Laguna II Power Windows
Like Tree5Likes
Thread: Laguna II Power Windows
    dat
    dat is offline
    May 2017
    24
    Default Laguna II Power Windows
    Hi all,
    Has anyone else come across the problem where the power windows will only move a small amount at a time? To get the window down or up I need to continually press and release the switch to get it up or down in small steps. It just moves a bit and stops when you press the button.
    I imagine there's a setting or an over current threshold that needs resetting I'm just hoping someone else has been there before and can save me some time.
    Dylan
    4,425
    It's common to have to reset the windows and it's described in the manual. Usually after changing a window motor, or if the power has been disconnected?
    I think you lower it down, then all the way, up and hold the up button on (once window closed) for 5 secs or similar.
    KB
    11,293
    Something like that. We've had once to reprogramme the Scenic and have had no issues since.
    If that doesn't work, the dealer will surely know the exact procedure - it's a quick and simple fix.
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    Oct 2005
    Rome
    2,660
    Lower the window until it is at nadir. Once there hold the power window button down for 20 seconds then release.
    Next raise the window until it is at the zenith. Once there hold the power window button down for 20 seconds then release.
    That should fix the issue. You are telling the mechanism where the top and bottom stops are. Before you do that, it just guesses, resulting in the small graduated steps.
    Dave
    PS Go Zenit, St Petersburg's Football team
    ​1997 BMW K1200RS
    IR655
    COL
    COL is online now
    A110 COL's Avatar
    Van Diemen's Land
    4,331
    Quote Originally Posted by 68 404 View Post
    Dave
    You need to do this for every window and every switch.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    dat
    dat is offline
    May 2017
    24
    Thanks guys, I sent the first response to my partner (I was at work) and she fixed it. Pretty sure she just did the drivers window and they all work properly now. That was one I'd never heard of or experienced before.
    Yes, I've had the battery disconnected a couple of times for various jobs. Now I know how to fix it.
    Thanks again!
