Renault 16 tyres
Results 1 to 19 of 19
Like Tree4Likes
Thread: Renault 16 tyres
    Mar 2013
    43
    Default Renault 16 tyres
    Hello everybody, just a quick question. Has anyone had experience fitting 185/70 tyres to Renault 16TL R1152.
    Sent from my Moto G Play using aussiefrogs mobile app
    1000+ Posts bowie's Avatar
    Aug 2002
    Sydney, Concord City, Sir.
    3,532
    Worried they will scrub on the rear arches?
    1000+ Posts Kim Luck's Avatar
    Melbourne, Aus.
    18,563
    No I haven't, but I have used a 135x380 (15) R10 wheel on the back of my 16TS to get me out of trouble in a rally back in the day....
    Simon's Avatar
    6,203
    Too wide, also if you want a workout, just go to the gymnasium. It'll be easier than parking the car.
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
    Feb 2005
    rosevale/tasmania
    2,872
    For what it's worth, I'd fit 175/70 or 165/70 to an R16 (Continental PremiumContact2 tyres are the best currently available on any parameter of appraisal you care to cite except longevity). These are near identical in gearing to 155/80 & 145/80 respectively.
    Owing to the contact patch shape, neither will increase steering heaviness. 185/70 are legal on a 4.5" rim but I can't see what you'd gain from them & the contact patch becomes large enough to increase steering weight at low speeds.
    cheers! Peter
    COL
    COL is online now
    A110 COL's Avatar
    Van Diemen's Land
    4,334
    If the rims are:
    4.5 inch I would fit 165 tyres
    5.0 inch I would fit 175 tyres
    Just my worth
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    Apr 2003
    249
    The 185 spare won't fit under the bonnet either
    Mar 2013
    43
    Thank you all. I'm impressed by the fervour that you Renault fans have responded. Yes. Looks like 185 is overkill and for no good reason. The car already has these but I've yet to drive. I can remember from many years ago fitting 205s to an Alfasud which totally destroyed the handling and made slow speed steering very un-nibble. Just wondered what the effect might be for a R16. I guess the driving will tell.
    If the STD car came with 145s then legally in Vic can still pass a RW.
    Is fitting less wide tyres to the front whilst keeping the bigger ones on the rear a viable option?
    Any experience on this setup?
    Apr 2003
    249
    I have done just this to use some tyres that were too good to throw away. The results were ok, as predictable as you would expect. A bit like a trailer on a racing bicycle. Also a little bit of rub on the handbrake cable
    Aug 2002
    3,532
    In defense of wide wheels, I can't wait to get the 205's back on my 12. Its transformed it! I swear it reduced some body roll too. And made me a more considerate caring lover.
    1000+ Posts Shoji's Avatar
    Jan 2012
    Mandurah WA
    1,193
    Quote Originally Posted by Balouk View Post
    I fitted Bridgestone Supercats 185/70R13 to my Cosmics which I think are 5.5 inch wide. I pressume that's ok. Bridgestone guys were fine with it! Feels good fast around the hills of Nannup on the weekend.
    Feb 2005
    rosevale/tasmania
    2,872
    A few things:
    It doesn't matter if you can't fit a 185/70 as a spare. Use what you have that fits & don't worry about diff stress from mismatched tyre circumferences as you can avoid that (with a bit more fussing) by only ever fitting the spare to the rear.
    I didn't realise that you had the 185/70s already. As you do, then I can't see why you shouldn't use them. Not an optimal arrangement but not disastrous either. My worry would more be that they might be a crap tyre type or be date-expired. (People fit all sorts of rubbish to save money.)
    Low speed heaviness can be ameliorated by raising the tyre pressures (which lessens the contact patch). Find what seems ok for this at the front & then adjust rear tyre pressures to find the handling balance you wish. (Unless you relish plough-understeer, this will mean lower pressures at the rear.) The R16 is so supple that I can't imagine ride comfort loss from the higher pressures becoming an issue.
    I would emphatically recommend that you do not fit smaller tyres at the front & larger at the rear. This is a recipe for monstrous understeer. If anything, the (default understeering) balance of an R16 would be improved by going the other way & having larger tyres at the front. I have done this to profitable effect in the past on R12s & my Moke. Much the same adjustment to balance can, however, be achieved by tyre pressure differences.
    I don't think that you will get in registration hassles with the 185/70s as they legally fit the rim, have the same offset as the original, don't foul in any circumstances (I assume) & have equal or better speed & load range ratings compared to the original 145/80s.
    cheers! Peter
    11,302
    The Citroen CX originally had smaller tyres at the rear, as does mine. I have 175/70 x 14 at the rear if I recall correctly and 185/70 at the front. My spare is a 175 as the 185 doesn't fit in the engine bay! Sounds familiar Peter!
    There's not much space to play with in the rear guards of a 16.
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    Citroën CX Pallas 1980 (moved on to new custodian)
    Fellow Frogger! Sarosa's Avatar
    Mar 2003
    480
    There's not much space to play with in the rear guards of a 16.Cheers
    True. I'm surprised anyone can fit 185/70 without rear guard modification. In my experience 175's only just fit.
    1968 Renault 16
    1969 Renault 16TS
    1974 Renault 16TX
    2001 Renault RX4
    2013 Renault Megane
    Feb 2005
    rosevale/tasmania
    2,872
    Quote Originally Posted by Sarosa View Post
    Mind you, Balouk observes: "The car already has these ..." so something might have been done.
    Mar 2013
    43
    Many thanks again. Has set me on the "straight & narrow" .... or maybe not so "narrow"!
    Feb 2005
    rosevale/tasmania
    2,872
    Once you have had a chance to drive for a while in varied conditions on the 185/70s, it'd be interesting to hear how you found them. (And please include advice on tyre date stamp & tyre brand & type.)
    cheers! Peter
    Fellow Frogger! Trading Estate's Avatar
    588
    I thought the originals were 155?
    '04 Megane
    Gone but not forgotten
    '71 16 TS, '72 16 TL, '74 15TS,'82 20TS Series 2, '85 25 GTX. '49 L15,
    Feb 2005
    rosevale/tasmania
    2,872
    Quote Originally Posted by Trading Estate View Post
    145/80 for TL & 155/80 for TS is my memory. But read the earlier posts in the thread & you'll see why 185/70 is the focus.
