R8 rear suspension straps
Results 1 to 17 of 17
Like Tree9Likes
  • 1 Post By JohnW
  • 1 Post By Simon
  • 2 Post By renault8&10
  • 1 Post By 59 Floride
  • 2 Post By Frans
  • 1 Post By Simon
Thread: R8 rear suspension straps
    10,749
    Default R8 rear suspension straps
    Good idea to check them from time to time.....
    I jacked the car up for another wee job and just after the rear wheel left the ground there was a slight bump, and it dropped back down....
    Dimensions for a genuine item are given on the photograph.
    Attached Thumbnails Attached Thumbnails R8 rear suspension straps-rear-suspension-strap-failure.jpg
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
    4,366
    You can use conveyor belting and cut to length as a replacement but it is normally twice as wide (but apparently matches Gordini straps).
    I used to have some spare. I could look if you need some?
    KB
    Fellow Frogger! rubyalpine's Avatar
    Christchurch, New Zealand
    474
    I've also had a limit strap break when jacking up the R10. I've since replaced them with galv. chain inside 25mm clear vinyl tubing. Now easily adjustable and much stronger.
    Henry
    When I find my feet,,,,,,,,,,,,,,I'll know where I stand!
    10,749
    Galv. chain eh? I'd not thought of that!
    Renault 4CV 1951
    Renault R8 1965
    10,749
    You can use conveyor belting and cut to length as a replacement but it is normally twice as wide (but apparently matches Gordini straps). I used to have some spare. I could look if you need some?
    Thanks Kevin. I have spares I'm glad to say. These cars are so unreliable. The straps have failed twice now in 43 years!!
    FIVEDOOR likes this.
    Renault 4CV 1951
    Renault R8 1965
    Simon's Avatar
    6,161
    Just drill another hole a bit further down. It'll last another 40 odd years.
    Berridale likes this.
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
    10,749
    That's so obvious I'd not thought of it!! It would reduce suspension travel by a few cm mind you.
    Thanks Simon!!
    Renault 4CV 1951
    Renault R8 1965
    Feb 2005
    rosevale/tasmania
    2,744
    I used to use conveyer belt cut in half as well but now use Land Rover check straps (bought on eBay) cut to length.
    cheers! Peter
    4,366
    I don;t bother cutting it in half:
    Attached Thumbnails Attached Thumbnails R8 rear suspension straps-dscn2848.jpg
    JohnW and Sunroof like this.
    KB
    10,749
    I used to use conveyer belt cut in half as well but now use Land Rover check straps (bought on eBay) cut to length. cheers! Peter
    Should be strong enough! Thanks.
    Renault 4CV 1951
    Renault R8 1965
    It's how I roll...Brisbane
    33,030
    They're strong enough for the mighty Fregate too..
    Feb 2005
    rosevale/tasmania
    2,744
    I have to find room laterally for a camber compensator strap which loops up just about where the droop strap loops down.
    1000+ Posts Frans's Avatar
    Auckland
    1,487
    The chain story comes a long way in my application namely racing with a locked diff. It serves multiple purposes as follows.
    1) it won't break when flat out in a corner with possible disastrous effects.
    2) it is easily adjustable.
    3) it is set up to a comfortable length when traveling in a straight line with fair suspension travel. When cornering the inside chain swings towards the gearbox making it effectively shorter and reduces the travel or lifts the inside wheel sooner. That's what you need with a locked diff.
    Regards. Frans.
    lozenge and JohnW like this.
    10,749
    Well, that's ideal Peter. One strap is long enough for both sides: Rear Check Strap for Land Rover Series 2 2A 3 SWB & LWB 880mm 598854.
    $22 plus postage. 2 minutes to order, delivered to your door!
    Thank you.
    Renault 4CV 1951
    Renault R8 1965
    33,030
    ...I don't think Napoleon would have approved using Pommy stuff on a French car.
    10,749
    Quote Originally Posted by 59 Floride View Post
    Don't worry, it is probably Indian!
    Renault 4CV 1951
    Renault R8 1965
    Simon's Avatar
    6,161
    Perhaps not, but it helped Citroen and Renault penetrate into numerous export markets. :-)
    JohnW likes this.
    1963 Renault R4 Van
    1964 Renault R4
