R12 head
Results 1 to 12 of 12
Like Tree7Likes
  • 1 Post By Frans
  • 1 Post By bowie
  • 1 Post By driven
  • 2 Post By Simon
  • 2 Post By On the Edge
Thread: R12 head
    Brisbane/Australia
    2,051
    Default R12 head
    Is this saveable?
    Head height is 71.85mm. According to Mr Haynes this in not the minimum for the high compression head.
    Does it even matter as long as the valve seats are okay.
    RTT
    Simon's Avatar
    6,163
    Head heights:
    12TL, 810-02/842-01.
    Nominal height – 73.4mm.
    Minimum height - 72.9mm.
    Combustion chamber volume - 37.8cc
    12GL, 810-05/06
    Nominal height – 72mm.
    Minimum height – 71.5mm.
    Combustion chamber volume – 33.8cc
    As for whether it matters or not, it would all depend on the general condition of the rest of the motor, and the various degrees of performance attributes you are looking to achieve.
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
    1000+ Posts bowie's Avatar
    Aug 2002
    Sydney, Concord City, Sir.
    3,376
    From the other thread Frans indicated he has seen heads shaven beyond 71mm in different applications (noting the depth of the oil hole)
    But I confess i didn't understand what the min height references where published for? Was it just to ensure things were near enough OEM as a reference for mechanics and builders?
    1000+ Posts Frans's Avatar
    Auckland
    1,492
    Everytime the head is skimmed the combustion chamber becomes smaller and the CR goes up. The factory has a minimum and that is what is published. My opinion.
    Frans.
    bowie likes this.
    Old enough to know better
    Young enough to do it anyway.
    Aug 2002
    3,376
    There you go Ren. It's ok. it's just giving us free power but making the combustion chamber smaller
    Shoji likes this.
    1000+ Posts driven's Avatar
    Apr 2005
    1,425
    Need to check many things when going under recommended values.
    Thermal expansion of conrod and piston. Piston wobble especially when worn
    Valve bounce if springs are old or weak
    Check out
    HAMMER PERFORMANCE - High Performance for your Harley Twin Cam, Evo Big Twin, Sportster or Buell! 208-696-1250
    As good as any
    Hate to rebuild engine and see it destroy itself in the first 20kms when it gets up to temperature
    Sunroof likes this.
    Simon's Avatar
    6,163
    The reason for the factory set specs is that they are the parameters within which the car will perform to its factory designed standards in terms of not pinging, emissions etc..
    Going outside of those specs can enhance the performance, eg higher compression etc, but if you take a mile of metal off the head, the valve timing, ability to run on pump fuel, and emissions are compromised. All of those things concern the factory, hence their specified specs. As has been seen, people like Alan Moore, Ross and Frans have all demonstrated what can be done by going beyond the factory specs. But you really do need to know what you are doing – and what you want to achieve.
    Sunroof and Bustamif like this.
    1963 Renault R4 Van
    1964 Renault R4
    Brisbane/Australia
    2,051
    My 12 is one of the early type (not as early as Bowies) GL's so has the 842-01 motor (1251cc).
    I thought this was the low compression motors so according to Simons data the minimum for that should be 72.9.
    (I thought all the 12's with the Solex 32EISA were low compression but I could be wrong).
    But there's no problem with going to the high compression spec of 71.5 I guess.
    But my major concern was the pitting on no.1 cylinder.
    Skimming 0.3mm to bring it to 71.5mm wont remove all the pits but would they really matter?
    They're in the combustion chamber so I'm thinking they won't make any difference but I'm no engineer.
    RTT
    Auckland
    1,492
    To me it will not matter as long as the area where the fire ring of the gasket sits is clean without dents. A little dent or scratch can be the weak spot where the compression can force it's way through.
    According to the photo it looks like it will be good to use even if you have to go to 0.4 to get rid of some of the potholes..
    Frans
    Ipswich, Queensland.
    1,895
    As Frans has said, 0.3-0.4mm would still allow the head to be OK to use in your circumstance. I would get the machinist to just take the minimum to clean up the face. The marks from the broken ring will matter little in the whole scheme of things, with many Sierra motors having the same marks and still running OK. Your comp ratio would still be far from extreme, although I would recommend at least 95 octane fuel.
    I like Chilton Engineering at Wooloongabba for motor machining, although I have mostly used another guy up until last year when he retired.
    '56 Renault 750 (16TS Power)
    '62 Renault Dauphine Gordini
    '08 Renault Megane sedan
    Brisbane/Australia
    2,051
    None of the dents are in the combustion chamber or where the gasket sits.
    They're just where the piston and the head would be at their minimum.
    Thanks for the tip on Chilton Engineering Alan, I'll contact them.
    The higher compression wouldn't hurt and I only ever use 95RON or higher anyway.
    RTT
    May 2015
    Himeville - South Africa
    31
    Default R12 head
    Quote Originally Posted by REN TIN TIN View Post
    RTT
    I am using an R9 1397 cc engine in my race car and the head has had 2.5 mm skimmed off it for competition use and to achieve a decent CR ( 10.5 : 1 ).
    Following Frans's recommendation I did 3 torqueing procedures after fitting the head and after my first race meeting did it again.
    Three race meetings later and using 7000 RPM as a limit, all OK. Water temp has never gone over 85 C albeit that at my last meeting ambient temp was over 30 C.
    Tough little engines.
    Must add that I use 100 LL Avgas.
    'Till later.
    Arthur.
    Sunroof and bowie like this.
