mm I believe. The 1108’s were 160mm.
    KB
    10,769
    R10 1300 is definitely 170 mm as I've just measured it. And yes, 160 mm for the R8 1100 and I think ALL earlier RERs. Adequate for the 4CV obviously....
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
    Jun 2004
    396
    I guess I should go with the "go measure it" approach when I pull the box for a rebuild
    bowie likes this.
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,031
    Quote Originally Posted by 3006882 View Post
    Have a look at the engine & gearbox code and you will probably have a guess at what it is.
    Its either a 200mm or a 215mm.
    But to be 100% sure the measuring it is the way to go.
    Simon likes this.
    Regards Col
    1973 Alpine A110
    Maldon
    153
    I have just installed a complete Valeo clutch kit in my R12 Gordini replica, 807 motor, 200mm driven plate. sourced from Ken Bailey - just under $200 plus freight. Should be the same as R17. Give him a call 0400 566119.
    Cheers, Fred.
    bowie likes this.
    Fellow Frogger! Jensen's Avatar
    373
    Agree, talk to Ken. From memory, a 17TS/G uses a 16TS clutch plate, Fuego pressure plate and 17 throw out bearing. I may have got the pressure plate/clutch plate combo the wrong way round.
    2002 Monaco Blue Renaultsport Clio 172
    1975 R1317 Renault 17 Gordini
    Jun 2004
    396
    Quote Originally Posted by Jensen View Post
    That combo does actually sound familiar, I think I've read it somewhere before.
    Thanks to the knowledge bank again
