The little Flea from Hell
Results 1 to 7 of 7
Like Tree9Likes
  • 9 Post By Mike Tippett
Thread: The little Flea from Hell
    1000+ Posts Mike Tippett's Avatar
    Jan 2002
    Vancouver Island, Canada
    1,712
    Default The little Flea from Hell
    An old friend of mine built this car up for track racing and occasional street use back in the mid-1980s. The rear guards were professionally widened with steel to accommodate the 215 section rear tires; the fronts were left alone as the wider wheels are offset to the inside.
    The engine as you can see is from a R1135, however, it is equipped with the Alpine 1296 kit, so it has 120 HP at 7200 RPM. The transaxle is 8 Gordini 5 speed with tall final drive. The radiator is from a Golf and has a powerful electric fan. The muffler is transverse and squeezed in between the engine pulley and the rear panel. Transmission and engine mounts are hardened Group 2 items. The twin shock 1135 rear end would not fit in the shell but a single shock R-8G crossmember was used, which only required minor modifications to the inside of the shell.
    I had a ride on the street in this car and it was raucous. The car is so fast with its Porsche Cayman power/weight ratio that each gear can only be held for just over a second up to third, under full bore acceleration. The car's buzzy inside due to the hard mounts. So not really a pleasure to drive, but a whole bundle of fun. The wheels are widened steel which normally wear hubcaps and to the untrained eye it looks much like a stock 21 HP 4CV.
    It was mainly built as a track car and when the Westwood racetrack near Vancouver shut down in the late 1980s, this car was mothballed and sits under cover. Breakable bits were removed and are stored indoors.
    Kim Luck, J-man, lozenge and 6 others like this.
    1966 Peugeot 404 Coupť Injection post-restoration reassembly underway!
    Register your 404: https://recensement.leclub404.com/submit.php
    1000+ Posts Dano's Avatar
    Apr 2012
    1,072
    Love a wolf in sheep's clothing...
    Simon's Avatar
    6,162
    That's a ripper conversion! Those guards have been executed perfectly. And I like the crank handle hole in the front bumper just to cause further confusion :-)
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
    Apr 2012
    1,072
    Well spotted Simon...
    Reminds me of when the ex owned an Renault 10. She was loading the groceries into the boot/front. And this guys wonders over and sheepishly asks, were is the motor?
    Fellow Frogger! lozenge's Avatar
    Castlemaine
    493
    terrific! this is what I call a real car. thanks Mike for sharing.
    Mar 2013
    olinda victoria australia
    696
    That's why it's so fast - a motor at each end. Can't let CitroŽn be the only one
    My "poverty pack" 1960 4CV has crank holes in both ends, presumably to save cost of tooling for two separate bumpers
    Andrew
    Member Thierry's Avatar
    Feb 2015
    Central coast
    32
