Info required - R21/R25 unleaded inlet manifold ports
Results 1 to 8 of 8
Like Tree2Likes
  • 2 Post By jo proffi
Thread: Info required - R21/R25 unleaded inlet manifold ports
    Oct 2005
    vic
    848
    Default Info required - R21/R25 unleaded inlet manifold ports
    Hi all,
    Would like to glean some information from those who have done this conversion, or, have the knowledge.
    Many moons ago I grabbed a head/manifold/loom from a fellow frogger.
    Was led to believe the whole shebang was from a 21.
    Same as the R25 S2?????
    A finger has been pulled out and am starting the work to graft the bits onto the Fuego.
    Since I did not pull the head etc, I have no knowledge of where the vaccuum lines go to.
    Could anyone provide me with the details of where:
    Red port A, Blue port B, Yellow port C, Lime port D, Black port E (brake booster?), Lilac Port F=fuel regulator & Orange port G attach to???
    Note G is mega compared to the others.
    Will do some more reading whilst the bibs & bobs are soda blasted then painted?
    Thanks all.
    Info required - R21/R25 unleaded inlet manifold ports-inlet-info-1.jpg
    Info required - R21/R25 unleaded inlet manifold ports-inlet-info-2.jpg
    1000+ Posts bowie's Avatar
    Aug 2002
    Sydney, Concord City, Sir.
    3,375
    They are all sources of vacuum right?
    Don't suppose it matters too much, just connect the things you have that require a vacuum line? What things do you have that need a vacuum source?
    -Brake Booster
    -PCV system (perhaps there are couple inlets here that come of the head)
    -Fuel regulator
    Is there much else that requires a vacuum reference?
    Oct 2005
    vic
    848
    Just to raise a note here - it is just me assuming that the R21 & R25 S2 unleaded EFI systems are the same here.
    Oct 2005
    vic
    848
    -Brake Booster
    -Fuel regulator
    Thanks Bowie for the thoughts.
    Yes they are the usual suspects, but would be good to know why there are so many take offs before discounting them.
    Aug 2002
    3,375
    Providing you get the major stuff, I reckon you will ok. There PVC system is probably complicated that explains all the other reference points?
    8,395
    -Brake Booster
    -Fuel regulator
    Renix injection uses a MAP sensor.
    This is the primary sensor giving load information to the ECU.
    I have a book somewhere with a great diagram of all the lines, and another with the Pin outs of the loom and the ECU.
    Pretty sure I've posted them before, but in any case I'll look for it and if it turns up I'll post a pic.
    To have these diagrams is really the only way to do this job.
    Jo
    Kenfuego and bowie like this.
    Oct 2005
    vic
    848
    Thanks Jo.
    8,395
    Inputs on the manifold that i remember,
    Map sensor and carbon canister control going to ecu box and connecting to ecu controlled solenoid valves. Small lines
    Carbon can purge line
    Fuel pressure regulator
    Brake booster
    Heater control valve plenum thingy (for those canisters that open and close heater flaps)
    Small pcv line goes to yellow port on to rocker cover ( big one goes from rocker cover to atmo side of throttle)
