R12 gear linkage - Page 2
Page 2 of 2 First 12
Results 26 to 33 of 33
Like Tree10Likes
Thread: R12 gear linkage
  1. #26
    10,786
    Quote Originally Posted by 59 Floride View Post
    There's a brand new one of those on ebay fr, I'll see if I can find it for you. (humblest apologies to the apostrophe police if I got it wrong)
    That apostrophe is correct, a diminutive of 'there is'. My frustration is with things like "a fox has two eye's". Plurals do not need apostrophes, as many fruit and veg places don't seem to understand. "Carrot's" is one horrible example that comes to mind, painfully. I know I'm a sad case.....
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
  2. #27
    Brisbane/Australia
    2,064
    I found with Pieces d'origine parts, the blocks lasted circa 160K km. Repro stuff is of questionable quality in a lot of cases. When replacing them again, place a couple of stout zip ties around the steel. This will give the rubber some sort of support, and will likely give some warning when the shift becomes imprecise before the car becomes immobile.
    Bolting the two halves together will make the car more prone to jumping out of gear over rough surfaces, especially if the engine and gearbox mounts are soft.
    Hello Simon,
    I have no idea if these were Pieces d'origine or aftermarket. They weren't bagged when I got them and there aren't any numbers stamped on painted on them that I could see. This might be indicative of them being aftermarket.
    I did have 1/4" nylon zip ties around the coupling, that's probably why only one side let go. It was a bit difficult finding reverse when I got to work but it went in eventually. This isn't unusual and reverse has often been a struggle (probably because the couplings were always on the way out). Today I found one of the zip ties in the car park. It was still done up so must have stretched and worked it's way loose. I was going to put some stainless steel hose clamps around the coupling but didn't have any of the right size at the time so it was going to be a job for another day (which unfortunately never happened). I think I recall seeing in my parts manual a plate that bolts over the coupling that holds it together but I've never seen this on any 12 I've ever come across. It shows it wasn't an uncommon problem if Renault went to the trouble of designing a fix.
    The engine and gearbox mounts are probably contaminated with oil are are likely to have gone hard rather than soft. Jumping out of gear I think I can live with better than have no gears. The 12 only ever goes on tarmac, and being a TL, sedately at that. There may be a pothole every now and then but not a lot. Suppose if I don't make any permanent changes I could always go back to the silentblocs if the gear jumping proves to be a problem.
    RTT
  3. #28
    10,786
    Hmm. I still wonder about alignment if you are questioning the mounts' condition. We just never saw this problem with two R12s over quite a few years and never replaced the pads.
    Internal issue with the gearbox? The only symptoms I experienced with these gearboxes was gear-changing getting easier, I supposed as the synchro springs weakened with high mileage, so I have my doubts.
    All a bit odd - I do sympathise with the frustration!
    Renault 4CV 1951
    Renault R8 1965
  4. #29
    It's how I roll...Brisbane
    33,165
  5. #30
    8,899
    That will most likely have the new style (most likely) after market rubbers, so no real benefit.
    I have had Stuey's wagon, and he did indeed change the rubbers to two steel bushings and I didn't see any problem. Engine and gearbox mounts were very good though, so that may have contributed to keeping the vibrations down.
    ACHTUNG ALLES LOOKENPEEPERS
  6. #31
    Brisbane/Australia
    2,064
    Wow 24 Euro, that's cheap. That's what they usually ask just for the rubber connectors.
    But they don't ship to Australia and we still have the weak link in that all that's holding the too parts together are two pieces of 3/4" rubber.
    For now, I've ditched the rubber mounts and bolted the two halves together with a piece of 20mm square steel tube in place of the mounts. I'll see how I go with that. If I get bad vibrations I'll change back to rubbers.
    RTT
  7. #32
    10,786
    That's odd, when I looked on ebay it said they did ship to Oz.
    If in doubt, ask them?
    Anyway, you might be prepared to live with it as you've now done the deed! At least it is reversible. Hope it's quiet enough and stays in gear.
    Renault 4CV 1951
    Renault R8 1965
  8. #33
    8,899
    Try to use the sway bar link nolathane bushings like I suggested and do away with the crappy rubber with poorly glued metal.
