wiper blades
Results 1 to 23 of 23
Like Tree5Likes
  • 1 Post By bob
  • 1 Post By bob
  • 1 Post By bob
  • 1 Post By REN TIN TIN
  • 1 Post By bob
Thread: wiper blades
    bob
    bob is offline
    May 2001
    Skipton
    2,254
    Default wiper blades
    G'day,
    silly questions time.
    The blades on the Latitude look to be held by the horizontal "U" shaped hook style, with a flip up latch on top of the blade.
    Flipping the latch up does not allow 'easy' sliding off of the blades - is there another lock on these ?
    thanks,
    Bob
    Oct 2005
    Rome
    2,660
    ​1997 BMW K1200RS
    IR655
    Oct 2005
    Rome
    2,660
    At 1.17 you can see him removing the old one
    ​1997 BMW K1200RS
    IR655
    bob
    bob is offline
    May 2001
    Skipton
    2,254
    G'day,
    I know that I'm a dull old fart, but not totally gone, the video method is totally obvious from just looking at the buggers on the car. If it was that easy they'd be off by now....
    Have to have a closer look, they're hanging on somewhere. Maybe they've been there far too long and just super sticky !!
    cheers,
    Bob
    1000+ Posts Kim Luck's Avatar
    Melbourne, Aus.
    17,330
    Turning the blades 90 degrees to the wiper arm and pushing it back down the arm to release its' spindle from the u-hook doesn't work?
    bob
    bob is offline
    May 2001
    Skipton
    2,254
    G'day,
    haven't tried 90 yet - not going out there now though, it's damn near snowing, outdoors temp is dropping like a stone !
    cheers,
    Bob
    Oct 2005
    Rome
    2,660
    It took me an hour to work out how to open my Leatherman the first time so I hear you...
    Dave
    ​1997 BMW K1200RS
    IR655
    1000+ Posts bluey504's Avatar
    Dandenong Vic
    1,240
    Quote Originally Posted by bob View Post
    G'day,
    cheers,
    Bob
    Bob wait until tomorrow or when the weather is warmer/visibility increases. Load up the wood burner and enjoy a night indoors.
    I think the collective wisdom on Aussie Frogs would be "We're too old for this cold shit."
    Brendan.
    ps Select a robust Red grape juice.
    bob
    bob is offline
    May 2001
    Skipton
    2,254
    G'day,
    OK, changed the mongrels, it takes the froggies to devise a way to turn something incredibly simple into complex....
    Yes, the 90 thing is important, I think that might be releasing the hidden catch at the end of the turn-back on the U piece but it still doesn't release from there, just gives you a little movement to clear the catch. Back to flat along the arm to get it off the rest of the way....
    Well, that's how it worked with whatever brand that it was fitted with.
    Replacements are elcheapos, but rubber. I suspect the ones fitted were silicon, been there before, rubbish streaky things, they ought to be banned.
    cheers,
    Bob
    Kim Luck likes this.
    Oct 2002
    Melbourne Victoria
    11,196
    Bob
    Next challenge, change headlights globe, I wonder if Renault have worked out a way to make that more difficult too!!
    Ken
    bob
    bob is offline
    May 2001
    Skipton
    2,254
    G'day Ken,
    I'm not up that challenge just yet....
    It's bound to be a horrid exercise, when you consider some of the stuff that they have in the design rules you'd reckon that the ability to be able to change a light-globe in the dark and rain at the side of the road would be some sort of priority.
    To be honest, I haven't looked at that one, I'm just assuming that it'll be a typical modern car.....
    cheers,
    Bob
    Kenfuego likes this.
    Brisbane/Australia
    1,972
    Quote Originally Posted by Kenfuego View Post
    Bob
    Ken
    I know, they could go back to sealed beam lights.
    Not only would they be harder to change, but they'd also be harder to find and cost four times as much.
    Oh joy!
    bob
    bob is offline
    May 2001
    Skipton
    2,254
    Default one plus !
    G'day,
    I suppose many modern cars have this problem. On the latitude the wiper arms will foul the bonnet if you lift them high enough to turn the blade to 90, so they provide for the stalk to be moved to the 'high' position where the blades will move to the middle of the sweep and stop - if the motor isn't running....
    So, some things do get better. This would have been handy for wiper operations on any car I've had...
    cheers,
    Bob
    Oct 2002
    Melbourne Victoria
    11,196
    Quote Originally Posted by REN TIN TIN View Post
    Oh joy!
    You might be right RTT, but more likely with LED elements and perhaps cheaper than the old style, but can manufacturers of the cars make them easy to remove and refit a spare on the road on a wet and rainy night. Galling to read in an owner manual that such changing of bulbs is best left to be done by a dealership.....
    18,038
    G'day Ken,
    cheers,
    Bob
    On a similar topic.
    On my ex Japanese V6 people mover. I purchased a set of spark plugs and was somewhat dismayed when I discovered the rear bank of cylinders required the inlet manifold to be removed in order to remove and replace the plugs.
    I then understood why the vehicle had original plugs fitted at 80,000km.
    What was expected to take 15 minutes, ended up taking almost a day.
    with apologies to Judy Grahn
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    3,803
    On a similar topic.
    That is pretty much standard practice on V6 engines of this century, Renault, Citroen, Peugeot, Mitsubishi are just some brands that come to mind.
    Regards Col
    1995 Renault Laguna V6
    2002 Renault Laguna V6
    1973 Alpine A110
    bob
    bob is offline
    May 2001
    Skipton
    2,254
    G'day,
    well, maybe not quite as bad, but bad enough.
    The second vehicle here is a trusty, no, not rusty, BA 'ute. 24v v8, a fairly rare breed this lot - especially with 6s manual attached. Anyway, the plugs on these things are cheap enough, but, the oldies tend to come out in three bits with a little 'ferrule' left deep in the plug 'ole. Necessitates the obtaining of a special tool kit to extract all the bits.....
    Yep, got the kit, local mechanic hasn't been game enough yet to give it a go.... nope, me too...
    cheers,
    Bob
    no iphone, just Linux
    bob
    bob is offline
    May 2001
    Skipton
    2,254
    Default Wiper blade update...
    G'day,
    OK, I got these fellas "HOOK Aero Wiper Blades Pair of 24inch (600mm) & 16inch (400mm)" from eBay seller "mycarperformanceonline", links keep changing on greedbay, easier to just search the description.
    natural rubber and $20 posted.
    No more silicon streaks and great wipers - I don't expect them to last long at that price but we probably should change them at least once a year anyway. No complaints...
    cheers,
    Bob
    Brisbane/Australia
    1,972
    G'day,
    cheers,
    Bob
    These are only plastic backed rather than the metal of the Bosch and other premium types.
    But once the rubber (or silicone) blade wears out it doesn't matter how good the arm is, the blade isn't refillable.
    Even $20 for the plastic ones is a bit high, you'll find them for less.
    You'll probably have to replace them twice a year but at $20 per set who cares.
    shanadoo likes this.
    bob
    bob is offline
    May 2001
    Skipton
    2,254
    Default Update....
    G'day,
    so the $20 blades have had their lifetime, say 10 months. Tell tale is they start to chatter, as it progresses you can see the rubber blade moulding breaking away from its backing. It starts from the centre and works out to the ends.
    Silicon would probably be tougher, but silicon blades are crap blades.
    For natural rubber $2/month [including post] is probably worth it....
    And, yes, after much swearing and cursing I had to come back into here to find out how I got the mongrels off last time....
    cheers,
    Bob
    Boonah Qld
    2,432
    Brand new wiper blades, genuine Volkwagen parts for sons VW chattered from new.
    bob
    bob is offline
    May 2001
    Skipton
    2,254
    G'day,
    it's a miserable $20 to try an alternative....
    It's a wonder that the Renault ones weren't replaced with 'real' ones at the last service, one of them was exhibiting stress back then. S'pose it proves that they don't do a proper check at service time....
    cheers,
    Bob
    Oct 2005
    Rome
    2,660
    Try some isopropyl alcohol on your windscreen first, removing the baked on oils and shite.
    Once done it may negative the need for replacement...
    Dave
    ​1997 BMW K1200RS
    IR655
