warning light
Results 1 to 22 of 22
Like Tree5Likes
  • 1 Post By Only19
  • 1 Post By driven
  • 1 Post By jo proffi
  • 2 Post By jo proffi
Thread: warning light
    Dec 2015
    boyup brook wa
    61
    Default warning light
    It has been a long time since I have been in the forum. My Renault 19 (Renee) 1.7 litre 1994 model has been running great. Today a warning light stayed on. I am at a quandary as to what this light signifies. I am pretty Sure it has something to do with the automatic transmission. It is Located on the bottom R/H corner and is coloured orange. It has a diagonal and then straight line configuration. It repeats this line pattern 3 times. If any one could confirm what this warning light is for, I would appreciate the information. Yours Shane
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,007
    A pic of the dash with the warning light on would help.
    I have a Laguna 1 about the same era and the only warning light that looks like what you describe is the imobiliser light.
    Does the car still start and run?
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    1000+ Posts FIVEDOOR's Avatar
    Jun 2011
    Brisbane Qld
    20,179
    I found this photo on the net, It's supposed to be 1994 Renault 19, is it the correct dash?
    Every day is a good day
    Brisbane/Australia
    2,047
    The lights at the bottom right are usually the choke and hazard.
    Orange warning lights do not normally indicate critical faults but are advisories.
    The gearbox warning usually is an outline of a gear box or gear lever and is usually red.
    If it looks like a zig-zag this is telling you there is an issue with the injection computer or injection system.
    This is very vague so it's best to get the car checked although if it's running okay it might not be urgent.
    Dec 2015
    boyup brook wa
    61
    G'day Fivedoor, the dash is similar, however not the same. Where the hazard light indicator is located is where this orange warning light is. It is similar to he pattern that Ren Tin Tin has shown. I would love to post a phot, but I lost my camera. Thanks for your help Shane
    Dec 2015
    boyup brook wa
    61
    G'day Col, the car still runs so it is not an imobiliser problem. I appreciate the help though Thanks Shane
    Dec 2015
    boyup brook wa
    61
    G'day Ren Tin Tin, the diagram you posted is similar, although not exactly the same. It is located in the same position as the Hazard light posted by Fivedoor. I drove Renee yesterday and the light remained on. I noticed that the engine was revving a 1000 revs above her normal revs. When I drove back I had no problems with either the light or the gearbox/engine revs. I have no transmission fluid leaking out. Thankyouy for your help Shane
    Fellow Frogger! Only19's Avatar
    755
    Hi there - had a 2004 Clio auto that would occasionally do that (1000 revs higher idle, same sort of light on dash) - generally due to a load of dud/contaminated fuel. (It seemed a bit oversensitive to fuel problems). Try draining the fuel and refilling with high octane and give it a good run. At the worst, you get a 1 - 2 year supply of mower fuel.
    Bryce
    jaahn likes this.
    Who needs brakes? They only slow you down ....
    Dec 2015
    boyup brook wa
    61
    G'day Bryce, I should clarify that the revs were only higher when I was travelling down the road. It was like I was in second gear when doing a 100km's. Renee has always idled fine. Thanks for the help though, Shane.
    Newcastle
    2,590
    Hi Shane
    The extra revs sounds like it was in 'limp home mode' and in 3rd gear. This is a normal protective step for all modern auto boxes if they see a fault. 3rd gear is direct drive.
    Have you serviced the transmission, eg changed the oil a couple of times. If not now is the time to start. How many Ks has it done.
    Jaahn
    1000+ Posts driven's Avatar
    Apr 2005
    1,424
    Injection or transmission, take to your Renault Dealer
    All Renault dashboard light warnings at
    https://www.drivingtesttips.biz/rena...s-symbols.html
    Apr 2005
    1,424
    If selling the car take out the globe.
    AND
    If buying a car ensure all warning lights are working as someone may have read this post or knows about this trick
    pug206gti likes this.
    8,395
    Would a renault dealer have an XR25.or know how to use it??
    Plugging The r19 into one would end the game of guessametrics.
    Jo
    COL likes this.
    Dec 2015
    boyup brook wa
    61
    G'day Jo Proffi, I had taken Renee to my local mechanic. He didn't have the right connection plug for the car/computer. My nearest Renault dealer is some 90 minutes drive away. This will be my last resort so to speak. Thanks Shane
    Dec 2015
    boyup brook wa
    61
    G'day Driven, I have no intention of selling Renee. I intend to drive her until she drops. Thanks Shane
    Dec 2015
    boyup brook wa
    61
    G'day Driven, that link was useful. Believe it or not it still didn't have the symbol that is on my dash. The closest one was the electronic fault warning light. For now I will closely monitor things. A trip to the dealer will undoubtedly be inevitable. Thanks Shane
    5,065
    Shane, it's most likely as Jaahn said.
    How many km has the box done? Has it got an external oil cooler?
    I'd call the dealer first and ask if they have an XR25 and an older Renault trained technician. If not, you're probably going to waste your money.
    You could check the transmission computer and look for oil that's creeped up from the pressure switch. It could be the multi function switch at the top rear of the transmission; it could be a problem with one of the valve body solenoids; could be an internal pressure loss problem.....
    If indeed there is an internal pressure reduction, the Renault dealer should have the tool/gauge to diagnose that easily. If the internal pressures are good then you look at the rest.
    If you need a manual to do the internals of the box i can send it to you. They internals are easy to fix if you have a few spanners and patience. It's possible to take the transmission out without removing the engine (have done it once and it wasn't too good for my back) so i just removed e&t as a unit.
    "The enemy of knowledge is not ignorance, it's the illusion of knowledge"
    Stephen Hawking
    lost
    11,055
    Icon6
    Quote Originally Posted by SHANE51 View Post
    G'day,
    draw a pic of it with a pencil, please.
    regards,
    Les W.
    206 GTi 180
    the stealth Pug
    8,395
    Quote Originally Posted by pug206gti View Post
    G'day,
    And then what??
    Mail a copy to each of us??
    pug206gti and jaahn like this.
    lost
    11,055
    Icon6
    G'day,
    I was thinking maybe, scan it, take the pic with a 'phone, or a camera. Come along to the FCOMTKD.
    p.s. any chance of an Australia Day BBQ ?
    regards,
    Les W.
    206 GTi 180
    the stealth Pug
    Oct 2005
    Rome
    2,660
    An automatic Renault 19?
    Won't be long
    Dave
    ​1997 BMW K1200RS
    IR655
    Newcastle
    2,590
    Hi Shane
    Then take note of JoBo. He owned quite a few R12 autos over the years and worked on them all including the rebuild of the autos. He put a lot of ideas and suggestions on here too for the help of others. Retired now I guess from that work
    Jaahn
