Wonder if any AF knows of a diagram of the front end. I searched on the net but to no avail. Probably due to my lack of search skill.
Reason being that i want to fit proper sounding horns instead of the standard pissy one.
I asked at the last service (3rd) if they could fit it while the resealed the timing cover (had a very slight weeping showing). They could but @ $143.50/hr. so i gave it a miss and will do it myself.
A proper drawing would help a lot to avoid breaking any plasticy bits. E.G is the headlight only fixed with the two top bolts and has a sliding arrangement at the bottom?
The space available is rather tight and my double horns will just fit but i need good access. Going from underneath with the bottom plastic removed just isn't enough to do i properly.
