Outer CV bearing dust cover R17 shafts
Thread: Outer CV bearing dust cover R17 shafts
    1000+ Posts Shoji's Avatar
    Jan 2012
    Mandurah WA
    1,193
    Default Outer CV bearing dust cover R17 shafts
    It's the metal dust cover ring that fits on the hub end of the shaft that I'm after. Hub end.
    I have new shafts but they don't come with these parts.
    And they are a different size to the original shafts.
    I removed the old ones from the worn shafts but....
    Original was 45mm
    New shafts are 48mm, beefed up I suppose and last part number/version
    Anybody know where I can buy these?
    Renault 12 shop doesn't have them
    Luckily, I have the two brass shims that sit between the drive and the hub.
    This is the part like on this example shaft
    Jan 2012
    Mandurah WA
    1,193
    sorted
    I went to see an old fellow that has specialized in CV's for years. His business name is:
    Dicks CV's. Get Shafted by Dick!
    Really! No pun intended
    Jan 2012
    Mandurah WA
    1,193
    Sent from my Moto G Play using aussiefrogs mobile app
    Jan 2012
    Mandurah WA
    1,193
    Dick is about to celebrate 80 years. And he is still working. (And still tells the same jokes)
