R 20 Clutch Master Cyl
  • 1 Post By Steve K
Thread: R 20 Clutch Master Cyl
    Kapunda
    455
    Default R 20 Clutch Master Cyl
    Having solved all the issues with the Slave and piping I'm now trying to dismantle the M/Cyl. I suspect that the piston is being retained by a roll pin hidden behind the fluid entry port.(I have removed the circlip and washer etc) Advise needed on how to remove the pin, assuming this is the reason the piston wont come out.
    Woody
    1000+ Posts driven's Avatar
    Apr 2005
    1,425
    Think the pin is removed with a tight drill bit, just so it grabs, similar to an Ezy-Out
    Bunnings
    https://www.bunnings.com.au/sutton-t...w-set_p6360087
    19,056
    Bunnings
    A pin punch is normally the recommended tool. To remove a rollpin
    SCA Punch Set - Pin, 6 Piece - Supercheap Auto
    Dec 2010
    Blackburn Victoria
    474
    Just screw an appropriate sized screw - plasterboard or wood are the best with a pointy and tapered tip - into the hollow of the roll pin
    and lever out with a claw hammer.
    If you look carefully, some roll pins have a small lateral hole near the end.
    In this case a suitable scribe can be used to lever it out.
    Kapunda
    455
    Thanks a lot guys, a 3.4mm drill did the job. Now I can see the lateral hole! I am tempted to assemble it minus the roll pin.
    Woody
    Dec 2010
    Blackburn Victoria
    474
    put the roll pin back in
    COL likes this.
