R8/R10 Spigot Shaft measurements.
Results 1 to 13 of 13
    Feb 2012
    Vista SA
    890
    Default R8/R10 Spigot Shaft measurements.
    Me again
    Anybody out there can tell me the diameters of a R8 and/or R10 Gearbox Spigot Shaft, where the clutch plate sits and where the spigot shafts goes into the flywheel.
    Thanks guys
    Phil
    9,303
    Two types Phil. The earlier ones have coarse splines and the later ones fine splines, I think both have the same diameter at the flywheel bush.
    You'll presumably be using the later type.
    Call Col R. I suggest if nothing comes through here. I don't have a later one to measure and am away in any case.
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    Peugeot 306 XT 1995 (daughter's)
    CitroŽn CX Pallas 1980
    Boonah Qld
    2,125
    Yes I have one sitting in the container, I'll check it out later. Mine will be the later type.
    Boonah Qld
    2,125
    The spigot shaft into fly wheel is 12mm. Is the other measurement you want the spline diameter?
    1000+ Posts Frans's Avatar
    Auckland
    1,215
    16.5mm OD 20 splines. But be careful because there are different angled splines that counts up to 20 and because the angles of the splines are different, they wont fit.
    Frans.
    Old enough to know better
    Young enough to do it anyway.
    Feb 2012
    Vista SA
    890
    Yes Rob. the OD of the splines please. Looks like Frans has it but I would like confirmation anyway.
    Thanks again
    Phil
    Feb 2012
    Vista SA
    890
    Thanks Frans. That's a good warning.
    Phil
    Frans.
    Feb 2012
    Vista SA
    890
    Thanks John.
    Phil
    Boonah Qld
    2,125
    Mine is the same as Frans. 16.5mm
    Feb 2012
    Vista SA
    890
    Thank you Frans and Rob. Now knowing what you have told me I think I'll raise up my old post on 'BARNIE the Barn Find progress' Something odd here about the Gbox.
    Phil
    COL
    COL is online now
    A110 COL's Avatar
    Van Diemen's Land
    3,219
    Phil
    Phil I reckon they have changed the input shaft to one from an R16 to handle the extra power.
    Is there a 6203 bearing in the end of the crankshaft for the gearbox spigot to go into?
    Regards Col
    1995 Renault Laguna V6
    2002 Renault Laguna V6
    1973 Alpine A110
    Feb 2012
    Vista SA
    890
    Yes Col 6203 Just bought a new one last week and installed it.
    Phil
    9,303
    Frans.
    Well well. That I did NOT know. Thanks Frans.
    Renault 4CV 1951
    Renault R8 1965
