R8/R10 Hood Lining
Results 1 to 17 of 17
Like Tree4Likes
  • 1 Post By 59 Floride
  • 1 Post By renault8&10
  • 1 Post By brettr
  • 1 Post By Paul T
Thread: R8/R10 Hood Lining
    Fellow Frogger! R10S FAN's Avatar
    Mt Barker S.A.
    391
    Default R8/R10 Hood Lining
    Does anyone know if its possible to transfer the hoodlining from one car to another? I have a mint interior in an R10 that I'd like to put into my new project and the hoodlining would be the icing on the cake!
    Anthony
    Sent from my SM-T813 using aussiefrogs mobile app
    Current Frogs:
    1964 Renault 8 (1289 / Sonics)
    1968 Renault 10 (Modified 1.4L Alpine White)
    It's how I roll...Brisbane
    33,990
    Yep, I reckon they should interchange. I'd also recommend you lay the donor hood lining out in the sun before refitting, this will make it a little more supple and stretchable. There is the possibility that you will need to redrill the holes for the bows if there is a subtle difference between new and donor body shells.
    R10S FAN likes this.
    Every day when I wake up I reach up in the darkness with my eyes shut and if I cannot feel anything that resembles a wooden lid I know it will be a good day. No lid today.
    4,426
    It's possible if you are super careful but with the age, it is super brittle particularly on the c pillars and around the windscreens where it is glued on. With all the best intentions I'd say you are likely to rip and tear it removing it. The main part is not glued and retained by the metal hoops which do unlock and release relatively easily. It is also a dusty, tedious job so be prepared.
    KB
    Oct 2014
    Windsor 2756 NSW Australia
    663
    I agree with renault8&10 on R10 trim. Unless the car has been stored in a dark room with a controlled climate, my experience with vital parts of 10 lining is that it is dry, tissue thin and explodes into a tear when handled only slightly roughly, a bit like my skin as I get older. Good luck, it is possible but very high risk.
    Simon's Avatar
    6,203
    The French (large diamond) fabric can be quite fragile with age, and is very prone to tearing as indicated above. However the Australian (small diamond) fabric used on the later 10s is not as fragile. They will swap over between models, just make sure things like the grabhandles and coat hook holes line up before gluing the sides in place.
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
    1000+ Posts Dano's Avatar
    Apr 2012
    1,452
    Once tried to remove and keep a 404 hood lining for later use, but unfortunately it was unsuccessful. Just too brittle. If the hood linings are glued to the frame around the windows and doors, I would suggest using a hair dryer (not a heat gun, too hot) to soften the glue prior to pulling at it. It makes it easier to remove and reduces the chances of tearing. The vinyl does distort a lot though, especially were its been glued.
    528
    Just get a new one and be done with it....
    Sent from my E5823 using Tapatalk
    BR
    Building a race car is easy - building a race car that can be road registered is hard.
    For any custom fabrication call Precision One Off Engineering - Sydney 02 4587 8666
    Mt Barker S.A.
    391
    Where did you source that one from Brett?
    Sent from my SM-G935F using aussiefrogs mobile app
    Current Frogs:
    528
    Mecaparts.
    BR
    Fellow Frogger! Paul T's Avatar
    Mar 2012
    Bathurst, NSW.
    276
    I used a new one as well. The new ones use the same or very similar patterned material. Mine came via J Y Lardinois in Belgium.
    R8/R10 Hood Lining-dsc_2172.jpg
    Dano likes this.
    Paul Tomlinson
    R1135 Gordini 1968.
    Jaguar XJ-C V12 1975.
    Alpine GTA- ATMO 1987.
    Jaguar X Type 2002.
    Jaguar XF 2014.
    Simon's Avatar
    6,203
    ENPI may be the source, so it could be worth shopping around. Although if doing a bulk order through Meca or J-Y, there may be minimal savings when it comes to bulk buy and postage.
    SELLERIE EN PRET A POSER & TISSUS RENAULT 8 - 10 - ENPI-RETRO
    1963 Renault R4 Van
    1964 Renault R4
    Fellow Frogger! Gordini Pervert's Avatar
    Mar 2012
    Perth
    203
    yeh I reckon it will rip... save the pain man, either get it re trimmed OR new mecaparts??
    Mt Barker S.A.
    391
    Thanks for all your replies, might just order a new one from Mecaparts.
    Anthony
    Current Frogs:
    Dec 2010
    260
    Default J Y Lardinois
    Quote Originally Posted by Paul T View Post
    Paul, can you give me JYL e-mail address, I'm trying to contact him and must have an incorrect e-mail for him.
    Mar 2011
    Roselands
    253
    Default Headling
    If the headlining is not torn, have you thought of having it painted. Could be a goer, or just go to an upholsterer and have it replaced. I had a new headlining in my 4CV installed locally. Just a thought
    Quote Originally Posted by chris hartwell View Post
    Mar 2012
    Bathurst, NSW.
    276
    As soon as I get home tonight I will send it in a PM.
    Paul Tomlinson
    R1135 Gordini 1968.
    Jaguar X Type 2002.
    Jaguar XF 2014.
    Member Thierry's Avatar
    Feb 2015
    Central coast
    35
    I transferred a r10 one not long ago it came up okay, but I'm sure a new one would be better.
