Where can I buy a R10 New Top Radiator Hose & Thermostat?
Results 1 to 15 of 15
  • 1 Post By R8 Dream
Thread: Where can I buy a R10 New Top Radiator Hose & Thermostat?
    Fellow Frogger! Gordini Pervert's Avatar
    Mar 2012
    Perth
    194
    Icon5 Where can I buy a R10 New Top Radiator Hose & Thermostat?
    Hey Aussiefrogs members...
    Im after a top hose and thermostat for an R10 - where can I buy one please?
    Ebay is a bit sh*t and doesn't give me dimensions
    specifically
    • water pump side diameter OUTER: 44mm
    • Radiator side pipe diamater OUTER: 38mm
    thanks in advance!
    610
    As a first, try locally Parts of France (Ken Bailey) on 0400 566 119 (formally Caravelle Motors) Melbourne
    Failing this the usual suspects for o/s : Catalogue ALPINE RENAULT, https://www.franzose.de/en/Renault/ etc
    HONG KONG PUGGY likes this.
    Mar 2012
    Perth
    194
    thanks so much!
    I also found this thread Radiator Hose ID - RENAULT 4CV DAUPHINE GORDINI CARAVELLE LATE SERIES
    which found this supplier: About Us - AutoSiliconeHoses.com - Silicone Hoses
    did you have any luck with them @R8 Dream?
    610
    Yes Ken is very good local supplier, but does not carry a lot of 'old stuff' mainly consumables ie oil filters, bearings etc
    Franzose - have not used them yet.
    As for Mecaparts, we are on first name basis!
    10,369
    Melun Retro Passion, Bretagne Auto Retro, Ichard, Neo Retro, Mecaparts..... They are pretty standard products. The early Sierra-engine cars, like my R8, had a smaller top hose diameter and look smaller. Those smaller ones weren't fitted on the R10 AFAIK.
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
    Nov 2002
    Yarrabilba, Queensland
    2,753
    Agree, try Ken first, last and always for older French Cars parts.
    In over 30 years of French Car ownership, Ken has always been the go to for me firstly since my R17.
    I'm constantly perplexed by anyone who says........"eBay is shit" WTF, ebay is just a sales tool for things and should be the last place you look for any French car part unless you pretty much have a part number or if you are buying a second hand part which you know is right.
    Sorry, just my opinion.
    Previous
    2001 Rx-4 Privilege
    R17TL, 1973
    R20TS x 3
    R18 GTS wagon x 2
    R10
    610
    Quote Originally Posted by Gordini Pervert View Post
    specifically
    thanks in advance!
    Found this on ebay?
    Gates Thermostat FOR RENAULT 10 119_ (TH01483) | eBay
    https://www.ebay.com.au/itm/Renault-...4AAOSwxKtYBXj1
    18,043
    Have a look at mackay online catalogues.
    Catalogues | Mackay Consolidated
    You may find the correct hose, or simply a very close equivalent.
    Then go to Repco or Supercheap and check stock or order the hose in.
    with apologies to Judy Grahn
    4,261
    ^^ Possibly Rob. Without looking at the catalogue, the R10 top hose is an odd shape and size. The thermostat fits inside the hose on the engine side then onto the top of the water pump housing, and from memory the size varies between that and the radiator size.
    I always thought the R8 and 10 were the same, but I think Johnw mentioned the early R8 (R1130) is different again?
    KB
    18,043
    I've also grafted two off the shelf hoses together.
    If you don't look at the "by inside diameter" catalogue you will never know.
    Mar 2012
    Perth
    194
    thanks guys really appreciate the help!
    Nov 2005
    Geraldton
    1,499
    If you don't mind doing a little sheetmetal work there's always the possibility of modifying the radiator carrier to accept R12 radatior, the hoses for which are more readily found.
    In the Shed(s):
    In the Past:
    10,369
    Yup. Early R8s have a smaller top spigot on the radiator. Not that they overheat.
    Renault 4CV 1951
    Renault R8 1965
    10,369
    I don't know whether this problem is still there, but it took me less than 30 seconds to verify that Mecaparts has them in stock. You need '2nd montage' in the top hose.
    These are always available.
    Renault 4CV 1951
    Renault R8 1965
    Simon's Avatar
    6,086
    And don't forget, you will be looking for a 73-75 degree thermostat, to suit Australia's climate. A lot of the Euro thermostats may the the 84 degree type.
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
