R8/10 Rubber Door Seals undoing
Results 1 to 24 of 24
Like Tree2Likes
Thread: R8/10 Rubber Door Seals undoing
    668
    Default R8/10 Rubber Door Seals undoing
    The door rubber seals don't seem to be staying on. This is the second time I have glued them on using Selleys Contact Adhesive each time cleaning off all the previous glue from the surfaces ensuring they are absolutely clean. I am following the instructions to the tee, leaving the surfaces for 20-30mins before pressing together, but the rubber seal eventually comes apart from the door after a few weeks. It happens on the curved parts of the door back and front.
    Any suggestions for any better adhesive or technique?
    AS
    Simon's Avatar
    6,203
    Try Loctite 406, or your fave cyanoacrylate adhesive. With 406, it is very low viscosity, and only the tiniest drop is needed before it is pressed into place - when it becomes permanently adhered, so you only get one chance. Again, only the tiniest amount is needed, as you won't get a chance to wipe it away if it runs or drips onto a surface.
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
    4,425
    Also, it is important to wipe new rubbers down to remove release agent. Did you do that before the initial attempts?
    KB
    11,293
    Also, be careful not to stretch them as you glue round the corner. I've had adequate results with Selleys, with a few bits of re-gluing I'd agree. You might want to consider whether or not you expect to take them off in the future, or whether you'll accept/pay for new ones then. I like the idea of the 406, just applied along the corner - I don't believe you need both sides glued.
    I didn't know about wiping them down...
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    Feb 2012
    Vista SA
    986
    'Grease and Wax' remover from Super-cheap Auto at $14 a bottle works wonders as a pre-cleaner for anything to do with coatings on rubber or metal etc. Takes off all the finger prints, release agents, waxes, oils etc before you use your glues and paints.
    668
    I cleaned both surfaces with acetone carefully, and then 'prepsol' over again (which I know is a grease and wax remover).
    I do note that its the rubber separating from the glue, not the door side.
    I will give the Loctite 406 Simon suggests a go and will heed his warning about being sparingly with it.
    I will give it a good clean before I start of course (after etting the old glue off).
    Will give it a go next weekend and let you all know how I went.
    Thanks everyone
    Attachment 98928
    Mar 2013
    olinda victoria australia
    759
    The high end solvents ( acetone, thinners etc ) can be unkind to rubber and plastic, leaching out plasticisers etc. Prepsol is not as aggressive and is safe ( note rubber separating from glue )
    Selleys have a couple of grades of rubber cement, one normal and the other industrial strength. The latter sticks like shit to a blanket in most applications.
    The cyanoacrylate route is also good and less of a PITA than rubber contact adhesive as one can do it in stages. NOt all "Superglues" are the same and some disagree with plastics, so be careful to take advice about exactly what grade works in this application.
    My 404 was done with a cyanoacrylate glue and nothing's fallen off in two years, but I forget the exact grade/type
    Best Wishes
    Andrew
    Quote Originally Posted by R8 Dream View Post
    Thanks everyone
    Attachment 98928
    1000+ Posts geckoeng's Avatar
    Perth, WA
    1,765
    Angelo,
    Why not use the proper stuff for the job.
    Clean the surface with Turpentine, and wipe with a clean rag. Use 3M Weather Strip Adhesive, and do not leave too long to join seal to door. Do about 300mm at a time, starting at the top.
    Work carefully.
    Ray
    Ray geckoeng
    Think Old, But Run Modern !!
    668
    Angelo,
    Work carefully.
    Ray
    Thanks Ray, I figure you have done it recently with success, so will follow that lead.
    thanks
    Angelo
    19,214
    https://www.bunnings.com.au/sika-1l-...esive_p1210057
    You can't go wrong with the correct Sika product.
    I've thinned it with a little acrylic thinners to make it flow off the brush.
    Better to use a contact, because the rubbers seals can still be removed at a later date.
    Boonah Qld
    2,632
    Where did you buy the rubber? Is it slightly too big requiring the door to be closed hard, even with the adjusters right out? I need new rubbers but have always found the local and some overseas ones just a smidgen too big.
    668
    Mecaparts. They are a good match to originals when compared I thought.
    It's how I roll...Brisbane
    33,939
    I go along with the 3M tape idea too, I used it on the mighty Fregate door rubbers and they haven't budged. On my Floride I used Black Sika, they similarly haven't budged, Sika can be very messy in the wrong hands though..
    Every day when I wake up I reach up in the darkness with my eyes shut and if I cannot feel anything that resembles a wooden lid I know it will be a good day. No lid today.
    Boonah Qld
    2,632
    Thanks R8 Dream.
    668
    Quote Originally Posted by 59 Floride View Post
    I think Ray means the 3M Weatherstrip Adhesive (08011) which comes from a tube, not tape (double sided?)?
    Attachment 98935
    33,939
    19,214
    Contact adhesive worked well at time of original manufacture.
    If it's not working now, it's a reason to find out why rather than a reason to use an alternative method of attaching.
    In my opinion anyway.
    COL
    COL is online now
    A110 COL's Avatar
    Van Diemen's Land
    4,331
    Maybe the original rubber was natural and the replacement is synthetic and contact adhesive does not stick to well to it.
    I could be wrong just my worth
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    Mar 2013
    759
    Wonderful short thread. Learned lots ( was probably paying attention 'cos am about to do it !)
    The knowledge and experience in the group is amazing
    Andrew
    11,293
    My new door rubbers (4CV) came from NeoRetro in France. I have Oz-purchased rubbers on the R8, and they were glued OK with contact adhesive years ago, came off for painting and went back with contact adhesive.
    The 4CV rubbers went on with a rubber glue (auto painter's material so I didn't see the brand) and I've had to reglue some sections with Contact Adhesive (Selleys), so far quite successfully.
    With the 4CV, the doors are a hard shut, but it is the new rubber buffer triangles, not the seals I think.
    Clearly there are several different situations here and more than one type of rubber door seal. There are different objectives too, permanent vs removable.
    Please let us know what you actually end up doing that works for you!
    19,214
    The why don't rubber seals on modern cars fall off ? Presumably there are made of "synthetic rubber"
    Perhaps what you are saying is that the correct adhesive and careful surface preparation is required.
    11,293
    Not to argue at all, but to provide another bit of information. I've found this Dynagrip sticks like the proverbial to a blanket.
    Attached Thumbnails Attached Thumbnails R8/10 Rubber Door Seals undoing-dynagrip-adhesive-1.jpg   R8/10 Rubber Door Seals undoing-dynagrip-adhesive-2.jpg
    Fellow Frogger! Paul T's Avatar
    Mar 2012
    Bathurst, NSW.
    275
    New car seals don't fall off because they are held on with clips not glue.
    Paul Tomlinson
    R1135 Gordini 1968.
    Jaguar XJ-C V12 1975.
    Alpine GTA- ATMO 1987.
    Jaguar X Type 2002.
    Jaguar XF 2014.
    4,425
    Beat me to it Paul!
    KB
