Renault 25 Flywheel machining
  • 1 Post By mistareno
Thread: Renault 25 Flywheel machining
    don
    don is offline
    Fellow Frogger! don's Avatar
    Mayfield Newcastle
    415
    Default Renault 25 Flywheel machining
    Hi all need to consult the brains trust again
    How much metal can I have removed if machining the flywheel form my B29 R25. the old facings where down past the rivets and have scored the Flywheel. Id rather get it machined than not for a new clutch fitting.
    Anyone
    Administrator
    mistareno's Avatar
    Nov 2002
    4,926
    You should safely be able to remove more than enough from a R25 flywheel to remove any scoring. They are pretty heavy and soild.
    Just try and keep the RPM under 10K just in case
    jaahn likes this.
    don
    don is offline
    Mayfield Newcastle
    415
    Many thanks Misterano
    You are correct very heavy I didn't realize until it fell on my chest after the last bolt was removed. As for the revs
    don
    don is offline
    Mayfield Newcastle
    415
    Fellow Frogger! renoamust's Avatar
    Jul 2012
    Moss Vale NSW Australia
    124
    Quote Originally Posted by don View Post
    Anyone
    Hello Don
    If you require a replacement I have one here.
    Cheers Mark C.
    Restricted to driving Auto
    '08 Laguna II Ph II 2.2 DCi
    '02 Citroen C5 2.0 HDi
    '05 Megane X84 2.0 CC [ SOLD ]
    '90 R25 Baccara V6 Auto (1990 motor show car)
    '71 Mini K Hot Brick (m)
    Resto Projects in Progress
    '60 Dauphine 3sp
    '72 Holden HQ 1 Tonner 308/ H/T 400
    '84 Dacia 1.4 4X4 T/Top
    currently out in (BARNS)
    '99 Peug 406 SV V6 A S/wagon
    '95 Ren 19 Alize 1.8L a
    '94 Peug 405 SRDT m sed
    '92 Peug 505 FII 2.2l A
    '90 Ren 21 TXE 2.2L A
