Need some help !!!
Results 1 to 13 of 13
Like Tree3Likes
Thread: Need some help !!!
    1000+ Posts geckoeng's Avatar
    Perth, WA
    1,767
    Default Need some help !!!
    All the A110 owners and knowledgeable people.
    Sam's A110 has got me baffled, mainly as i have worked on only a few.
    Window winders, does anybody have a winder out of the car or a picture of one. The ones fitted to Sam's car, I am sure are not the correct ones fitted. They interfere with the window slide arrangement. I have the window slide and quarter light aligned perfectly with the seal rubber, with the door fully aligned to the body, so everything is true. But the winder toothed segment hits the window slide frame. As if the winder body is too thick. And all else fits in perfectly. The parts book shows a similar winder frame mech, but the coil spring sits inside the door, and this one is on the inside face of the door.
    If I could see one first hand I can fabricate something like it, out of what I have got.
    Need some help !!!-20170706_153113.jpgNeed some help !!!-20170706_153137.jpg
    Thanks,
    Ray
    Ray geckoeng
    Think Old, But Run Modern !!
    My Supermodel 63-1092's Avatar
    somewhere! Pilbara, Bowen Basin, Melbourne?
    10,986
    Swap sides?
    John
    Александър Кристоф Шанел
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,333
    Hi Ray
    I found these pics here which from memory are correct:
    Blog de alpine-a110-in-force - Page 4 - alpine a110 - Skyrock.com
    As can be seen the ones from Sam's car have been modified, they are suppose to have an off set in the end that attaches to the metal frame below the glass.
    Hope this helps a little, been a few years since I had mine out, and as you guessed I never took any pics.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    Perth, WA
    1,767
    Hi COL,
    You are a star, the second one is exactly the picture I needed. I can now make what I need to fit in the door. The picture is downloaded and on a memory stick already, so I can do some work tomorrow.
    Thank you a great help,
    Ray
    Ray geckoeng
    Perth, WA
    1,767
    Col's Picture !!
    Thanks,
    Ray
    Ray geckoeng
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,333
    I have found some better pics with a bit of an explanation as well
    https://translate.google.com.au/tran...54&prev=search
    Regards Col
    1973 Alpine A110
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,333
    Some more from the same web site:
    http://a110a.free.fr/SPIP172/article...id_article=121
    Regards Col
    1973 Alpine A110
    Perth, WA
    1,767
    Hi COL,
    Thank you for the research on the 2 articles. They are great, as much as I do not think I would go to the extent of making my own toothed segments, the man is most dedicated.
    Thanks,
    Ray
    Ray geckoeng
    Perth, WA
    1,767
    I have worked out how to modify, and 1 is almost ready to be tested in the car. Looks perfect, so it must be perfect .......
    Ray
    Ray geckoeng
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,333
    Ray
    Good stuff Ray
    Regards Col
    1973 Alpine A110
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,333
    Hi COL,
    Thanks,
    Ray
    I was on night shift at work, dare I say with not much to do. I also learnt a bit from trawling that website.
    Regards Col
    1973 Alpine A110
    Perth, WA
    1,767
    COL,
    Your help was much appreciated.
    As from the correct picture for the part, above, I have been able to make.
    Need some help !!!-20170713_130355.jpgNeed some help !!!-20170713_130514.jpg
    They work perfectly in the situation, all I need to do is a little bending of the arm for final assembly with the glass.
    That was a good one,
    Ray
    Ray geckoeng
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,333
    COL,
ID:	98129Click image for larger version.
    Ray
    Good stuff Ray. They look great. I did learn a few things myself from that website.
    Regards Col
    1973 Alpine A110
