R8/R10 Hub Assemblies - Page 2
Page 2 of 3 First 123 Last
Results 26 to 50 of 51
Like Tree6Likes
Thread: R8/R10 Hub Assemblies
  1. #26
    Ipswich, Queensland.
    1,845
    Quote Originally Posted by R8RX View Post
    What is the easiest way to get the inner bearing of the stub axle ?
    Don’t know this is the easiest way, but I have often used a 100 mm grinder with a cutting disc to grind a flat on the inner down to a point where it starts to go blue at the closest part to the axle, maybe a mm thick. I stop at this point before going through to the axle and give it a hit with a cold chisel, usually cracking it and making it easy to remove. Requires some dexterity with the angle grinder, but I have done this successfully more than a dozen times over the years without damage to the axle.
    JohnW likes this.
    '56 Renault 750 (16TS Power)
    '62 Renault Dauphine Gordini
    '08 Renault Megane sedan
  2. #27
    Jun 2018
    Norway
    86
    Used the split plate bearing puller advice Pulled off two bearings on no time, but wrecked two bearing seal holder plates
  3. #28
    Jun 2018
    Norway
    86
    What is the weak points on these assemblies? Thinking of motorsport use.
  4. #29
    10,492
    I'm not remotely qualified to comment! I will say that the later ones have stronger stub axles. There are kits available to reinforce the steering rack mountings.
    PM Frans!!!
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
  5. #30
    10,492
    Yes, you would have! The later ones for the stronger stub axles are available as a replacement part I think.
    Renault 4CV 1951
    Renault R8 1965
  6. #31
    Jun 2018
    Norway
    86
    Yes, i have seen some pictures of a strut brace for the steering rack. But my steering rack and steering column are lowered.
    Yes, new plates are on their way from France.
  7. #32
    Oct 2014
    Windsor 2756 NSW Australia
    523
    The type of motorsport you intend to participate in will determine the weak points. Most upgrades such as bracing the steering rack and dual shock rear ends are mostly rallying upgrades.
    I assume that if your rack is lowered it is because the ride height was raised for rallying. If you intend to race on a sealed race track, the rack should be returned back to the original height or higher to maintain the correct geometry if the car is lowered for tarmac race track work.
    There are many rallying experts here however I recall that if you're going rallying, the front suspension arms need to be reinforced and there are many areas of the chassis that will require reinforcement. History shows however that it will still flex and crack after some serious rally use.
    geckoeng and JohnW like this.
  8. #33
    Jun 2018
    Norway
    86
    Not entirely sure why the rack was lowered. Rideheight seems to be standard. But I believe it has to do with everything between the suspension arms were Volvo-stuff. So could be because of the position of steering arms. I am in the process of rebuilding back to R8 parts because of regulations.
    So anyway it is smart to brace the steering rack Suspension arms are already reinforced. Not going rallying with the car. But it is an old rallycross/hillclimb car. Yes, have some hours of welding the car. But mostly because of rust.
  9. #34
    Newcastle
    2,473
    Hi R8RX
    With regards to the rebuilding of the steering and correcting the rack position. As you are probably aware the rack position is adjustable in the standard car so it can be moved slightly to make the geometry correct. This applies to getting the rack end joints in the correct relationship to the upper and lower wishbone inner pivot positions. If this is not correct it will give changes to the toe of the front wheels during wheel movement. This will make the steering twitchy under bumps or worse !
    The genuine manual has a procedure to check this and correct it. But from my memory it is not clear what was intended to be the reason for it and the step by step description does not help if you do not know what you are trying to achieve. It was only meant to adjust small position changes caused by minor accident damage and some minor bending and repair.
    Good luck Jaahn
  10. #35
    Jun 2018
    Norway
    86
    Hi Jaahn! Thank you! Yes, bump steer is a thing I am concerned about. I know what can cause it, but that's all really. My rack is mounted directly in the crossmember, in the lowest hole. So I guess we are talking about a movement of centimeters from the original position. I have a feeling I need to do something with the rack. Maybe wait and see and when everything else is back to original, then concentrate on the steering rack.
  11. #36
    Jun 2018
    Norway
    86
    I've bought a set of NOS tie rods since I need to replace the custom ones which currently sits on the car. One tie rod is slightly longer than the other. Which tie rod goes to which side of the car?
  12. #37
    10,492
    I thought they were the same length but I can't find two to compare - I've been tidying up and losing things is always the result!
    However, they can only fit one way - there are two part numbers, one for each side. My term is that they are "handed", that is a left-hand side and a right-hand side. Are they the old ones with the adjustment on the eye bolt at the rack or the new ones with an adjustment in the rod itself?
    Renault 4CV 1951
    Renault R8 1965
  13. #38
    Jun 2018
    Norway
    86
    Yes, these are the old ones with the adjustment on the eye bolt. Haven't got anything to compare with either. It is definitely a left and right side yes. But I don't have a parts list or something similar to check with.
  14. #39
    10,492
    Do you have parts numbers for them?
    My manual (P.R. 818, Renault 8, 1965-1973) gives two number sets:
    Left: 09 81 950 300 for most cars and 77 01 453 399 for a few R1132 cars if I read it correctly
    Right: 09 81 950 400 for most cars and 77 01 453 400 for a few R1132 cars.
    They can only fit on one side correctly. What is the length difference?
    Try to find a parts book on ebay. They are fantastic.
    Renault 4CV 1951
    Renault R8 1965
  15. #40
    1000+ Posts Frans's Avatar
    Auckland
    1,423
    Hi,
    I have 2 Quintin Hazel NOS ones that will go onto my Gordini soon. The ones I have are the same length for RH and LH. I hope you have measured wrong or maybe we are talking a few mm and not more.
    If they are equal length it is easy to ID them when you install the rack first. Then the angle at the rack end will tell you straight away which is which. If it is difficult to connect the ball joint end you have them the wrong way around. The twist at the rack end is there to locate the ball joint end easier.
    I would think they are the same lengths.
    Frans.
    JohnW likes this.
    Old enough to know better
    Young enough to do it anyway.
  16. #41
    Boonah Qld
    2,441
    It's quite awhile ago since a played with these but doesn't one have an oval cast on it to indicate which side it goes. I am sure the manual tells you which.
  17. #42
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    3,804
    They can only fit on one side correctly. What is the length difference.
    I have a P.R.700 Renault 8 R1130
    Left: 9819503
    Right: 9819504
    Regards Col
    1995 Renault Laguna V6
    2002 Renault Laguna V6
    1973 Alpine A110
  18. #43
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    3,804
    I also have a P.R. 992 Alpine A110 1973
    It agrees with Johns numbers above.
    Regards Col
    1973 Alpine A110
  19. #44
    10,492
    Left: 9819503
    Right: 9819504
    They added quite a few zeros over time....
    Renault 4CV 1951
    Renault R8 1965
  20. #45
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    3,804
    Yer I noticed that after I had typed them in and was comparing.
    Regards Col
    1973 Alpine A110
  21. #46
    Jun 2018
    Norway
    86
    I have to check numbers when I get home from work. When you put the two tie rods together the difference in lengts is clearly visible. I would say about 1cm. They came in a Renault plastic bag, but the text on label was gone. Someone made a new label and wrote Renault 8 + 10 on it.
  22. #47
    Jun 2018
    Norway
    86
    Thank you for your help
  23. #48
    Jun 2018
    Norway
    86
    The new type of tie rods, these that are adjustable. Are they something that was orginally manufactured by Renault or are they been produced by others later?
  24. #49
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    3,804
    As far as I can make out they are from the newer Renault models that happen to fit the older ones as well.
    I think the R5 tie rods fit the R8/R10
    Regards Col
    1973 Alpine A110
  25. #50
    Jun 2018
    Norway
    86
    Ok, thank you
