Another R17 owner planning to upgrade - Page 11
Page 11 of 25 First ... 78910111213141521 ... Last
Results 251 to 275 of 623
Like Tree327Likes
Thread: Another R17 owner planning to upgrade
  1. #251
    10,367
    Yes, as I recall and an Amal carby
    And Wipac ignition? I vaguely recall my old Latvian mechanic friend having one of the things back in the 1960s.
    I imagine they were quite expensive in the day....
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    Citroën CX Pallas 1980
  2. #252
    1000+ Posts Shoji's Avatar
    Jan 2012
    Mandurah WA
    1,011
    I've never been into personalized plates but when looking at the DoT WA, I couldn't resist.
    Oh and another pic just for Robmac.
    Another R17 owner planning to upgrade-front.jpgAnother R17 owner planning to upgrade-back.jpgAnother R17 owner planning to upgrade-atco-bits.jpg
    59 Floride, COL, bowie and 3 others like this.
  3. #253
    1000+ Posts FIVEDOOR's Avatar
    Jun 2011
    Brisbane Qld
    19,302
    Quote Originally Posted by Shoji View Post
ID:	105130Click image for larger version.
ID:	105131Click image for larger version.
Name:	Atco in bits.jpg
    See what happens when you put them back
    Edit :- Like the plates
    Shoji likes this.
    Every day is a good day
  4. #254
    Simon's Avatar
    6,086
    Going for the modern look, with the odd tail light lenses :-)
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
  5. #255
    1000+ Posts bowie's Avatar
    Aug 2002
    Sydney, Concord City, Sir.
    3,213
    Aw man that thing is sweeeeeeet!
    Ive never seen one with extra spot lights across the front like that. Looks great.
    And those plates. Perfect
  6. #256
    Jul 2003
    bundaberg
    311
    That orange back bumper looks so much better than the dowdy grey. Would love to see your 17 in the flesh. High beam must chew some power.
    bowie likes this.
  7. #257
    Aug 2002
    3,213
    Yes come to Sydney
    Bring the WA posse with you
    geckoeng likes this.
  8. #258
    Jan 2012
    Mandurah WA
    1,011
    Dropped into Gekoeng this morning on the way back to Mandurah from Perth today. More progress on the Hot French Donk. (yeah, we'll go with that!?) Block all cleaned and painted outside. Ray will be adding extra crankcase breather pipes to a catch can.
    Head is about to be ported up to 3mm larger and matched to the inlets. Power tool of choice for this is a large industrial dremel on steroids coupled with a tungsten carbide porting tool. Inlet manifolds also needs some extra porting to match the head. More porting near each valve seats to remove some of the humps for better flow and elimination of turbulence. I think....
    Sore arms for Ray though after this.
    Another R17 owner planning to upgrade-block.jpgAnother R17 owner planning to upgrade-block-2.jpgAnother R17 owner planning to upgrade-head-porting.jpg
    JohnW and bowie like this.
  9. #259
    10,367
    Clearly it is time I dropped in for an inspection!
    59 Floride likes this.
    Renault 4CV 1951
    Renault R8 1965
  10. #260
    10,367
    And I did. It's looking good. Chunky crankshafts for a 1500 cc engine!
    A very funny coincidence came out of the discussion. Ray had the previous day dropped into Harris Engineering, an engine workshop about ten minutes from our place, only to find a Dauphine head on the counter. He must have been ten minutes behind me dropping that precise head in for an overhaul plus conrods for new bushes, reaming and alignment. Small world, as Dauphine heads are not that common on workshop counters!
    Renault 4CV 1951
    Renault R8 1965
  11. #261
    Jan 2012
    Mandurah WA
    1,011
    Aussiefrogs walk/drive similar paths, John.
    JohnW likes this.
  12. #262
    Jan 2012
    Mandurah WA
    1,011
    Default Geezes - Used G Motor $$
    https://www.leboncoin.fr/equipement_...414593765.htm/
    vend moteur 1605 cm3 gordini ideal R17G -R12G -A110 etc ...type 844/12
    chemise - piston alesage 78
    arbre a came alpine renault A110 1600 142CH
    carburateur weber 45
    collecteur 4/1 devil
    moteur tres peu roulé environ 10000 kms par contre 10 ans arret
    prix: 5500 euros ferme non negociable pas la peine de tel pour perdre du temps
    a retirer sur place vente cause gros probleme de santé merci pour votre comprehension
    ATTENTION : ce n'est pas 1 moteur de R16ts ou tx ou R17 tl ou ts
    Translate:
    sells engine 1605 cm3 ideal gordini R17G -R12G -A110 etc ... type 844/12
    shirt - piston alesage 78
    camshaft alpine renault A110 1600 142CH
    carburetor weber 45
    collector 4/1 devil
    engine very little rolled about 10000 km against 10 years stop
    price: 5500 euros firm non negotiable not worth such to waste time
    to withdraw on site sale cause big health problem thank you for your understanding
    ATTENTION: it is not 1 engine of R16ts or tx or R17 tl or ts
  13. #263
    Fellow Frogger! nauli's Avatar
    Oct 2017
    Perth, WA
    237
    Translate:
    carburetor weber 45
    collector 4/1 devil
    Hmm...that makes sense!!
    Tempting...but don't want to cause myself a big health problem!!
    1969 Alpine A110
  14. #264
    Ipswich, Queensland.
    1,831
    About $8850 AUD. I would have thought it would need to be pristine and newly rebuilt with new everything for that. Perhaps I am just too tight for this business of playing with old machinery.
    Sunroof likes this.
    '56 Renault 750 (16TS Power)
    '62 Renault Dauphine Gordini
    '08 Renault Megane sedan
  15. #265
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    3,781
    My thoughts also Alan, when I saw the price and the condition I just about fell off my chair.
    Regards Col
    1995 Renault Laguna V6
    2002 Renault Laguna V6
    1973 Alpine A110
  16. #266
    Jan 2012
    Mandurah WA
    1,011
    I keep seeing these adverts being posted on the French page Renault 15 17 notre passion (fBook) for 12's, 15's & 17's with high prices in all conditions. Though not surprised with the amount of fans in France and Europe...
  17. #267
    10,367
    Interesting - our experience in Europe with the wonderfully hospitable members of the Floride and Caravelle Club was that few of the owners do as much of their own work as we do in Oz. They are used to paying for things and some costs there are simply higher. Maybe our expectations are higher? Not sure. There's a much bigger market that is for sure, and you only need one buyer per item....
    I'm groaning a wee bit at a quotation of about $240 for a crankshaft regrind, which is nothing in comparison with the cost of that engine. I'm with you Alan!
    Renault 4CV 1951
    Renault R8 1965
  18. #268
    Boonah Qld
    2,416
    About $8850 AUD. .
    Plus packing and freight. Thats over $10,000 I would think, just for an engine.
  19. #269
    Simon's Avatar
    6,086
    I can understand the price, the block would roughly be the equivalent of an L34 block, or a “Bathurst” block for an XU1 in Australia (which in France would just be considered scrap :-)). Not a lot of the 844-12 motors were made relative to other 12G/15/17 blocks, and few would have survived in usable condition with decent liner seats. Sure you could re-plate another block, but it just wouldn't be right, and I'm sure someone somewhere would be able to tell.
    JohnW, Shoji and 85Fuego like this.
    1963 Renault R4 Van
    1964 Renault R4
  20. #270
    Jan 2012
    Mandurah WA
    1,011
    Another R17 owner planning to upgrade-side.jpgAnother R17 owner planning to upgrade-side-again.jpg
  21. #271
    Simon's Avatar
    6,086
    LHS = RHD
    Odd that there are no E marks on the glass, are they replicas?
    1963 Renault R4 Van
    1964 Renault R4
  22. #272
    Jan 2012
    Mandurah WA
    1,011
    So they are identical Simon? I have heaps of them
    Please explain?
    Definitely Cibie. As marked at the bottom on the lens
    Edit: And there old
  23. #273
    Jul 2003
    bundaberg
    311
    ARE these for sale? Concave or convex?
  24. #274
    Jan 2012
    Mandurah WA
    1,011
    Concave. No Geedee, not for sale sorry
  25. #275
    Simon's Avatar
    6,086
    Please explain?
    Edit: And there old
    Identical to what? They are the pattern that was used on the Australian 17, if that was the question.
    1963 Renault R4 Van
    1964 Renault R4
