Renault Scenic, rear tail lights?
Results 1 to 8 of 8
Like Tree4Likes
  • 2 Post By Simon
  • 1 Post By Fordman
  • 1 Post By Berridale
Thread: Renault Scenic, rear tail lights?
    Jerangle
    776
    Default Renault Scenic, rear tail lights?
    Our 2001 Renault Scenic is due for a pink slip, lights failed.
    What does the lowest panel of red do ?
    Top brake light and parker work but the lowest panel light doesn't work, globe good .
    Presume Fail Test was because the lower panel was not operating.
    Will go in today and ask.
    Simon's Avatar
    6,163
    Is it something like a 21 watt single filament clear globe, in a red lens fitting? I'm thinking rear fog light. Perhaps they didn't have the knack to find how it works, or there is a poor/intermittent earth.
    HONG KONG PUGGY and Berridale like this.
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
    1000+ Posts Fordman's Avatar
    May 2004
    Perth/West Australia
    1,384
    I have same body Scenic. Common problem is connections in rear lights. Have posted a thread previously with details. It is where the harness plugs into the light assembly, need to clean contacts in light assy and possibly bend tabs slightly for better contact. Usually causes warning light on dash when applying brakes.
    Sorry, rushing to go out - look for prev thread - I will post further info later if you cant fix it.
    Berridale likes this.
    2004 Scenic I 2.0 auto (Hers)
    2016 Ford Territory (His)
    2004 WRX (Sunday car)
    Nov 2002
    Yarrabilba, Queensland
    2,755
    Yes it is rear fog light from memory.
    It is if I am correct the next position past the front fog lights that turns the rear fog on. Also another telltale light on the dash panel. There will be, low beam, front fog, which is green with a slash through the beam and an orange for the rear fog.
    While you are working on the light panel for the rear lights. I found an couple of the LED beam lights excellent in the reversing light globes really gives great visibility for reversing. I had a long dark driveway down the side of my house and it helped immensly
    Previous
    2001 Rx-4 Privilege
    R17TL, 1973
    R20TS x 3
    R18 GTS wagon x 2
    R10
    Jerangle
    776
    Is it something like a 21 watt single filament clear globe, in a red lens fitting? I'm thinking rear fog light."
    Simon, so the fog lights are in the bottom red section?
    May 2004
    1,384
    Previous thread from May 2016 - re bad earths in tail lights:
    Scenic earth problem
    and it refers back to another earlier post.
    Cheers.
    Jerangle
    776
    Sorted.
    female staff relayed the message incorrectly twice!
    Male to male communication solved the problem.
    Centre stop Light needed a globe.
    Fordman likes this.
    Nov 2002
    2,755
    Quote Originally Posted by Berridale View Post
    Sorted.
    Previous
    2001 Rx-4 Privilege
    R17TL, 1973
    R20TS x 3
    R18 GTS wagon x 2
    R10
