Use-by date for engine oil?
Results 1 to 20 of 20
Like Tree16Likes
  • 6 Post By jaahn
  • 4 Post By 68 404
  • 2 Post By 4cvg
  • 1 Post By robmac
  • 3 Post By Simon
Thread: Use-by date for engine oil?
    Manly West, Brisbane
    397
    Default Use-by date for engine oil?
    How long does engine oil, both mineral and synthetic, last when stored?
    I have a 5lit can that has been sitting on the shelf for about six years. Is it still good to use?
    19,225
    Quote Originally Posted by Breitie View Post
    Link to Mobil recommendations
    https://www.mobil.com/en/industrial/...e-and-handling
    5 years seem to a pretty typical shelf life if stored in optimum conditions.
    1000+ Posts driven's Avatar
    Apr 2005
    1,572
    Won't have latest additive packages though :-(
    Newcastle
    2,811
    Hi
    YES !
    You know mineral oil has been sitting under the dirty old ground for millions of years before it was liberated ! So why would we be worried about oil in a sealed container. Shake it a bit before use
    Jahn
    19,225
    Hi
    YES !
    Jahn
    However the additives and other ingredients haven't been beneath ground. And have the potential to separate (and degrade) from the mineral content.
    So you are confident that a "little shake" is all that is needed to restore the mixture ?
    What is your view on synthetic oils ?
    The op hasn't shared the whole story of his "6 year old oil"
    Edit: It could prove to be expensive mistake if your assumptions/ theories are incorrect.
    Oct 2005
    North of Hornsby
    2,664
    I'd rather 6 year old 'new' engine oil in my sump than black stuff unchanged for 2 years that's been through hell and back.
    Dave
    2008 Renault Laguna 2.0 dCi estate
    2013 Renault Koleos 2.0 dCi 4WD
    ​1997 BMW K1200RS
    IR655
    Feb 2005
    rosevale/tasmania
    2,873
    Quote Originally Posted by 68 404 View Post
    Dave
    um, there is a third option: buy new oil. As the old quip has it: oil is cheap; metal is dear.
    robmac and JohnW like this.
    Oct 2005
    North of Hornsby
    2,664
    The third option wasn't available at the time of posting!
    Dave
    ​1997 BMW K1200RS
    IR655
    Dec 2010
    Blackburn Victoria
    505
    Put it in the company car.....
    19,225
    Or the motor mower
    Wildebeest likes this.
    BVH Roger Wilkinson's Avatar
    Warrnambool
    2,413
    I reckon it depends on the oil and the application. The less fancy the oil and the less fancy the engine, the happier I would be to use it. I have a couple of 5 gallon drums of light oil my father salvaged from the Paul & Grey Shipchandlers warehouse when they shut up shop in Melbourne 60 or more years ago and still use it for things like lathe lubrication. I would inspect aged oil before using it in an engine. I have some tractors that are 50, 60, even 70 years old, and I would be comfortable putting aged oil in their engines as long as it looked and smelled all right. But in my modern tractors and cars I would use only relatively new oil.
    Roger
    9,307
    Total's advice for "optimal" storage times - Total - Lubricants shelf life
    11,310
    That's interesting. Very conservative - shelf life of LHM for example is far shorter than the fluid is normally left in cars that are operating. Still, that's what they are prepared to stick to for their customers presumably, so what you buy from Total is younger than those durations, by some unknown amount I suppose.
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    11,310
    397
    Thank you all, for your valuable comments.
    I am surprised by the relative short shelf life of lubricants, as set out in the TOTAL table.
    I always believed that mineral oil was 'indestructible', unless it is actually burnt, and would be good as gold and ready to go round once again after being cleaned up. I remember businesses in the past who 'recycled' used oil and re-sold it for engine lubrication, but at a cheaper price than 'new' oil and their containers identified this oil as being recycled.
    I am not sure about synthetic oil because it appears to mix more readily with water than mineral oil?
    11,310
    I have a friend who used to use one of those reprocessed engine oils. His car remains the only example I know of personally of a near new Renault R10 running a big end bearing. He also had camshaft trouble with a 16TS, although that might not have been the oil....
    Back to Peter's "oil is cheaper than metal" I guess. Not that you were arguing!
    CHeers
    9,307
    Refining used oil for reblending is still a big business, eg Southern Oil
    11,310
    Thanks - interesting to see. I presume it must be fairly reputable, at that scale of investment.
    Simon's Avatar
    6,203
    Just look at the prices of old empty bottles and cans of oil. Stick it back on the shelf for another 30 odd years, potentially a better return than a bottle of Grange.......
    pug206gti, JohnW and J-man like this.
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
    19,225
    But not nearly as pleasant to consume.
