Another R17 owner planning to upgrade - Page 2
Page 2 of 25 First 12345612 ... Last
Results 26 to 50 of 623
Like Tree327Likes
Thread: Another R17 owner planning to upgrade
  1. #26
    1000+ Posts Shoji's Avatar
    Jan 2012
    Mandurah WA
    1,032
    I am just so over these 508 errors. Only my mindless and moronic comments seem to be getting through, rather than something which might be vaguely useful.
    I imagine someone else will be able to assist. But in the faint hope something finally gets through, try googling these catalogues, someone may be more helpful than me (not unusual of late!): PR1002 (17TS Phase 1 parts catalogue), PR1017 (17 Phase 2 with 395), PR1064 (late 15/17 catalogue), PR1018 (Renault 18 1978-82).
    I bet this get through, in the meantime, I'm going off for a Bex and a lie down.
    I.
    also have lost two posts just now
    Thanks Simon. i'll look into it
  2. #27
    Jan 2012
    Mandurah WA
    1,032
    Another R17 owner planning to upgrade-p1030210.jpgAnother R17 owner planning to upgrade-p1030211.jpgAnother R17 owner planning to upgrade-395-gearbox-mounts-r17.jpg Off the Forum Amicale Renault 15 & 17 forum
  3. #28
    COL
    COL is online now
    A110 COL's Avatar
    Van Diemen's Land
    3,873
    Quote Originally Posted by Shoji View Post
ID:	98245Click image for larger version.
ID:	98246Click image for larger version.
Name:	395 gearbox mounts for r17.jpg
ID:	98248 Off the Forum Amicale Renault 15 & 17 forum
    Those pics are of a 365 gearbox with its brackets.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
  4. #29
    Jan 2012
    Mandurah WA
    1,032
    Just thought while I was at it post the 365 up on this thread too. this is where I thought I could cut and fit the 352 mount
  5. #30
    COL
    COL is online now
    A110 COL's Avatar
    Van Diemen's Land
    3,873
    I wouldn't cut up the bracket that you already have. Just get some 1.6mm sheet metal and bend up a bracket similar to the 365 brackets and weld together, if done right you could make them look pretty close to what the factory did and no one will notice the difference.
    Shoji likes this.
    Regards Col
    1973 Alpine A110
  6. #31
    Jan 2012
    Mandurah WA
    1,032
    I was thinking of buying the one on flebay (#1 post pic) cut that one up.
  7. #32
    Jan 2012
    Mandurah WA
    1,032
    Got it. Cheap as chips. Hang on, fish n chips aren't cheap these day's
    Sent from my Moto G Play using aussiefrogs mobile app
  8. #33
    Fellow Frogger! Jensen's Avatar
    363
    Here are some photos of the 365 mounting brackets. Apologies for the dodgy photos, I'm currently renovating and there is no power to the shed! Had to rely on the flash.
  9. #34
    Jan 2012
    Mandurah WA
    1,032
    Quote Originally Posted by Jensen View Post
    Thanks Jensen. Appreciate it!
    It looks like those mounts would be easy to make up. But where would I find the rubber silencers and the cover plates. They are a two piece!
    Are there any Renault's silencers that are similar. Two bolts to the side of chassis frame and a 90 degree peg with one bolt hole to the mount on the box. Seems the easiest way.
    Another question: are all the boxes main bodies of the 352, 365 & 395, not counting the end cover or bell housings, the same length?
    I have just measured the 395 box and it is 385mm approx. I'm sure they are as they share similar parts internal. I'm just thinking about where the 365 box has it's mounts. It would be no didfferent for this 395 box? if I could get some silencers then it's just a matter of copying those mounts with some sizes from someone.....
  10. #35
    Jan 2012
    Mandurah WA
    1,032
  11. #36
    363
    No worries. I'll measure the box when I'm back at the house tomorrow night.
    Yes I think R20 engine mounts work if you grind off a bit of the bracket. Like these https://m.motor-doctor.co.uk/product...ngine-mounting
    Otherwise pretty sure mecaparts sell new gearbox mounts.
  12. #37
    Jan 2012
    Mandurah WA
    1,032
    I checked out both sites but nothing available.
    So now I'm after some silencer blocks for the r17 ts.
    Anyone know of a website I can shop for these??
  13. #38
    363
    This was under A310 1600 (which also uses the 365 gearbox). The mount has two holes rather than one but if you are fabricating the brackets to attach it to the gearbox casing, that shouldn't present a problem.
    http://www.mecaparts.com/PhotosPieces/mp2047.jpg
  14. #39
    Jan 2012
    Mandurah WA
    1,032
    Jensen. Your right. They will do the job. do they also have the cover bracket on that site?
    Would you mind measuring the mounts on your gearbox in detail.
    Sorry but I can't get this info anywhere else, that I know of.
    Regards
    John
  15. #40
    COL
    COL is online now
    A110 COL's Avatar
    Van Diemen's Land
    3,873
    Regards
    John
    John you could fabricate the cover bracket from some sheet metal or if you are lucky a bit of SHS or RHS of the right size. All it does is stops the gearbox from fall onto the road if the rubber mounts fail.
    Shoji likes this.
    Regards Col
    1973 Alpine A110
  16. #41
    Jan 2012
    Mandurah WA
    1,032
    Yep, thanks Col. Great idea! This is possible and maybe the way to go.
    Ray (Geckoeng) and I have been talking about it just tonight. I understand the complete setup now. I think this is the way to go. Ray even mentioned a steel section beneath the box from one side to the other to help if a mount breaks.
    Thank you
    John
  17. #42
    Jan 2012
    Mandurah WA
    1,032
    Just found this. Thought I would add the original part numbers page for the gearbox mounts - 365 box for the R17. Future reference.
  18. #43
    3,493
    The part listed is actually for the A 310/6. The 310/4 doesn't have a mount on the side of the gearbox, it has a mount on the end cover and being bolted to the engine takes care of the other end. The mount is the same as the A110 1600 s
    Shoji likes this.
    .2010 Holden Commodore Ute
  19. #44
    Jan 2012
    Mandurah WA
    1,032
    Actual link to part MP2047
    SILENTBLOCS A310ALPINE RENAULT,GORDINI
    Thanks Jensen
    Just need the measurements for the steel mounts that fasten to the box.
  20. #45
    363
    I'll go and measure them up on Monday.
    Shoji likes this.
  21. #46
    363
    Hi Shoji,
    Sorry only just got a chance to measure up the brackets and take some photos. My verniers are in a box somewhere so had to use a tape measure and mark up on my phone! Hopefully it's enough detail to rough up the mounts and test fit before drilling the holes.
    bbcode image link
    bowie, vivid, Shoji and 1 others like this.
    2002 Monaco Blue Renaultsport Clio 172
    1975 R1317 Renault 17 Gordini
  22. #47
    Jan 2012
    Mandurah WA
    1,032
    Hi Shoji,
    bbcode image link
    Thanks Jensen for taking the time. I really appreciate it wholeheartedly!
    This a great help. I can now plan to make the mounts later down the road.
    Next to look at is the gear shift linkages......
    Anybody have images of their setups?
  23. #48
    Jan 2012
    Mandurah WA
    1,032
    Just purchased the chassis mounts from Meca Parts. $237 later for two mounts.
    Long walk to the shop though.
    COL and Sunroof like this.
  24. #49
    Jan 2012
    Mandurah WA
    1,032
    Has anyone have a workshop diagram/picture of the complete gear linkage for a R17 with a 395 box? Including gearshift
    Or better still, a picture of their car with complete linkage setup (later model I think)
    The 395 box has a different setup to the 365 and my 352
    As mentioned before, the r18 setup fits but i'm interested in how the r17 setup is with these boxes and maybe replicate.
    The link with silencers are the same. That's a good start. The shaft on this box is longer by 75mm
    Another R17 owner planning to upgrade-img_20170913_172505115.jpgAnother R17 owner planning to upgrade-img_20170914_134650149.jpgAnother R17 owner planning to upgrade-img_20170914_134701644.jpg
  25. #50
    Jan 2012
    Mandurah WA
    1,032
    Bump (Look up ^)
