R16TS Sump size ??
Results 1 to 14 of 14
  • 1 Post By COL
Thread: R16TS Sump size ??
    Feb 2012
    Vista SA
    986
    Default R16TS Sump size ??
    Is there somebody that can confirm to me that somewhere in the manufacturing life of the R16TS Renault decided to change the shape and capacity of the R16TS sump.
    I have two different shaped sumps and I'm assured by both R16TS previous owners that they came with these sumps on.
    It's a bit of a optical illusion in the Attachment that the one on the right is larger. They are identical in base fitment but the one on the right is a different internal shape and deeper. The smaller one was the original sump used for rally work, hence the baffle half way down the middle.
    Thanks guys
    Phil
    See Attached:
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    3,955
    Hi Phil
    The sump on the right is a R16 sump, the one on the left is a R15/R17 sump the someone has modified with that baffle.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    Simon's Avatar
    6,136
    +1 to what Col said.
    The one on the left is a 15/17 sump - also the 15/17 and 16 motors use a different oil pick-up. Either way, both hold 4 litres. Are you sure it is a 16 block? (no biggy, as the block is the main difference between 16 and 15/17)
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    3,955
    As far as I know the differences between the blocks is where the engine mounts bolt on and also the liner seal area.
    Regards Col
    1973 Alpine A110
    Feb 2012
    Vista SA
    986
    Gee Simon, now you got me thinking. The block is labeled 807 - 03, been wondering why my Workshop Manual M.R.96 only lists 807-01 and 807-02 for the R1151 Type.
    Is the bore and stroke the same for both R16TS and 15/17 ??
    What is the difference between the blocks ??
    Thanks for your advice Simon
    Phil
    Boonah Qld
    2,506
    R15 and early 17 blocks had different mount holes than the 16. But 16TX and 17TS/G engines had holes for both 15/17 and 16's.
    Feb 2012
    Vista SA
    986
    Hi Phil
    Thanks Col. See what comes from Simon's reply. I new it had been modified but never even thought it might be from a R15/R17.
    Phil
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    3,955
    Hi Phil
    Here is a link to Richard Mann's description of the differences between the Renault engines available here, is a good read with lots of information.
    RICHARD MANN'S CROSS FLOW RENAULT ENGINES
    Stuey likes this.
    Regards Col
    1973 Alpine A110
    Simon's Avatar
    6,136
    Hi Phil
    That's a great link!
    1963 Renault R4 Van
    1964 Renault R4
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    3,955
    Yer it is, Richard knows his stuff. I think he is like all of us here learned the hard way.
    Regards Col
    1973 Alpine A110
    6,248
    Plus one! Fascinating stuff.
    2003 PEUGEOT 206 GTi
    Feb 2012
    Vista SA
    986
    Hi Phil
    Thanks Col. That's a top read. Answered all my questions.
    Phil
    Boonah Qld
    2,506
    That is a great thread Col thanks.
    Oct 2014
    Windsor 2756 NSW Australia
    566
    I donít agree with Richard Mann in using those Alfa liners to get the big capacity.
    We found that they are only just OK with a low compression Renault engine but the material is not up to the task when you get over 9:1 CR. They split the liners very easily.
    I have been using the Mecaparts high quality steel liners 86 and 87mm bore. You have to do a lot of work to the block to get the big capacity reliably. The steel quality is a quantum leap from cast liners.
    As mentioned previously the Mecaparts quality control is sometimes not up to standard. I did not have a problem with the liners being oval, mine were bell shaped - larger inside diameter in the middle which took a lot of work to fix and oversize pistons. Then three full years of hard circuit racing with no problems.
