Fuego battery relocation - cabling firewall
Results 1 to 12 of 12
Like Tree4Likes
Thread: Fuego battery relocation - cabling firewall
    Oct 2005
    vic
    868
    Default Fuego battery relocation - cabling firewall
    Hi people,
    Am after inspiration from people who have relocated their battery.
    Following this thread, have re-located battery in the tool compartment behind the rear seat.
    Cabling I am running inside the cabin up to the firewall (RHS).
    Now, I am looking for a good spot to penetrate the firewall and continue to the starter.
    For those souls who have done the job, where have they run the cable through to the engine bay?
    All the promising spots on the RHS firewall close to the steering wheel are too cramped to drill.
    Any advice?
    Prefer not to go outside until up the firewall.
    David
    1000+ Posts driven's Avatar
    Apr 2005
    1,570
    Everyday use, then probably need an Engineers certificate for insurance purposes
    19,218
    Why ?
    It's not a mechanical modification nor change to any item which is inspected during RWC checking.
    Provided the battery is securely mounted and wiring is done in workmanlike manner IMO there should be no need for a engineering certificate.
    8,484
    Quote Originally Posted by 85Fuego View Post
    Hi people,
    Any advice?
    David
    Have a look and I'm sure you'll find some existing holes bunged up with rubber behind the glove box.
    Some type of hangover from the the conversion to right hand drive.
    My fuego wiring was heavily modified with all types of sensor wiring going through the firewall, and I don't remember drilling any holes but seem to remember drilling out a bung.
    Jo
    19,218
    And if you need a seal and abrasion protection you could use a cable gland as a feed through. A cable gland will also positively hold the battery cable.
    https://www.jaycar.com.au/13-18mm-di...-pk-2/p/HP0740
    Administrator
    mistareno's Avatar
    Nov 2002
    4,926
    It's been a while, but I think I ran my cable through the LH firewall as the battery cable comes around to the starter motor on the LH side.
    I have a large circuit breaker mounted next to the battery incase there was ever a direct short due to an accident or similar.
    I have a full river battery mounted in the compartment above the beam axle in the boot.
    I never had any issues with it.
    I only ever ran the positive lead to the front. I just earthed the neg cable well.
    Never had any issues.
    I think I had my positive cable mounted to a small rubber mount that was a junction. It also meant I could jump start the car from under the bonnet if required.
    I'll have to have a look though to be sure...
    Brisbane/Australia
    2,202
    Why the RHS?
    You'd be better to go the LHS where there are unused pressings in the firewall for the LHD versions.
    Boonah Qld
    2,634
    Why move the battery at all?
    Oct 2005
    vic
    868
    Default cabling re-location ideas
    Robmac - thanks have that. Am looking at also getting some grommets for internal cable protection.
    Quote Originally Posted by mistareno View Post
    Mistareno/Jo/Ren Tin Tin - Thanks, will search there
    I have a large circuit breaker mounted next to the battery in case there was ever a direct short due to an accident or similar.
    Good idea. What rating? Anyone done a current check to see what current is drawn whilst starting? 400 Amps??
    Yes have same battery HC40 so am thinking exactly along the same lines.
    Thinking of doing the same.
    Smart thinking, again, will do the same. Was going to add an anderson plug so that charging could be done externally.
    Sunroof, 2 things: a) the Fuego steers like a lead arrow around the track - moving some weight to the back will help b) am thinking of putting an oil cooler in that space.
    Will keep you updated with progress/questions/ideas.
    8,484
    the Fuego steers like a lead arrow around the track - .
    That has often been said, but for some reason I never found that to be the case.
    Not running 205/50r15 tyres by any chance??
    Jo
    bob
    bob is offline
    May 2001
    Skipton
    2,534
    G'day,
    ......the Fuego steers like a lead arrow around the track - moving some weight to the back will help......
    Interesting, best drive that I had in mine was during the big move to the sticks. Poor old Fug was loaded to the gunnels' sat like a brick on the road and went round bends like it was on rails, SWMBO was following in the Celicia and couldn't keep up...
    Scenic steelies with 195/55, same rolling diam as originals.
    cheers,
    Bob
    Oct 2005
    vic
    868
    Not running 205/50r15 tyres by any chance?? Jo
    Jo
    Calculated the OD and fitted 195/55/15.
    So, in my opinion, not overly overtyred.
    By lead arrow, I mean one has to use the fast in/brake hard/fast out style of driving.
