It seams like a lot of you have converted to electronic ignition of some sort. Some have even ditched the distributor for a modern coilpack and megajolt.
Why not just convert to EFI?
First I have to confess that not much have been done to my -64 R8 the last two years. Two small children(2 and soon to be 5 years)and moving to an oldish house in a rather rough state, not to mention the old barn and the ruin of boat house.
The lathe and mill are in bits and the welding machines on storage. But my head are bursting and the pile of parts are getting bigger....
I used to have a Peugeot 106 16v that I converted to gsxr throttle bodies and Vipec(NZ brand) mapable engine management. It gained about 20bhp and it was a lot of fun.
I plan to do the same to my R8. The original 1108cc engine is a five port and the gearbox have an input shaft like a knitting pin so I have a C2J engine from a late R5 TS and complete rear assembly from a late R10 1300 waiting to get in, hopefully for the summer.
The C2J have the inlet ports nicely spaced with about 45mm centre distance. To make the runners of the inlet as straight as possible I need to find paired throttle bodies with the same centre distance. Jenway make throttle bodies the same style as the weber DCNF carburettors withch have 48mm centre distance but they are quite expensive. Also I'd like them closer. Some of the Japaneese HD clones have nice dual throttle bodies but most of them have the inhectors in the inlet close to the cylinders. Witch means I would have to weld injector bungs in the inlet.
So theese days I look for throttle bodies from everything from old american cars to snowmobiles, outboard engines and jet skies...
