1.4 engine main bearings (first under)?
Results 1 to 10 of 10
  • 1 Post By 4cvg
Thread: 1.4 engine main bearings (first under)?
    Feb 2005
    rosevale/tasmania
    2,712
    Default 1.4 engine main bearings (first under)?
    Does anyone have (or have a source of) first undersize main bearings for the 1397cc R12 engine?
    cheers! Peter
    1000+ Posts Frans's Avatar
    Auckland
    1,477
    Hi Peter,
    I assume that you will have the big journal mains. I think all 1400s has the big mains.
    CLEVITE MS1381AL.25MM Main Bearings for 76-87 RENAULT 810, C6J, R5 Alpine Turbo | eBay
    Don't know of any local stuff in NZ or Aus.
    Regards, Frans.
    Old enough to know better
    Young enough to do it anyway.
    Traralgon,Victoria
    205
    Peter, as it happens I have just had my 1.4 c (1397) crank reworked by Crankshaft Rebuilders in Melbourne and Colin Stark of Alpine Affaire supplied the bearing set for first grind .25 . I think Colin keeps them in stock.
    Brian
    Feb 2005
    rosevale/tasmania
    2,712
    Thanks to both of you.
    18,725
    cheers! Peter
    Cranks are under size: bearings to match are oversize
    Feb 2005
    rosevale/tasmania
    2,712
    Ah, I was relying on the common shorthand in which 'first undersized bearings' is shorthand for 'bearings suitable for first undersized journals'.
    Sunroof likes this.
    Member JohnnyAfrica12G's Avatar
    Jul 2015
    Pyalong Victoria
    59
    Sorry Pete had another look here all standard.
    1000+ Posts geckoeng's Avatar
    Perth, WA
    1,620
    Sorry Gents !!!
    Bearings for a ground crankshaft are Undersized, as the bore of the bearing is smaller than standard (?????)
    Try phoning Precision International auto parts !!!
    Ray
    Ray geckoeng
    Think Old, But Run Modern !!
    18,725
    Sorry Gents !!!
    Ray
    Upon reflection you are indeed correct and I unreservedly apologize for my brain fart.
    Feb 2005
    rosevale/tasmania
    2,712
    Sorry Gents !!!
    Ray
    thanks for the lead Ray.
