Mystery Renault Gearbox
Results 1 to 7 of 7
  • 1 Post By bob
Thread: Mystery Renault Gearbox
    Administrator
    mistareno's Avatar
    Nov 2002
    4,926
    Default Mystery Renault Gearbox
    Anyone have any ideas what type of box this is?
    It is a 5 speed box.
    It's apparently a late Renault 20, but I thought they ran a Fuego style box.
    This has the twin crownwheel reliefs like a UNI.
    There is no ID plate on the box.
    If it is a R20 5 speed, what would the ratio's be?
    Simon's Avatar
    6,134
    If it is out of a 20TS, the Observers book of Renault gearboxes says it will be a 369.
    1st 37/11 – 3.36
    2nd 35/17 – 2.06
    3rd 29/21 – 1.38
    4th 37/35 – 1.06
    5th 32/39 – 0.82
    AR 23/11 – 2.09
    Diff 8 x 33
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
    1000+ Posts FIVEDOOR's Avatar
    Jun 2011
    Brisbane Qld
    19,945
    Every day is a good day
    Apr 2014
    kilsyth (lower montrose) vic,
    181
    Hi mistareno, definitely late r25 note hydraulic slave cylinder mount bolt holes (horizontal holes at top of b/housining near clutch fork).
    more interesting is gearbox sitting next to it which has minimal casting webbing and steel plug on side of box,any ideas as to what that one is out of? jim
    Administrator
    mistareno's Avatar
    Nov 2002
    4,926
    1st 37/11 – 3.36
    2nd 35/17 – 2.06
    3rd 29/21 – 1.38
    4th 37/35 – 1.06
    5th 32/39 – 0.82
    AR 23/11 – 2.09
    Diff 8 x 33
    I don't suppose you know AUD Fuego Ratios for comparison?
    bob
    bob is offline
    May 2001
    Skipton
    2,351
    G'day,
    Quote Originally Posted by dacia4x4 View Post
    Hi mistareno, definitely late r25 note hydraulic slave cylinder mount bolt holes (horizontal holes at top of b/housining near clutch fork)..... jim
    R20 also had hydraulic clutch - with dodgy plastic hose... well, not so much the hose, the connections had a tendency to pop out...
    Local brake place fixed mine by replacing the hose and fittings with 'normal' style screw in rubber hose, cheap as chips fix....
    Mine was a 5 speed also, but I can't recall the number. It came from a late model R20 (replacement for knackered auto) and was built like a brick dunny inside.
    cheers,
    Bob
    JohnnyAfrica12G likes this.
    Apr 2014
    181
    oops,correction to post no4,meant r20 wrote r25,as r20 also has cable speedo drive(as seen in photo) where as r25 is electronic. jim
