Another R17 owner planning to upgrade - Page 25
Page 25 of 25 First ... 152122232425
Results 601 to 623 of 623
Like Tree327Likes
Thread: Another R17 owner planning to upgrade
  1. #601
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    3,752
    Agree Col. Might be the drive position though.
    Thats easily checked by removing the distributor cap and making sure that the rotor button is point at #1 on the distributor when #1 cylinder is on TDC with both valves closed ready to fire.
    Shoji likes this.
    Regards Col
    1995 Renault Laguna V6
    2002 Renault Laguna V6
    1973 Alpine A110
  2. #602
    1000+ Posts Shoji's Avatar
    Jan 2012
    Mandurah WA
    1,001
    Am I meant to hear a decent squirt when I give a manual throttle? Yesterday I had the filters off and my ear down to listen. Nothing. But there's fuel in the bowl's. JJJ turned off because Brad has it full bore
    Sent from my Moto G Play using aussiefrogs mobile app
  3. #603
    Jan 2012
    Mandurah WA
    1,001
    I'll try again later
  4. #604
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    3,752
    Quote Originally Posted by Shoji View Post
    The fuel pump jet is on the motor side of the venturi up on the top. One would think that you would hear the fuel being pumped as you open the butterflies.
    If you get a mirror and look down the throat you will see it and as you operate the butterflies you should see fuel being squirted out.
    In one of your posts you said you has some back firing, for this to happen fuel must be getting into the cylinders.
    Check that the static timing is somewhere near, the points opening at TDC and it should start.
    Regards Col
    1973 Alpine A110
  5. #605
    Jan 2012
    Mandurah WA
    1,001
    If the gear drive is not installed properly then I would have issues? Just been reading from the manual. The points are closed.
  6. #606
    Boonah Qld
    2,402
    I had a hell'uve lot of trouble with my 17TS. If you have a lot of spare time you can read about it here.
    https://www.tapatalk.com/groups/rena.../r17-t389.html
    But now it runs well. Took years to get it right though. But then perhaps I am not too bright.
    Shoji likes this.
  7. #607
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    3,752
    The drive dog on the bottom of the distributor can go on two ways, the male part is offset.
    It is easy to change the drive dog position by removing the spring from around the drive dog; punch out the pin; rotate the drive dog 180 deg; re-insert the pin and replace the spring.
    In the pic post #605 is the motor on #1 cylinder TDC? If it is I would rotate the distributor clockwise until the points open and then try to start the engine.
    A way of checking for TDC without using timing marks is to remove #1 spark plug; rotate engine clockwise with your hand blocking the spark plug tube, you will feel pressure build as the piston come up on compression. When you feel this insert a screw driver down the spark plug tube until it sits on top of the piston; now rotate engine slowly clockwise until the screw driver stops rising, this will be close to TDC. If all is well the timing marks on the bell housing will line up with the flywheel timing
    mark. Do all your static timing checks with the engine in this position.
    bowie likes this.
    Regards Col
    1973 Alpine A110
  8. #608
    1000+ Posts driven's Avatar
    Apr 2005
    1,283
    To check the carbies are actually doing anything....back to the BUSH MECHANICS
    Fill spray Bottle with Petrol....DANGER / DEATH etc
    Better Still
    Get your to be ex-mate and fit out with Gloves, hat, glasses etc in case of backfire
    Crank over and spray into carbie inlets, no filters
  9. #609
    Jan 2012
    Mandurah WA
    1,001
    Drive gear is in the wrong way. No wonder I couldn't start it. Not happy Jan
    bowie likes this.
  10. #610
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    3,752
    That's progress, easy to fix.
    Regards Col
    1973 Alpine A110
  11. #611
    Boonah Qld
    2,402
    Better Still
    Better still and not quite as dangerous use "Start You Bastard" or " Ezy Start " just a brief spray.
  12. #612
    Boonah Qld
    2,402
    I have a long long nose pair of pliers and can use them to lift out the gear and move to the right place. Some times takes several goes to get it right as it spirals down. Easier than altering the dizzy drive.
    JohnW likes this.
  13. #613
    10,265
    Not a high assembly priority given you weren't going to use the distributor! Good luck getting it going.
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    Citroën CX Pallas 1980
  14. #614
    Jan 2012
    Mandurah WA
    1,001
    Still not good when your looking through the hand book at settings to sort the problem. anybody doing the same would have been stumped. The next person/mechanic who touches this motor will be! I got it going but the timing is tricky. It's running to rich and after a few hours of trying to get to run properly it decided to filled the glass bottle which was very alarming. I turned it off and walked away.
    bowie likes this.
  15. #615
    1000+ Posts bowie's Avatar
    Aug 2002
    Sydney, Concord City, Sir.
    3,174
    But more importantly.. It's Alive!
  16. #616
    Ipswich, Queensland.
    1,829
    Some air in the coolant system? Thermo fan not coming in?
  17. #617
    10,265
    I can recommend a bloke to help get it right! Glad it is running and I hope it gets sorted ere long. You really want it running well to get the rings bedded in sooner rather than later.
    Renault 4CV 1951
    Renault R8 1965
  18. #618
    Fellow Frogger! nauli's Avatar
    Oct 2017
    Perth, WA
    230
    Shoji, Shoji, Shoji.....I understand your pain. I've given this old bloke some time off from building my engine to come and assist....just don't take up too much of his time!
    geckoeng, 27of85 and JohnW like this.
    1969 Alpine A110
  19. #619
    10,265
    A week has passed in Peru, so no doubt in Perth as well.
    Any joy?
    If not, good luck and best wishes....
    bowie likes this.
    Renault 4CV 1951
    Renault R8 1965
  20. #620
    Oct 2017
    Perth, WA
    230
    John W and John Shoji....I am reliably informed that the car is now running very sweetly....True story Shoji-san?
    1969 Alpine A110
  21. #621
    10,265
    Quote Originally Posted by nauli View Post
    Good to hear and perhaps good news for your own engine assembly schedule!! I wonder whether they got the black box working?
    Renault 4CV 1951
    Renault R8 1965
  22. #622
    Oct 2017
    Perth, WA
    230
    I believe it's running on a distributor...
    JohnW likes this.
    1969 Alpine A110
  23. #623
    10,265
    Thanks Nauli.
    Good to keep the bits for both options! I have a transistored ignition on the 6V 4CV and, in the boot, the key wire to revert to points/capacitor from points/transistor box in a couple of minutes.
    Renault 4CV 1951
    Renault R8 1965
