R12 igniton switch spring
Results 1 to 9 of 9
    Fellow Frogger! IThompson's Avatar
    Sep 2011
    Bendigo / VIC
    226
    Default R12 igniton switch spring
    The spring in the ignition switch has gone resulting in the starter motor staying engaged too long. I have to manually remember to twist it back quickly.
    Anyone with a suggestion?
    - dismantle ignition switch
    - replace ignition switch
    - bypass starter with a button
    Any ideas welcome.
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,338
    I would just replace the switch.
    You can separate the switch from the barrel, there is two screws that hold the switch to the barrel.
    I have had very little trouble with these switches, my experience is the opposite with the switch not operating the starter.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    1000+ Posts bowie's Avatar
    Aug 2002
    Sydney, Concord City, Sir.
    3,536
    Big... Red.... Button.
    Like Top Gun
    1000+ Posts driven's Avatar
    Apr 2005
    1,570
    Like Top Gun
    Never thought of this.
    I just used a screwdriver under the bonnet on the starter
    Fellow Frogger! Bolla's Avatar
    Merlbourne
    126
    I wired my first 12s ignition up to a momentary switch on the dash when the ignition lock failed (choice between beer money and the cost of a replacement ignition and I was at uni at the time) worked a treat. Had the added bonus that when someone tried to steal my car they failed to nut out the revised wiring.
    On a serious note I actually had a redundant momentary switch on the dash that was a standard Renault switch - you may be able to find one of them.
    Sent from my ASUS_Z010D using aussiefrogs mobile app
    Bolla
    85 Feugo x2
    83 Fuego (stored parts car)
    75 R12 Almost on the road!
    74 R12 Wagon undergoing restoration
    03 BMW K1200RS
    Ford Territory & Focus
    Previously
    too many Fords to list
    73 R12
    79 Virage
    11,302
    I'd not bother to mess with a probably worn out switch, myself. I'd either replace it with a new one (did that with the R8 years ago) or add a nondescript switch, like a Renault rocker switch with a momentary action, and keep the keyed switch for ignition and steering lock functions. On balance, I think I prefer the latter unless you are really concerned about originality.
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    Citroën CX Pallas 1980 (moved on to new custodian)
    1000+ Posts Shoji's Avatar
    Jan 2012
    Mandurah WA
    1,193
    Yesterday I glanced at a replacement ignition switch panel for race/track cars at Jaycar.
    https://www.jaycar.com.au/racing-ign...panel/p/SP0774
    Sent from my Moto G Play using aussiefrogs mobile app
    Brisbane/Australia
    2,202
    If the return spring isn't working it's the lock barrel that need replacing not the switch (which screws onto the end of the lock).
    New switches are available for not a lot of money.
    I've seen them on Ebay, Amazon, and through the usual suspects like R12 shop etc.
    Used ones are also around but they're an unknown quality and might last 10 years or 10 minutes.
    My 2 cents, replace the switch.
    Ren
    Brisbane/Australia
    2,202
    Here you go, on Aliexpress, around eight bucks plus shipping.
    The shipping charge is very high but still you have a brand spanking new switch for less than thirty bucks.
    Not worth the effort of rigging up a bypass.
    https://www.aliexpress.com/premium/r...d=0&isViewCP=y
