EFI/Individual throttle bodies on old renaults - Page 2
Page 2 of 3 First 123 Last
Results 26 to 50 of 61
Like Tree33Likes
Thread: EFI/Individual throttle bodies on old renaults
  1. #26
    Oct 2012
    600
    Quote Originally Posted by ReidarUF View Post
    @c.lees: I would deffinately convert to itb. And the paired gsxr ones should be a good choice. Sandy Brown in England have made a really nice setup for the Peugeot 106 16v/gti. He is using 1000/750 bodies but the 600 are basicly the same. The spacing on the pug is 90mm but as you see he have avoided spacing the bodies. I know from experience there is good reasons for that...
    Attachment 104114
    That is an interesting setup, do you know how they throttle bodies have been connected to the tubes? The only ones I've seen so har use silicon tubes to connect them as that is how they are connected on the bike.
  2. #27
    Nov 2011
    Norway
    60
    On the GSXR there is actually a rubber coupler/inlet with a vulcanised metal flange that is bolted to the cylinder head.
    There is a grove on the "tube" on the bodies for this coupler to not to slide off. On theese kits this groove is used as an O-ring groove. Its not perfect as such but seem to seal good enough in the holes in the flange. There is also small metal brackets that secures the bodies to the flange.
    I bought one of theese inlets second hand as I thought it was better than my own setup but I sold the car and inlet before fitting it. Anyway I plan to rob this design for another engine later.
  3. #28
    Jun 2004
    407
    I havent paied much attention to the second butterfly setup but I think Alan Moore sums it up pretty good. The gsxr itbs I used on my Pug 106 also had them but I just removed them and plugged the holes.
    What is interresting is the system to make them work in conjunktion with the main butterflies. There is a cam lobe on the second butterfly axle that works against an adjustable arm on the axle on the main butterfly axle. I think this adjustment can be made into a balance adjustment between the two bodies.
    Attachment 104045
    @3006882: Your setup looks good. Sometimes the dcoe bodies are just perfect. But I think you make it seem a bit complicated. Cam trigger is not really needed when running wasted spark and batch fire the injectors. And my 106 was idling nicely without any idle control other than some tweeks in the software.
    Well I'm certain I've made it more complicated than it needed to be, but I was partially doing it to teach myself EFI tuning, so I wanted sequential injection and ignition. The cam trigger turned out to be a fairly easy fix using an off the shelf aftermarket cam trigger unit from the US made for an air cooled VW EFI conversion that replaces the distributor and making a new shaft for it.
    I also have long term visions of a small twin scroll turbo on it, so the extra tuneability can't hurt.
    ReidarUF likes this.
  4. #29
    Aug 2011
    Bømlo, Norway
    71
    Working on the pattern for the inlet manifolds.
    After adding some bondo and details
    bowie likes this.
  5. #30
    Aug 2011
    Bømlo, Norway
    71
    Big step today as I did my first green sand casting. Pretty good I think but adjustments is needed to the sentre distance of the cores. Shrinkage was less than I though so the core tabs on the model is a bit too far apart. Also I´m not sure of the "trademark" RF. My full initials is RUF but thats allready taken. I´m thinking of RF8
    [IMG]118213[/IMG]
    [IMG]118214[/IMG]
    [IMG]118215[/IMG]
    [IMG]118217[/IMG]
    [IMG]118216[/IMG]
    Sunroof, COL, Shoji and 3 others like this.
  6. #31
    9,261
    Hey, not too shabby. Are you going FI?
    ACHTUNG ALLES LOOKENPEEPERS
  7. #32
    Jun 2018
    Alameda, CA
    19
    What are you using for your core material?
    Heres a manifold I made for my Simca 1000 a few years ago.
    Reidar likes this.
  8. #33
    Aug 2011
    Bømlo, Norway
    71
    @sclitzaugen: Yes, EFI. Not sure what system to use yet. I have an old South African one on the shelf but there is a new Sweedish system that looks promising. Maxxecu mini.
    @[email protected] identical project as mine but yours seems more elegant. Any pictures of it finished?
    My cores is paving sand with sodium silicate. I suspect yours is the same? And nice core box. Mine is a lengt of pvc pipe split in two.
  9. #34
    1000+ Posts bowie's Avatar
    Aug 2002
    Sydney, Concord City, Sir.
    3,515
    you guys forging your own parts.. Fantastic!
  10. #35
    9,261
    Casting.
    Forging is a bit beyond the home workshop:
    https://www.youtube.com/watch?v=Bzhi4kRBNHU
  11. #36
    Jun 2018
    Alameda, CA
    19
    Sorry, I missed your reply. Yes, sodium silicate is what I used.
    I wish I could say my molds were hand made, but I carved them on my cnc router.
    Quote Originally Posted by Reidar View Post
    Reidar, bowie and Renault Rod like this.
  12. #37
    Aug 2011
    Bømlo, Norway
    71
    @Godzilla: Real nice! Seems like you made your own throttlebodies too?
  13. #38
    9,261
    If you have a CNC router, why not make the manifold itself on it?
  14. #39
    Jun 2018
    Alameda, CA
    19
    I made the cnc router in college as a means to make casting patterns and cut sheet goods. As such, it wasn't very stiff and couldnt cut alu very well.
    Later, I did get an old Tape-drive Hurco KMB-1 mill and converted it to run on windows.
    I used that machine to make a manifold for a souped up Fiat a buddy has. It used a single throat of an IDF Weber.
    Sunroof, bowie, Reidar and 1 others like this.
  15. #40
    Boonah Qld
    2,603
    Love home made workshop equipment, your a clever guy. But I guess the professional machine does it better or would that be easier?
  16. #41
    9,261
    I see. That Hurco looks like it could do the job nicely though.
    If you look up This Old Tony's channel on youtube, you will find a brother in arms. I think he is now trying to do the same CNC conversion on a Maho mill (which was sort of CNC back in the seventies).
    Would be a hell of a project though to make a four throat manifold on a CNC, even an industrial one, let alone a home brewed machine. But hey, if it works, it would be worth its weight in gold.
  17. #42
    Aug 2011
    Bømlo, Norway
    71
    If anyone is wondering whats the point in using such strange parts for my project they can have a look here:
    https://www.ebay.co.uk/itm/06-15-200...8796%7Ciid%3A1
  18. #43
    Aug 2002
    3,515
    They really look perfect. That spacing is great.
    Looking forward to how these end up for you
  19. #44
    Aug 2011
    Bømlo, Norway
    71
    @Bowie: What is the port spacing on your engine? These bodies have 47mm SS while my C2J have 45mm SS. The core prints on my model can easily be alterred a few mm. The model is now nearly finished for a new test. 6mm narrower and about 7mm shorter.
  20. #45
    Aug 2002
    3,515
    Realy tight.
    Here you can see one port on the way with the other left. You can also see the scratch marks out the outside that would match the standard DGV weber manifold, but with the standard valve in it, there isn't much point in making the inlet port bigger then the valve (if I understand my books correctly)
    The port spacing on these heads is crap next to your C1J's (which we didn't get).
    I'm going to end up with ~30mm inlet ports and maybe a ~1mm wall between them... I figured I would use a shared wall between the two runners when making the V manifold. Thankfully, because the angle is relatively steep out to the bike carbs I'm using, it should work ok. I was planning on using 30mm dai steel pipe with a wall thickness of 1.2mm and then slice up the ends and flare it out to accept these ~38mm throttles. Alla, something like this;
    Yes the carbs are huge, probably to big, but they where cheap to experiment with, and the kawasacki spacing doesn't really change much, and they flow similar to 45 DCOE's or said this chap I found who measured them. If i's crap a set of 600cc carbs will be fine. A success will be if it only makes power between 5k-7k by the time I get silly cam in it. So not to precious about it.
  21. #46
    Aug 2002
    3,515
    Those Vulcan carbs however.. perhaps that is my plan B.
  22. #47
    Aug 2011
    Bømlo, Norway
    71
    Looks like a challenge making a good four port inlet for that head. The flange will have to fit perfect with no play. I guess a few dowels would be an idea. Also you might also have to glue the manifold on to ensure no leak between 1-2 and 3-4.
    I guess those carbs are a bit on the big side. Size are more critical on carbs than on throttle bodies as they require better fliw to work properly.
  23. #48
    Aug 2002
    3,515
    yeah... sealing is going to suck.
    But enough about my mess, sitting tight for more news about your craftsmanship!
  24. #49
    bob
    bob is offline
    May 2001
    Skipton
    2,496
    G'day,
    .......I guess those carbs are a bit on the big side. Size are more critical on carbs than on throttle bodies as they require better fliw to work properly.
    but don't be afraid to experiment with bigger....
    In an earlier life I had a Standard 10 [about 1 liter, 4cyl for the newer generation] that had a tiny Solex, this was initially replaced from the junk pile by a dual barrel unit from side valve Ford V8 - dumping both barrels at once. No problems at all, bit more go of course, and better economy !!
    This motor ended up with dual 1.5" SU carbs on a factory manifold produced for the Triumph Spitfire - part of a transformation exercise with the bores ending up 3/16" or so apart, compression around 11.5 and a big overlap cam. It went rather well....
    cheers,
    Bob
  25. #50
    Boonah Qld
    2,603
    Renault R12G, R1063 etc. Always had massive carbies for the capacity of the engine. Weber recommend maximum of 2 X 40 mm DCOEs (4 barrels) for 1600 cc. Where as Renault fitted two by 45 mm DCOE carbs. The difficulty is getting the correct sizes for the various bits that can be changed.
