BOSCH RE-55 Voltage Regulator
Results 1 to 8 of 8
    Feb 2012
    Vista SA
    986
    Default BOSCH RE-55 Voltage Regulator
    Hi fellow Froggers.
    Before I rush out and buy one I'm just wondering if anybody out there has an old (working) BOSCH RE-55 Voltage Regulator they can spare. My good R8 just blew one up last week when the wire on the back of the alternator snapped of. Apparently if it disconnects during running the Voltage Regulator gets overloaded.
    Happy to pay for it plus postage.
    BARNIE is coming on, hope to be posting some photos of the finished engine soon! Hard work this restoration but the finished job will be worth it, I keep telling myself!!
    Thanks Guys
    Cheers Phil
    10,755
    If you've run the alternator open circuit, as I did by accident a while back, I think you are likely to have blown the diodes in the alternator itself. There's quite a thread back there somewhere on this.
    When replacing my (pretty old) Bosch alternator, I've had problems with RE-55 units giving strongly flickering headlamps. I reverted to the old style regulator, which didn't flicker but then started over-charging. We have an R8 owner here who is a retired TAFE lecturer on auto electrics, and he recommended setting up a relay by the regulator, so the wire from the ignition switch operated the relay to give a real 12V at the regulator, rather than taking that "12V" from the ignition switch. He suggested that with the length of the wiring, there could be voltage drop via the ignition switch, with the regulator trying to operate with less than a 12V input. I now have a short wire from the alternator +ve switched by that relay, so the regulator gets a real 12V input and the problem has gone away.
    Those RE-55 units are available new on ebay in my experience. There are two types, more or less identical, but one made in Oz and the other made in Taiwan.
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
    Feb 2012
    Vista SA
    986
    Good advice John. Thank you very much.
    I'll search it out this week. Luckily I bought a brand new battery for my R8 so its Ok for a day or two running around.
    Thanks again
    Phil
    Newcastle
    2,592
    Hi Phil
    I think I might have one in the shed 'up the top'. An old one from ?? a Valient or a VW Kombi perhaps. I will look for it and you can have it !!
    Send me your address
    Jaahn
    306
    Hi Phil
    I've got one here in Adelaide (Edwardstown to be precise).
    Call me on Oh Fore Oh Too 319 Seven Too Fore, if interested.
    Philip
    Newcastle
    2,592
    Hi
    I have sent two to you Phil today.
    Jaahn
    Feb 2012
    Vista SA
    986
    Thanks Philip for the kind offer but I now have one.
    Phil
    Quote Originally Posted by philipjh View Post
    Hi Phil
    Philip
    Feb 2012
    Vista SA
    986
    Thank you Jaahn. Very much appreciated. Im happy to refund the postage just let me know. Coffee on me when we can.
    Phil
    Hi
    Jaahn
