Another R17 owner planning to upgrade - Page 10
Page 10 of 17 First ... 67891011121314 ... Last
Results 226 to 250 of 425
Like Tree200Likes
Thread: Another R17 owner planning to upgrade
  1. #226
    9,970
    Quote Originally Posted by nauli View Post
    Definitely not right!! Looks like some refurbing required there John!
    https://piecesrenaultvintage66.com/i...roller=product
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    Citroën CX Pallas 1980
  2. #227
    9,970
    Quote Originally Posted by Shoji View Post
    Thanks Simon. I think I might go with a rebuild. Your Brake Parts Specialist | Perth Brake Parts
    or https://www.renault12shop.com/7701348206 or
    Shame it had to happen before Easter.
    I was looking forward to taking a crew to our local Dwellingup Pumpkin Festival in the orange 17.
    Here are my new best friends, hose-wise....
    Grey haired folk behind the counter....
    https://www.absauto.com.au/kewdale
    Shoji likes this.
    Renault 4CV 1951
    Renault R8 1965
  3. #228
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    3,586
    Taken out the master cylinder and booster today. No sign of leakage through back of the cylinder or the front of the booster.
    But there was something leaking inside the car from the booster. Only a few drops though and it is brake fluid because a little was on my floor mat and it has stripped a little paint off the back of the foot brake arm.
    When I took these photos I tilted the booster on it's front and fluid came out. That's not right, is it?
    Attachment 104918Attachment 104919Attachment 104920Attachment 104921Attachment 104922Attachment 104923
    I'm guessing the brake fluid thats in the booster is from a previous master cylinder leaking seal problem.
    I would be cleaning the inside of the booster by putting some methylated spirits in side and giving it a good shake and tip it out. Repeat until clean methylated spirits comes out, them put booster in the sun to dry out.
    Shoji likes this.
    Regards Col
    1995 Renault Laguna V6
    2002 Renault Laguna V6
    1973 Alpine A110
  4. #229
    Fellow Frogger! Shoji's Avatar
    Jan 2012
    Mandurah WA
    921
    Thanks JohnW. I know of the new parts out there. But Perth Brake parts can check the booster and master. So as you said go there and you know it will fit later, with warranty.
  5. #230
    Jan 2012
    Mandurah WA
    921
    I'll do that tomorrow Col Great advice. But still have it tested including the vacuum valve.
    COL likes this.
  6. #231
    Jan 2012
    Mandurah WA
    921
    All refurbished. Could have flown to Sydney return for the same money. Now to throw it all back in and bleadAnother R17 owner planning to upgrade-1522990108166.jpg
    Sent from my Moto G Play using aussiefrogs mobile app
    JohnW and bowie like this.
  7. #232
    Simon's Avatar
    6,080
    Peace of mind; priceless.
    Is the rear flexi hose from the limiter to the rear axle being replaced as well? It would likely be getting on a bit now, and would be worth replacing whilst everything else is apart if it hasn't already been done.
    JohnW, bowie and Shoji like this.
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
  8. #233
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    3,586
    While under there I would also check the proportioning valve, they are prone to leaking.
    Regards Col
    1973 Alpine A110
  9. #234
    Fellow Frogger! Jensen's Avatar
    355
    This hose is the same size/fitting as the front brake hoses from memory.
    2002 Monaco Blue Renaultsport Clio 172
    1975 R1317 Renault 17 Gordini
  10. #235
    Jan 2012
    Mandurah WA
    921
    I couldn't remove it. Threads are seized. I will spray with penetrant first.
    I might buy a new proportioning valve and do that job later. Best be ready.
  11. #236
    9,970
    Spray, spray and spray again....
    I'm a great believer in getting the parts in stock to fit when the moment and motivation come together!
    Shoji likes this.
    Renault 4CV 1951
    Renault R8 1965
  12. #237
    Jan 2012
    Mandurah WA
    921
    I turned up at the right time to see the engine in its beginnings of becoming a hot french donk.
    Good and bad upon discovery. Block is good. Head is really good and better than the spare one I have. Crank is not a goer as tolerances are to the max and rear main journal is knackered. But Ray is looking in his stash for a good one.
    Another R17 owner planning to upgrade-head.jpgAnother R17 owner planning to upgrade-gasket.jpgAnother R17 owner planning to upgrade-crank.jpg
    JohnW, bowie and FIVEDOOR like this.
  13. #238
    Fellow Frogger! nauli's Avatar
    Oct 2017
    Perth, WA
    153
ID:	105069Click image for larger version.
ID:	105070Click image for larger version.
    John...I dropped by and had a look at it yesterday too...and Ray showed me the crank...good thing though is that the build is off and running!!
    Shoji likes this.
    1969 Alpine A110
    2016 Ford Focus RS
    2012 Nissan Pathfinder (these have a Renault engine)
  14. #239
    1000+ Posts bowie's Avatar
    Aug 2002
    Sydney, Concord City, Sir.
    3,027
    agreed, and you are checking all this now. This is good (and good for us as we like these sorts of things)
    JohnW and Shoji like this.
  15. #240
    9,970
    Everyone should have a stash! I must slip over and have a look. If anyone wants a good 1951 Renault 4cv crankshaft with new white-metal conrod bearings, just shout! I doubt I'll be deafened.....
    Renault 4CV 1951
    Renault R8 1965
  16. #241
    Jan 2012
    Mandurah WA
    921
    Back on the road doing blockies and the brakes are working. Will need to work on that proportioning valve and replace it along with the hose. Have sprayed it with Penetran a few times, thanks JohnW. It worked very well on my old ATCO cylinder mowers chain gears yesterday. I'm refurbishing the old faithful with a full sand blast and paint.
  17. #242
    9,970
    Good re the brakes working! People collect those old Atco mowers and pay good money for them I gather!
    Do you have a good pipe fitting spanner of the appropriate size? I'll plan to slip over to your workplace during the school holidays if you are working then, at a convenient time of course.
    Renault 4CV 1951
    Renault R8 1965
  18. #243
    Jan 2012
    Mandurah WA
    921
    John, you're most welcome. Mondays or Tuesdays are best
    Do you mean flared spanners? If so, yes I do. Went and bought a set as I soon as I learn't....
  19. #244
    9,970
    Yes, they are the spanners. I just couldn't recall the correct name.
    Tuesday 17th sounds good I think. Morning. I'll bring my grandson, who is doing some woodwork at school and needs, IMHO, to see some top end carpentry. I'll be in touch nearer the time.
    I've never tried a rattle gun with a crow's foot spanner for brakes - I'll try to remember to bring mine down to show you what I mean.
    Renault 4CV 1951
    Renault R8 1965
  20. #245
    18,043
    And currently selling it on ebay too ?
    https://www.ebay.com.au/itm/Atco-Vin...8AAOSwZ5hacEyh
    From Altona Meadows, VIC, Australia
    Mutual Respect is Contagious
  21. #246
    Jan 2012
    Mandurah WA
    921
    Caught out. No. That's not my Atco. Just a pic off google images. I'll put it back, shall I?
  22. #247
    Jan 2012
    Mandurah WA
    921
    Sounds Good John. Your grandson is most welcome to have a look at our joinery shop
    JohnW likes this.
  23. #248
    18,043
    It's probably best not to tell pork pies in the first place.
    I found out quite innocently, looking on ebay to discover what an Atco was worth.
    My experience was with a Qualcast drum mower in the early 60s. Possibly the most unreliable mower ever built.
  24. #249
    9,970
    Baby Villiers motor?
    Renault 4CV 1951
    Renault R8 1965
  25. #250
    18,043
    Yes, as I recall and an Amal carby
