Renault 4 cv joints
Results 1 to 9 of 9
    Jan 2017
    Parwan Victoria
    5
    Default Renault 4 cv joints
    Hi all. I have a Renault 1963 three speed. The passenger side cv joint has had it. I'm wondering does anyone know a company who reconditions these drive shafts or sells new ones in Australia, hopefully Victoria. Thanks fazza
    Feb 2005
    rosevale/tasmania
    2,870
    If you get in touch with the 4CV Register then you should be able to secure a good second-hand one from someone.
    cheers! Peter
    1000+ Posts geckoeng's Avatar
    Perth, WA
    1,765
    Fazza,
    I presume you have a Renault 4L and its has a problem drive shaft.
    There would be a number of used drive shafts available, and I think the only place you will get new is Europe, some of the retro spares outlets. You will need to give them vehicle model numbers, from the "diamond"and "oval" plated on the firewall in the engine compartment.
    Ray
    Ray geckoeng
    Think Old, But Run Modern !!
    tweed heads
    1,544
    I recall having a friend drive an hour to procure an axle from my home so i could do a roadside repair[ broken axle] ,on my car ,only to find that the spline on the one he brought was different ,the experts can advise ,the build date may not be applicable as who knows what has been changed over the years, pugs ps i had to go back with him to get the right one ,i had several .
    Jan 2017
    Parwan Victoria
    5
    Thanks for the responses I've spent all week on net searching. I often look up this Renault 4 website / forum site in U.K. They all spoke of a Machanic shop in U.K. Called Renault speed. He specialised in Renault 4s. He told me to find some one to rebuild it. First place I saw rebuilt each shaft for $200 each. He also said he will re build rack and pinion. Going to put shafts in tomorrow then a drive. Go go Reno
    Feb 2005
    rosevale/tasmania
    2,870
    Fazza,
    Ray
    Ray's quite right, I didn't read the original post closely. Not a 4CV at all but its replacement, the R4. The point stands though. Why not trawl around (in a new thread with a correct subject title) for a good second hand one?
    cheers! Peter
    Perth, WA
    1,765
    Fazza,
    You may also want to see :
    4lparts - vente de pièces détachées pour 4L - 4L Parts
    Ray
    Ray geckoeng
    Feb 2001
    Romsey, Victoria, Australia
    4,904
    Quote Originally Posted by Fazza View Post
    My brother would have dozens of them and he's in Werribee so not far away. Send me a PM and I'll give you his number. He can also tell you about the 4cv register, well worth you joining.
    David Cavanagh
    03 9338 8191 or 03 93354008
    34 KING St
    AIRPORT WEST
    VIC 3042
    frenchconnect@bigpond.com
    Feb 2005
    rosevale/tasmania
    2,870
    Quote Originally Posted by David Cavanagh View Post
    No he wouldn't because we speak of an R4, not a 4CV. I repeat that the thread would work better if it was retitled or, as that isn't possible, replaced by another thread.
    To Fazza: I know that the '4' & the 'CV' are separated by a space but it's still pointlessly inviting confusion. Try: 'R4 constant velocity joints'
