Renault special tool details
Like Tree4Likes
  • 1 Post By Simon
  • 3 Post By JohnW
Thread: Renault special tool details
    4,363
    Default Renault special tool details
    Does anyone have either the actual item or diagram and measurements for the special tool to compress front springs on an R8/10?
    I seem to recall it's a threaded rod that fits up through the middle to the shock tower, with some sort of plate underneath the lower control arm that screws up and compresses the spring. I'd like to make one if anyone has any details?
    Kevin
    KB
    Simon's Avatar
    6,134
    Are these helpful? The wingnut is the same as used on the T.Av. 238-02 tool, indicating the threaded rod is a fairly coarse thread.
    Attached Thumbnails Attached Thumbnails Renault special tool details-dsc08925.jpg   Renault special tool details-dsc08924.jpg
    vivid likes this.
    1963 Renault R4 Van
    1964 Renault R4
    1967 Volkswagen 1300 Deluxe
    1969 Renault 8 Gordini 1300
    4,363
    Yes, thanks Simon.
    The second drawing does give me some ideas to work from.
    KB
    10,703
    When you have perfected it, there may be orders......
    I've always done it by using the standard jack under the inner, lower pivot and undoing those bolts carefully, using the car's weight to keep the spring compressed, then slowly winding down the jack. You need the car high enough that the jack can come DOWN far enough to release the spring compression. The right tool would be a bit more sophisticated!
    We're in Kalgoorlie, nearly home from the Muster, with a bit over 8,000 km on the R8 since leaving Perth. Going well so far.
    Sunroof, Wildebeest and Shoji like this.
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
    4,363
    I'll try loosening those bolts John, that's not a bad idea.
    The problem I was having was that as I tried to compress the spring with a trolley jack, it was lifting the front of the car off the axles stands before it was compressed enough. I brought 12x15kg boxes of biscuit shortening home from work yesterday (it was being thrown out), so I now have more weight to put in the boot and try again. In fact as I was loading it up, I could feel the rear end lifting so it's close to the tipping point!
    KB
