R 20 timing belt
Like Tree2Likes
Thread: R 20 timing belt
    Kapunda
    496
    Default R 20 timing belt
    I,m still learning the ropes on my R20.Being of dubious provenance I,ve decided to fit a new timing belt.
    A seller has one which he says is for a late model and it has 116 rounded teeth.Please can anyone advise.
    Woody
    Simon's Avatar
    6,203
    With the 20TS, the early cars had a square tooth timing belt, and the later cars had the round section timing belt. So it will pay to check which belt your car has, as both types were sold in Australia. Also, it will pay to change the water pump at the same time whilst everything is apart, as well as all the A/C, accessory belts etc.
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
    Kapunda
    496
    Thanks Simon, as mine is a late model ve decided to risc it anyway, seeing as it was only $20
    Woody
    6,665
    Brian, if the belt is old stock it may not be wise to use it. If you do wish to, at least check that if you bend it in the reverse direction the rubber doesn't show cracks and check the rubber has not hardened or the teeth may strip.
    2003 PEUGEOT 206 GTi
    Boonah Qld
    2,634
    My R20 (early model ) did 600,000 never had a timing belt change. Just saying.
