Fuel Sender Float Repairs
Results 1 to 7 of 7
Like Tree2Likes
  • 1 Post By Simon
  • 1 Post By nzrhysco
Thread: Fuel Sender Float Repairs
    Christchurch, New Zealand
    105
    Default Fuel Sender Float Repairs
    I've always had the problem of an inaccurate fuel gauge reading so in a moment of curiosity I had a look at the the sender unit and noticed that the float has a small amount of fuel in it which must be upsetting the reading. Is it possible to repair the floats or do I need to find a new one?
    Simon's Avatar
    6,161
    I’m guessing it will be a plastic float. Try popping the float attached to its arm, or a attach it to a piece of stiff wire, into (an old) saucepan on an electric stove top. Increase the heat (not to boiling) and watch for a trail of bubbles – the fuel will also likely vapourise and bubble out as well. Once you have ascertained where the leak is, it could be worked out if it is easy to fix, like using a hot soldering iron to seal a pinprick, or if it is a seam that has let go in the plastic moulding. Let the float cool to room temperature first – ensuring there is no fuel inside too, before sealing the leak.
    59 Floride likes this.
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,007
    After doing Simon's method to get the liquid out of the float.
    I would if it is brass solder the hole using the least amount of solder so as not to add to much weight, and if it is plastic use a suitable epoxy like Araldite, again using only a small amout.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    105
    Yes it's a plastic float. Thanks for your help guys
    8,858
    Geez. What car is it, idiot?!
    ACHTUNG ALLES LOOKENPEEPERS
    105
    [QUOTE=schlitzaugen;1547480]Geez. What car is it, idiot?![/QU
    Does it matter dickhead??!!
    facelnut likes this.
    8,858
    Obviously not to you.
