Correct colour for R8 rims
Results 1 to 14 of 14
Like Tree4Likes
  • 2 Post By COL
  • 1 Post By Sunroof
  • 1 Post By JohnW
Thread: Correct colour for R8 rims
    10,769
    Default Correct colour for R8 rims
    I'll ask the question in public so the answer is shared. Hopefully in the singular!
    What is the exact, correct paint for R8/R10 wheels please? I have finally concluded that mine are disgusting again and instead of another brush coat of silver enamel over the top, I might actually do them properly.
    I'm not attracted to powder coating them, but am open to suggestions.
    Thanks in advance.....
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
    1000+ Posts Shoji's Avatar
    Jan 2012
    Mandurah WA
    1,091
    Are you after a gloss finish John?
    As you may know, I'm a big fan of Wattyls Colourthane. Two pack with high build, gloss off the gun.
    Very durable and to me better than powdercoat, which is just paint at the end of the day.
    The usual etch expoxy primer needed on bare metal and then undercoat for prep.
    Old style powdercoat from memory, used to be real plastic powder, electrostatic guns and heat. i could be wrong though
    When you find out the correct colour you could have it mixed in Colourthane.
    ďListen very carefully, I shall say this only once.Ē Cheers. John
    Jan 2012
    Mandurah WA
    1,091
    Oh I forgot to say. Best done in front of a spray booth. Nasty stuff
    Like this one.
    My wheels came up a treat.
    Attachment 101001
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,031
    Take the tyre off and get the paint colour matched to the inside of the rim.
    The paint inside should be like new unless there has been moisture in there.
    JohnW and Shoji like this.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    Boonah Qld
    2,525
    Renault Floride were painted with Renault colour, Grey 667. But not R8. I think Simon has put the colour on A/F before.
    JohnW likes this.
    10,769
    Quote Originally Posted by Shoji View Post
    Like this one.
    Attachment 101001
    Thanks. Your alloys are superb, I remember well. I don't think I want high gloss but flattener can be added of course.
    Renault 4CV 1951
    Renault R8 1965
    10,769
    Thanks Col. That's so obvious I hadn't thought of it.
    COL likes this.
    Renault 4CV 1951
    Renault R8 1965
    10,769
    All of my wheel 'insides' were already painted over the years, to control rust, and the newer R10 safety rims I have are black inside! I reckon the Oz-built rims are a better rim, although poorly finished at the outer edge, but they are the wrong size for R8 hubcaps.
    I found one wheel with its internal centre retaining its original paint, and they are matching the rims to that. The wheel place was adamant that they could match it better with a powder coating than paint and that, properly prepared, they'd be as good as new. We'll see.....
    Renault 4CV 1951
    Renault R8 1965
    Boonah Qld
    2,525
    If you get wheels powder coated then it is important to remove the powder coating where the nuts tighten. This warning was given to me by a powder coating place. Some times it has been known that the nuts come loose due to the nut not biting into the coating like it will on bare metal or paint. While this applies to R12, etc etc. It may not apply to R8, 10, etc because of the big washer.
    10,769
    Thanks for that warning. It rings a faint bell but I'd forgotten, that is for sure. I suspect you are right that it may not apply with the big bulbous washer. I'll torque them up to the top end of the range and check a couple of times I reckon. I quizzed them hard about powder coating, having seen some failures, but as usual with that sort of discussion the "experts" put the problems down to someone else not doing correct preparation. I suspect they are right!
    Mille Miglia display on Sunday. I'll send photos.
    Renault 4CV 1951
    Renault R8 1965
    Fellow Frogger! rubyalpine's Avatar
    Christchurch, New Zealand
    474
    My rims were powder coated about 7 years ago and to-date I've not had any problems.
    Henry
    When I find my feet,,,,,,,,,,,,,,I'll know where I stand!
    10,769
    Quote Originally Posted by rubyalpine View Post
    My rims were powder coated about 7 years ago and to-date I've not had any problems. Henry
    Many thanks Henry. Must get to Christchurch sometime.....
    Renault 4CV 1951
    Renault R8 1965
    4,367
    Likewise, my green R8 wheels were powder coated in 2003 or 04, and I'm yet to see a wheel fall off.
    I just picked a grey colour close to what they were before. There was not much science to it as back then I was just trying to make it look pretty more so than exact.
    KB
    10,769
    Good to hear, and the powder coating is just fine too, if I recall. I do remember hearing the story before though. Perhaps applies more to the wheels held on with a bolt and smallish square section? I'm really looking forward to having tidy wheels after all these years.
    Thanks for that.
    Renault 4CV 1951
    Renault R8 1965
