Spark plug extensions
Results 1 to 7 of 7
  • 1 Post By bazzamac
Thread: Spark plug extensions
    Canberra ACT
    670
    Default Spark plug extensions
    Hi all
    Does any know whether there are spark plug extensions available for an R8G motor. I have them on my Fuego Turbo (807 motor with R18 fuel injection) which has deep spark plug recesses. They are too long for an R8G motor. The problem is making sure I connect the ignition leads to the plugs in my A110. Unlike the R8G, plugs 1 and 2 are well inside the engine bay on my A110 which makes it difficult, without a lot of patience, to find the tip of the plug and securely connect the ignition lead.
    Simon's Avatar
    6,136
    Where have you tried? I'm thinking starting with the usual sources, Alpine Affaire/Mecaparts/Simon Auto/GBS, etc., those places would have the required A110 experience to know which will fit with no fuss.
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
    Feb 2005
    rosevale/tasmania
    2,712
    On my R5 A/G motor, my mechanic used some from a Nissan or Toyota (or whatnot) with similar recessed spark plugs. One incidental advantage of them is that when one has unscrewed a plug, it is easily extracted by used of the extension as a lifter.
    So, a visit to a wrecker or Autobarn or . ..
    cheers! Peter
    8,810
    My suggestion as well. I have found some leads that fit perfectly the 807 engine and some that fit the 205GTI engine by just rummaging through the blue boxes (can't remember the brand name) at Supershit. The brand makes some nice fat wires (8mm?) with silicone covered ends, great stuff.
    The wires I have found for the 807 engine even come with nice rubber covers for the spark tubes and the extension section is some hard bakelite-like material.
    ACHTUNG ALLES LOOKENPEEPERS
    Canberra ACT
    670
    Thanks everyone for your advice. Did have spark plugs extensions that held the coil packs from my Nissan Silvia 200SX (now sold) but they are too long and too much fiddling to modify. Could find anything that suited at Supercheap and not inclined to rummage around wreckers without knowing a definite vehicle to source from. Found what I needed from GBS Alpine (ordered 29 June and arrived today - excellent service) and cost A$178.25 delivered.
    COL likes this.
    8,810
    Part number/brand/some sort of id?
    Canberra ACT
    670
    You can find it on their website at GBS SPECIALISTE ALPINE Bienvenue sur le site GBS Welcome to GBS website Look under A110 and catalog ignition for 1300G. Reference number is MOO46SB.
