Another R17 owner planning to upgrade - Page 15
Page 15 of 25 First ... 5111213141516171819 ... Last
Results 351 to 375 of 623
Like Tree327Likes
Thread: Another R17 owner planning to upgrade
  1. #351
    1000+ Posts Shoji's Avatar
    Jan 2012
    Mandurah WA
    1,018
    I'm presuming you mean "remote" not "bypass". A bypass filter doesn't take the full flow to filter it before it gets to lubricate anything. I know, pedantic.... Can't help it. Table #3 is looking good...…
    Yes John I did mean remote. it'll go like this - hot engine oil to filter, then to cooler and then return to engine as Ray explained. And a good local filter is fine by me.
    JohnW likes this.
  2. #352
    Jan 2012
    Mandurah WA
    1,018
    Thank Col. But I didn't have much luck with cross checking. It seems the Z9 doesn't have an equivalent in the Ryco SynTec so i'll call them today
  3. #353
    10,486
    Hmm. There's been much discussion on this one over the years. I like the Purflux because they are a quality product, compact and have a wonderful removal spanner that fits indentations on the filter body extremely well. Quite elegant.
    Some have had reportedly bad experiences with the Ryco filters, but I must admit I used them for years on the R8 without problem.
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    Citroën CX Pallas 1980
  4. #354
    Jan 2012
    Mandurah WA
    1,018
    Called Ryco and well I knew the Z9ST would fit but wanted a smaller version similar to the Z71 that the 807's use.
    oh well, there isn't. larger volume must be a good thing, right? to filter out the contaminates
  5. #355
    COL
    COL is online now
    A110 COL's Avatar
    Van Diemen's Land
    3,803
    Hi Shoji
    Have you thought about getting one of these? Right angle oil filter adapters
    https://www.speedwaymotors.com/Garag...er,296642.html
    I was looking on the Ryco Site and got these as the following dimensions for oil filters
    Z71
    Height 79mm
    Seal 73mm
    Seam 97mm
    Thread 3/4-16-UNF
    Z9
    Height 139mm
    seal 70mm
    Seam 94mm
    Thread 3/4-16-UNF
    I also measured up the oil filters that I use which are Mann W77
    Height 60mm
    Seal 70mm
    Seam 77mm
    Thread 3/4-16-UNF
    The height and seam measurements are just the external size of the oil filter, the important measurements are the seal size and the thread size.
    I was thinking about getting one of these adaptors to just around the oil spillage down the side of the block when changing filters.
    Regards Col
    1995 Renault Laguna V6
    2002 Renault Laguna V6
    1973 Alpine A110
  6. #356
    Jan 2012
    Mandurah WA
    1,018
    Yes Col they are good by the looks. But as you say , you get oil everywhere and now that I will have dual DCOE's in the way I thought remote would be to advantage. I've ordered/paid the two parts from Cov's. And Ray likes the hoses made up by Enzed. So mucking around. I just now have to settle on locations for all the bits but that can wait.
  7. #357
    Jan 2012
    Mandurah WA
    1,018
    yes I also had a good look at all the syntec sizes but not sure if they would fit. But now you say they could fit, I will look at them closer when the parts come in. Run the toledo over them to see what could work. The Z9ST is quite big but could be good for the engine.
  8. #358
    10,486
    Always have a towel in the workshop. Probably a very old one, rejected by SWMBO, and put it through the washing machine after a hot water soak in Sard Wonder Soap powder. I recycle all my good "rags" this way.
    Shoji likes this.
    Renault 4CV 1951
    Renault R8 1965
  9. #359
    COL
    COL is online now
    A110 COL's Avatar
    Van Diemen's Land
    3,803
    Quote Originally Posted by Shoji View Post
    The Z9 filter fits Ford Falcon 6 cylinder engines
    Regards Col
    1973 Alpine A110
  10. #360
    Fellow Frogger! 21571's Avatar
    Apr 2013
    Geelong
    125
    Another R17 owner planning to upgrade-1533644653948.jpgAnother R17 owner planning to upgrade-1533644663634.jpgAnother R17 owner planning to upgrade-1533644671596.jpgThis is what I'm fitting. Remote filter block with thermostat. Bit tight getting the pipes to the cooler but seems to be working. Still got the pipes that go to and from the engine to go underneath. Braided hoses surprisingly easy to cut and put fittings on.
    Moroso 90 degree fitting off the engine block, not much room to the chassis in there on an A310-4.
  11. #361
    Jan 2012
    Mandurah WA
    1,018
    Quote Originally Posted by 21571 View Post
ID:	108165Click image for larger version.
ID:	108166Click image for larger version.
ID:	108167This is what I'm fitting. Remote filter block with thermostat. Bit tight getting the pipes to the cooler but seems to be working. Still got the pipes that go to and from the engine to go underneath. Braided hoses surprisingly easy to cut and put fittings on.
    Looks a very tight space in there 21571. Mine should be a doddle
    While we are looking at oil cooling. I might look at the other cooling system a bit closer a give it an appraisal. If needed. Thermostat, pipes and radiator.
  12. #362
    Boonah Qld
    2,435
    All that pipe work looks complicated and expensive. Oil pressure isn't that high. The original oil cooler and filter has rubber oil hose with normal clamps. Why the complication and cost?
  13. #363
    Jan 2012
    Mandurah WA
    1,018
    Know what your saying Sunroof. Make it nice - because we can.
    But we are looking after the engines important fluids. Especially when your've spent so much
    Another R17 owner planning to upgrade-img_20180808_150742338.jpgOvernight airbag by Covs. very quick
    bowie likes this.
  14. #364
    Apr 2013
    Geelong
    125
    The Alpine and R17 spare parts catalogues sure look like they use braided hose, with screw on fittings. The coolers, filter blocks etc. all are designed for AN fittings, so hose clamps aren't applicable.
    The basic fittings aren't expensive on eBay. Braided hose is less than $20/m.
    And they're shiny.
    Shoji and bowie like this.
  15. #365
    Apr 2013
    Geelong
    125
    Get the radiator flushed! Who knows how much crap has accumulated in the last 40 years.
  16. #366
    COL
    COL is online now
    A110 COL's Avatar
    Van Diemen's Land
    3,803
    I pulled the end tanks off mine and rodded out the tubes, the amount of stuff in there was a wonder any water got through.
    Regards Col
    1973 Alpine A110
  17. #367
    Jan 2012
    Mandurah WA
    1,018
    I have had one of them done/serviced and is in the car. It's the larger one which is an original with a thermo fan. It's smicko but because I've had trouble with the larger one in it's first winter not keeping warm enough I will have the other smaller one serviced which would be good for winter. Rad shop is a walk over the road.
    I have a skirt in front of 1/3 of the rad currently and it's very happy
    Thermostat will be checked for temp number/operation when we pull the old motor out very soon (after the 19th of this month)
  18. #368
    1000+ Posts bowie's Avatar
    Aug 2002
    Sydney, Concord City, Sir.
    3,256
    The old motor, there are two? *gasps*
    Also, oil temperature, I assume when it gets too hot it looses it's ability to protect, (decrease viscosity) but surely modern oils have a fairly large operating range? How hot we talking about here?
    Or does a cooler allow you to simply run thinner oils in the knowledge that the temperature is regulated?
  19. #369
    Jan 2012
    Mandurah WA
    1,018
    Bowie. How could I/we be in so many places in the r17 in the last 6 months, Classic cars n coffee, Nannup, etc and have the engine being built by GekoEng? you better read back to numero 1#
    The R17 tardis
    It did cross my mind of how the engine, oil and water sync and the effects. But I don't know...
  20. #370
    Apr 2013
    Geelong
    125
    I've asked the question about oil temps on this forum before. Probably in the course of normal driving you won't need an oil cooler. The A310 doesn't have a huge radiator, and they came from the factory with an oil cooler so I figured I should put one back on. Not a fan of 'normal' driving myself.
    Sent from my LT29i using aussiefrogs mobile app
    Shoji likes this.
  21. #371
    Jan 2012
    Mandurah WA
    1,018
    And with a performance car 21571, who would want to drive normal?
    As Ray is building a performance engine for the R17, why would you rely the standard oil system of a pump and pan?
    baffles have been added to the pan and extra crankcase vents along with the cooler.
    21571 likes this.
  22. #372
    Jan 2012
    Mandurah WA
    1,018
    Default WTB R17 old engine mounts.
    Worn out or broken is fine. We need them for templates ASAP.
  23. #373
    Apr 2013
    Geelong
    125
    Which bits? I have an R17 motor sitting here, can't remember where I unbolted it though. Not sure how fast I can post either. Another R17 owner planning to upgrade-1534214544043.jpg
  24. #374
    Jan 2012
    Mandurah WA
    1,018
    Which bits? I have an R17 motor sitting here, can't remember where I unbolted it though. Not sure how fast I can post either. Click image for larger version.
    Hi 21571. It turns out Ray today has solved the conversion of engine mounts for a 16ts block to fit my R17 and it's brilliant. So I won't need any templates/mounts now. But we are still mucking around with the internal selector shafts in the 395 box.
    But thanks for your attention to my request.
    Hmm another 17 block hmm....and Wray supercharger. hmmm another challenge???
  25. #375
    1000+ Posts Frans's Avatar
    Auckland
    1,423
    My worth.
    If it had an oil cooler those days, put it back for authenticity and if you have one and would like to put it on it will always make an impression on somebody. However, with the oil technology of today I don't think a street car needs one, not even a hot street car.
    A few years ago a Le Mans team that, I can't remember who, had 2 identical cars running. It could be Porsches because they have a weak point in the front were the oil cooler is located, and one of these cars were in a get together. It limped back to the pits and the oil cooler was by-passed so it could carry on. After the 24 hours the 2 engines were stripped and no difference in wear could be measured between the oil cooled one and the non-oil cooled one.
    Frans.
    JohnW likes this.
    Old enough to know better
    Young enough to do it anyway.
