Smoothing a 12 Ts Inleft Manifold? - Page 2
Page 2 of 3 First 123 Last
Results 26 to 50 of 70
Like Tree27Likes
Thread: Smoothing a 12 Ts Inleft Manifold?
  1. #26
    1000+ Posts bowie's Avatar
    Aug 2002
    Sydney, Concord City, Sir.
    3,169
    oh you reminded me!
    I stumbled upon this link the other day which is a link to Vizards "How to Port & Flow Test Cylinder Heads"
    https://www.google.com.au/url?sa=t&r...KzxMP5KMsRx9l3
    Enjoy everyone
  2. #27
    May 2011
    50
    Default None of this is new!
    Bowie, get yourself a copy of David Vizard's book on heads and stuff.
    In the late 1950s and early 1960s, Laurie Oxenford had a good business doing 'Oxenford Conversions', particularly for Simca Arondes but also for Dauphines and lots of other cars.
    He claimed an increase from 48hp to 65 hp for a Simca Aronde. His process involved porting and polishing, head shave, a bit more spark advance and a few other minor tweeks. His claimed increases were probably a bit optimistic, but it did work fairly well!
    JohnW and bowie like this.
  3. #28
    10,259
    There are two easily found:
    https://www.amazon.com/Theory-Practi.../dp/0851130666
    Theory and Practice of Cylinder Head Modification (The MRP speedsport series) [David Vizard] on Amazon.com.
    AND
    David Vizard's How to Port & Flow Test Cylinder Heads (S-A Design ...
    https://www.amazon.com/David-Vizards.../dp/1934709646
    I quote: "It takes a craftsman's touch to shape the surfaces of the head for the optimal flow characteristics and the best performance. Porting demands the right tools, skills, and application of knowledge. Few other engine builders have the same level of knowledge and skill porting engine heads as David Vizard."
    Right out of my league but they look really interesting.
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
  4. #29
    Mar 2013
    olinda victoria australia
    613
    This looks good- focus on simplicity and basic principles
    Already well into it ( Reg, the 4CV, needs all the help he can get )
    Many thanks
    Andrew
    oh you reminded me!
    Enjoy everyone
  5. #30
    Aug 2002
    3,169
    Well having worked out what material can be re-leaved, (I used a combo of the oil and paper and blowing talc) i marked it up and started sanding away.
    The unmolested side,
    The molested side,
    already looks faster
    You can see the scratch mark on the side indicating there is still a bit more to go. I'm going to focus on the inside of the runner and try to smooth that corner out as much as I can without poking out the other-side, then open it up probably a 1~mm or so before I start on the head. And don't worry about the scratch marks on the surface, I'll get that planned along with the head.
    It actually is smoother then it looks, but it can still be smoothed over with a fine metal spinning disk. I'll do some more reading before I debate if it's worth just removing the port separators aka like some Perrie manifolds did.
  6. #31
    1000+ Posts geckoeng's Avatar
    Perth, WA
    1,527
    "bowie"
    You are getting the idea. Now try and get the ports to flow (blend), pinch ideas from the pages you read. I read American Hot Rod and Drag articles, from the '70s and '80, on working with motors. They used to explain flow (blending) very well. Now people only want to sell their product so there is far less information given.
    Go For It ....... !!!
    Ray
    JohnW and Shoji like this.
    Ray geckoeng
    Think Old, But Run Modern !!
  7. #32
    10,259
    "bowie"
    You are getting the idea. Now try and get the ports to flow (blend), pinch ideas from the pages you read. I read American Hot Rod and Drag articles, from the '70s and '80, on working with motors. They used to explain flow (blending) very well. Now people only want to sell their product so there is far less information given. Go For It ....... !!! Ray
    Must have a chat Ray, regarding 32DIS carbies and those right angled manifolds......
    Renault 4CV 1951
    Renault R8 1965
  8. #33
    Perth, WA
    1,527
    Any time John .......... !!!!!!
    Ray geckoeng
  9. #34
    8,428
    Be careful with the mouth of the manifold Bowie. You don't want to create a step between manifold and head such that the flow bangs into it (large on the manifold side). The other way around it's fine (head larger than manifold). Even if there is a negative step on part of the joint it is still detrimental, so make sure you either locate the manifold to the head perfectly so it can't go in any other position, or leave the manifold slightly smaller so you have a positive step all the way around no matter how much the manifold can wiggle around.
    Read Vizard's book and then on to carbies and read John Passini's book.
    jaahn likes this.
    ACHTUNG ALLES LOOKENPEEPERS
  10. #35
    Aug 2002
    3,169
    Yes I'm gong to smooth out the other-side of the manifold, then start on the inlet ports on the head, I'll take about 2mm off, and then re measure everything once more again.
    There is a surprising amount of meat here actually.
  11. #36
    8,284
    A tool tip…Get a small flapper tool, epoxy (or just crimp) it into a push bike brake cable outer, and use this in a drill.
    You can then push/pull this through your pipe over and over and it will naturally seek out the high points and leave the troughs untouched.
    Those brake cable outers make great low stress rotary tool bit extensions.
    Jo
    COL, bowie, FIVEDOOR and 1 others like this.
  12. #37
    8,428
    There are ready made flexible cable extensions that will take a flapper wheel. The trick is to find a flapper wheel of the right diameter, because you need it to contact all the way around its circumference, otherwise it will skip around like crazy.
  13. #38
    Aug 2002
    3,169
    Well slow progress, I took the interior lump out of the other runner to match them up, and started blending in the plenum. I hit everything with a shiny disc so I could clearly see how good/bad it's looking.
    I still have to focus on the inside of the runners and make that line as straight as I dare. It's probably hard to see, just where the runner starts to bend, there is a cylinder about 3x3mm just hanging out in the middle there, yeah it's going.
    The plenum is really really thick. I suppose it was thick to act as a pseudo heat shield? Anyone one could cut 5mm into the floor without any problem. I'm going to blend everything into the floor of the runner, and try to keep a little bit of a ramp in the middle as Renault did before me. I'm also going to focus on the inside edges and blend that corner out as much as I can, Everyone loves straight lines.
    Slow work, but strangely rewarding. This is also great practice before I go near the head
  14. #39
    Aug 2002
    3,169
    Well each runner (where it met the head) was previously 25~mm they are now sitting at 30mm
    This is probably enough for the moment,
    I've spend a great deal of time taking material from the floor, walls and roof so it's looking fairly consistent. I feel like there is still more to do to take the corner out of the runner, I'm still worried about blowing out the side and ruining everything.
    Also, talk to me about that coolant chamber that runs via the inlet manifold. This is to assist with cold starting and not in any effort to keep the intake temps down right?
    This is fun
  15. #40
    Perth, WA
    1,527
    The coolant passages in the manifold are there to keep the mixture vapourised when it is cold outside. I have used a small inline tap for warm race days, to keep the inlet air as cool as possible. The tap also needs to control the coolant through the heater plate under the carb. But when using the car on the street, in particular at night, the manifold needs to be warm to stop icing of the mixture, in particular the carb itself.
    Ray geckoeng
  16. #41
    10,259
    I thought that coolant flow was to avoid icing up, i.e. heating things up at high airflows.
    Renault 4CV 1951
    Renault R8 1965
  17. #42
    Simon's Avatar
    6,085
    It'll be interesting to see how it goes. I would have though enlarging the volume of the manifold, with everything else stock, wouldn't work. The mixture once through the carby slows down when it gets to the enlarged manifold, excessive fuel consumption and less go.
    I found matching the ports, and a balance (although they seemed good from the factory according to the place that did the balancing) was a decent compromise. The old 1289s just seemed to sing!
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
  18. #43
    Aug 2002
    3,169
    I plan to eventually fit a silly cam, silly cam springs, and valves as big as suitable. This is just all the easy prep before hand.
    But really, after all this it's not going to me much more then a matching port job really.
  19. #44
    Aug 2002
    3,169
    And I would have thought the proximity of the exhaust manifold would heat things greatly.
  20. #45
    10,259
    Latent heat of vapourisation of petrol..... It wasn't unknown for R12s or R16s to stop on fast runs in cool weather due to icing up of the carby throat. Or so I heard back then.
    Renault 4CV 1951
    Renault R8 1965
  21. #46
    Aug 2002
    3,169
    Ah true. So what fuel is a vapoiur at 23~ degrees. I suppose on cold mornings with a fast clip there would be enough air flow to bring that down despite the exhaust manifolds location.
  22. #47
    Aug 2002
    3,169
    Smoothing a 12 Ts Inleft Manifold?-1519044862217.jpgSmoothing a 12 Ts Inleft Manifold?-1519044870324.jpg
    These are the corners worth smoothing. Look! Daylight
    The plenum had the runner moulds removed, hot rod mags I've read (mostly about the straight 6 Holden Red engine actually, perhaps simply more was written about it) indicates free plenum volume is a good thing. It's actually still a little tapered there, the flash hides that.
    And the beginning of smoothing out / widening the track from the Webber to match the material removed from the rest of the runners.
    I haven't actually sat the 32/36 gasket on it to see what overlap in the airstream (if any) is there to remove. Added to the list.
  23. #48
    1000+ Posts Shoji's Avatar
    Jan 2012
    Mandurah WA
    1,001
    Hence the euro air ducting that starts at the exhaust manifolds that you see in the parts manuals and some photos I've seen on 12/17's in Europe. You would need warm air for the natural aspirated engines of the time in those conditions. Not so for Perth though. Almost no choke
    85Fuego likes this.
    ďListen very carefully, I shall say this only once.Ē Cheers. John
  24. #49
    Perth, WA
    1,527
    Only in the Snowy Mountains and parts of Tassie would you need a warm air duct to the air filter. And when running it hard in events, cold air is most preferable.
    As it is a daily driver, it needs to cope with general conditions first, and then be adaptive to racing conditions. Until it becomes a full time park in the workshop, race car.
    Ray
    Ray geckoeng
  25. #50
    Aug 2002
    3,169
    Well one grinding wheel down, it's starting to take shape.
    There is a lot of angles around the pushrod on the inside of the siamese that smoothed out nicely. I still have a lot of room to cut the floor and far wall, but I think I might just balance out the other inlet ports before I get to aggressive.
    Not going near the inside of the combustion chamber at the moment, (haven't read that far) and I'm just really trying to straighten out the air flow into the valve as much as possible, whilst increasing the volume.
    You can get an idea of the floor by the light in the second image, you can see the slightly larger area taking shape before the valve on the right, this is what I'm trying to enlarge
    Oh for those interested, standard port is 29mm x 29mm I'm aiming for a 31mm at most on the head, and 30.5mm~ on the intake manifold.. just ensuring a bit of blunder room really.
    I've managed to do all this with a big(ish) rotating stone on a dremel. Spraying it with WD40 every now and then it doesn't stick and is gong ok.
    Budget 1.5~hr per port with a small powered tool.
